C63 AMG (W204) 2008 - 2015
What did you do to your C63 today?
Old Oct 16, 2022 | 03:55 PM
  #151
sickSVT's Avatar
Top Answer: 1
3.0L Whipple E63 AMG
Started clearing out the drivers side area to mock-up the trans cooler. Fits perfectly, just waiting on some mounting brackets then I should be able to run the lines.
Deleted SAI system with VRP block-off plates. Removed windshield washer, wipers and motor assembly. About 30-40lbs removed from the front-end.
Old Oct 19, 2022 | 01:58 AM
  #152
swedepat's Avatar
2011 C63 AMG, 589hp
An advice, as the fittings are on the lower side, you might get an airpocket at the uppersize in the cooler, and by that not having it all that effective.
Weld a bung on top of it and put in an airpocket release screw.
Old Oct 20, 2022 | 12:22 PM
  #153
swedepat's Avatar
2011 C63 AMG, 589hp
Started updating doorspeakers as the were tired from abuse from the rockfordamplifier.
I chose Hertz 6.5" Mille PRO.
And as they are able to produce a lot more midbass i needed to sound deadening the doors.
The eagleeyes notices i still use oem harmankardon tweeters in rear doors.
At from i will swap them for something else, just haven´t decided yet
First impression thoug:
They can take a lot more bass.
I turned up the gain on the amplifier, lowered the highpass frequency from 90hz to 70hz and turned up the bass on the headunit.
They can still take it without loosing control.
And having the subwoofer unconnected just running the doorspeakers it is very impressive.
And also, but didn´t do that today, i did it a couple of months ago, i bought a rockford fosgate PIII 15" sub instead of the cheap 'GAS' i had temporarely after i blew my kicker L7 12"
It cleaned up the bass a lot.
Old Oct 21, 2022 | 03:22 PM
  #154
swedepat's Avatar
2011 C63 AMG, 589hp
Just 15sec clip.
Took some ravemusic with no song for your listening pleasure *LOL*
(copyright issues)
Hertz MP 165.3 pro, from their 'mille' series..
They are driven by a Rockford prime amplifier(R2-500x4) in this small clip i had the highpass set to 70hz And headunit bass set to +6. i measured 112dB without the subwoofer, with mic next to my right ear.
Old Nov 5, 2022 | 02:56 PM
  #155
sickSVT's Avatar
Top Answer: 1
Got the trans cooler all mounted up and wired up. Tested and works great, pump and fan automatically turns on after the trans fluid reaches 180 degrees.
Decided to use a relay to power the pump and fan, soldered and sleeved all connections for a clean install.
Old Nov 6, 2022 | 08:32 AM
  #156
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Curious how the fluid change procedure will go now.
Old Nov 6, 2022 | 10:37 AM
  #157
deadlyvt's Avatar
2010 C63 AMG
looks good
Old Nov 6, 2022 | 02:20 PM
  #158
Phil_T's Avatar
C63 AMG Saloon
Looks great, any information on the install? Items you bought? How you installed it all? Deleting the SAI etc
Old Nov 6, 2022 | 03:04 PM
  #159
AMGSIXTHREE's Avatar
'09 C63 AMG
R230 SL55-style smoked reverse lamps
Old Nov 6, 2022 | 11:40 PM
  #160
NZ-Merc's Avatar
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
Hi Team,
I was busy this last week polishing and cleaning up everything under the C63 front to rear that I could reach with my rags and brushes.
Then it was all discs off for repainting, cleaned callipers and changed brake fluid.
Old Nov 7, 2022 | 08:23 AM
  #161
DRBC43AMG's Avatar
Damn that's clean
Old Nov 8, 2022 | 02:58 PM
  #162
sickSVT's Avatar
Top Answer: 1
Pretty simple, just jump the pump and let it circulate new trans fluid.
I got everything from Setrab.
  • Oil cooler with fanpack
  • Oil Pump
  • 30/40 amp relay
  • Mounting Brackets
  • AN Fittings
  • Temp Switch
VRP Sells the SAI delete plates, just remove the SAI pump, lines and plug a small vacuum line on the intake manifold. Your tuner will have to turn off the engine code or you can do it via Xentry.
Great mod overall, drove it hard on Sunday and the trans cooler works as expected.
Pump and fan comes on at 180F and cools the trans fluid quickly, trans didn't have the sluggish feeling after driving it hard after a few hours.
Old Nov 8, 2022 | 05:37 PM
  #163
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Do you think the external cooler will empty through the pan when you yank the drain plug?
You will have to fill the pan through the fill plug then run the external pump to prime the cooler and lines at the same time so it doesn't suck in any air. Then on top of that run the car and set the fluid level once it hits a specific temp.
Old Nov 9, 2022 | 01:36 AM
  #164
Phil_T's Avatar
C63 AMG Saloon
  • Oil Pump
  • 30/40 amp relay
  • Mounting Brackets
  • AN Fittings
  • Temp Switch
Thanks, are you able to delete the SAI but keep the washer fluid bottle? I don’t mind deleting the SAI to make room but don’t want to remove the washer fluid bottle.
Did you have to remove or re locate the horn too?
Old Nov 9, 2022 | 07:18 PM
  #165
sickSVT's Avatar
Top Answer: 1
I think you could squeeze the cooler in front of the washer tank but you'd have to make some custom brackets. I've never used the washer fluid tank so I decided to delete it.
You can mount the horn below the frame rails.
Old Nov 22, 2022 | 08:28 AM
  #166
Phil_T's Avatar
C63 AMG Saloon
Finally fitted all my parts ive been storing for years since I have owned the car from new.
- BBS LM’s with Contisport 7’s, 255/35 & 275/30
- KW Clubsports
- Renntech Rear Adjustable Toe Arms With Spherical Bearings
- KMAC Adjustable Camber Arms
- Custom Adjustable Drop Links With Spherical Bearings
- Spoon Ridgid Subframe Collars
- Ultra Racing Front/Rear Strut Braces & All Underbody Bracing
- W205 C63 Amg Steering Wheel
- OEM Optional Extra Seat Mounted Fire Extinguisher
- Quaife Diff
- More Carbon Interior
I need to get round to fitting
​​​​​​- @SRG_C63 Setrab Larger Oil Cooler
- 390mm Black Series Front 2 Piece Discs
- OEM AMG Aluminium Door Pins
Still loads more to buy too!
Old Nov 22, 2022 | 12:00 PM
  #167
lo-fi's Avatar
2009 C63 AMG
Really looks good. I was just looking at some LMs. What are the offsets and widths for yours?
Old Nov 22, 2022 | 03:28 PM
  #168
C63realtor's Avatar
2009 C63
Removed steering column to replace the ESL with a emulator
Old Dec 6, 2022 | 07:34 PM
  #169
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
Engine mounts, thrust arm and voltage regulator.
Did my oil service the other day and while doing that did some other parts that needed doing.
Replaced the engine/transmission mounts, front upper control arm (thrust arm) and voltage regulator while I had the steering rack dropped.
Did voltage regulator while in there and battery disconnected.
original engine mounts 2013/120,000klm
most like original thrust arm replaced with new Lemforder part
Old Dec 10, 2022 | 08:40 PM
  #170
Meeyatch1's Avatar
'94 NSX,'99 NSX Z,'12 C63 Black Series (Prior: '07 E63, '08 CLK63 Black Series,'14 E63-S & 16 C63-S)
I didn't modify it, but I did take it on a (400) mile round trip to grab lunch yesterday. LOL! I just cannot stay out of it. Love this car.
Old Dec 12, 2022 | 06:53 PM
  #171
mr747's Avatar
c63
just finshing up this
Old Dec 19, 2022 | 07:15 PM
  #172
Meeyatch1's Avatar
I added snow tires to the Black Series.
Old Dec 26, 2022 | 03:48 AM
  #173
swedepat's Avatar
2011 C63 AMG, 589hp
I had this Audio hobby when i was younger, as many young guys do, i have kinda awakened that again, now almost 30 years later.
I try to combine audiophile with possibilites to play loud if i want to.
I have good experiance of Hertz, so i combined a kit myself:
3" 'pro' midrange.
And their best tweeter ML 280.3 Legend.
And ofcourse it wasn´t done 'today', but i´ll connect them today as i´m about to finish the passive crossovers.
Old Dec 30, 2022 | 08:42 PM
  #174
sickSVT's Avatar
Top Answer: 1
Got my JQ Werks magnetic paddle shifters, these have a strong satisfying click when shifting through gears. Should be a nice upgrade from the factory shifters with inaudible shifter click.
Old Dec 31, 2022 | 01:10 AM
  #175
Ragunarok's Avatar
C63S Coupe
Looking forward to your review on these compared to stock paddle shifters
