Maximize transmission shift performance with us!
Both vehicles have factory original transmissions WITHOUT ANY TCU tunes or modifications from factory. A perfect engine tune will allow the factory TCU to optimize shift parameters and maximize shift speed and directness to the potential of the 'factory limits'.
Actual shifts are quick, but the delay between paddle press and actual shift is the annoying thing that no one seems able to address.
I like you Barry but you’re going to have to provide some detail otherwise I call total bullshït. We had this debate on FB already and I’m pretty sure you lost.
The TCU and ECU are totally separate systems, with the TCU running closed loop. How exactly is an ECU tune causing faster shifting than you get with a factory fresh car? I’m not talking about you fixing someone else’s shïtty tune that sent bad values to the TCU. I’m talking about your claim that a car with your ECU tune shifts faster than a factory fresh car. It’s not possible.
”With a engine tune from eightysixtuned shift speeds of the factory 722.9 MCT transmission are greatly improved.”
That’s just a patently false statement. You’re better than that Barry.
it may be hard to comprehend, but factory tunes are built with cushion to ensure compatibility across a broader range. maybe the use of the word greater isn't ideal but our tunes do indeed aid in shifting speed and directness due to a very accurate torque figure being passed to the TCU which then translates to allow the TCU to tighten up shifting. if you continue to state our ECU tune cannot pass a more accurate number to the TCU you also would then be stating the factory ECU tune makes the max power possible for any engine configuration which we all know is not the case.
But i can´t agree on that an ecu tune will improve shifting speed above oem speed(if AMG hasn´t left any on the table).
It is easy to f_ck up the ecu tune and by that confuse the tcu - result is very lame shifting.
Earlier in my AMG history i had a kleeman supercharged C55 with a piggyback to control ignition and fuel instead of ecu tune.
Early in my tuning of that car the gearbox was really confused, this due to i didn´t have the signals correct calibrated(input/output of piggyback), engine was running good, really good thou.
Later on i did a lot of work getting the ecu to send 'unaltered values' to the TCU, and by doing that the gearbox came back to normal.
Here’s the problem language:
”With a engine tune from eightysixtuned shift speeds of the factory 722.9 with torque converter transmission are greatly improved. In addition, transmission 'acceptance' of paddle shifter inputs are instantaneous. Physical shifting of the transmission post paddle input is greatly improved.”
None of that is true. It’s just not. And I’m saying that Barry is better than resorting to language like this to sell tunes. Let his ECU tunes stand on their own merits, which by all accounts are far better than most. Don’t become like the others with false advertising and claims that do not exist.
Unless there’s hard proof with timing of shifts and paddle input to shift speeds - which there is certainly not - then this is just more of the same bullshït claims we’ve come to expect from tuners. It’s not necessary or welcome, and frankly a little disappointing especially coming from “one of our own”.
known places and they use way too much smoothing and set values on things that should not be generic set values. Also they increase throttle actuation angle per degree of pedal input to make it feel faster but then don't adjust the torque limit at that value so the transmission gets 2 separate map details. As far as it actually shifting faster from a stock car or with less time from you requesting the shift from the paddle I would also say yeah don't see that happening.
Unless the factory tcu has multiple shift maps based on torque output and throttle angle to which you could theoretically just make it one consistent map and receive the fastest possible shift each time you requested it regardless of rpm and or throttle/torque output
1)The shift communication from the paddle shifters to the transmissions clutches, is only fixed through a Valvebody upgrade.
2)The shift speed, or how fast the clutches are working to get to the next gear, is determined by aftermarket clutches.
"OR" (in my opinion the correct option)
3)You need both aftermarket clutches and a valvebody to get this modern communicated paddle shift to transmission shift down correctly.
I don't want to compare but like if I could maybe a Toyota supra A8. Lets make AMG's Great again who is gonna be the guy to do it, talk is cheap.
Their using a auto w/ a torque converter and the response from the paddle shifter or the communication is what we are looking for, the c63 shift speeds from the transmission the mechanical part is perfect doesn't need to be faster.
Our goal as a community for the TCU debate is to get the car to operate TCU wise like a toyota supra A8 or a 340i bmw
