C63 AMG 2013 Fobs not detected
I’ve since replaced the car battery to make sure. Now still doesn’t start but has new symptoms. Here are the symptoms:
- FOBs are not detected when i am in the car with the keys.
- Both fob keys have new batteries.
- When I have keys in the car the dash display does not show that keys are in the car.
- All lights work including hazard lights.
- When I open the driver side door the dashboard lights up, but nothing to suggest it recognized keys, and after a minute dashboard goes blank even when i am in the car with the keys.
- I cannot use fobs to lock or unlock doors, but I do hear the relays click when i press Fob keys.
- I’ve checked all the fuses under the hood on driver side and ones in the trunk/boot.
- Trying to start with the keys instead of push button does absolutely nothing. Doesn’t even recognize keys when inserted.
- I’ve tried several of suggested Fob synchronization button sequences, but no luck with that. i think the issue is something else.
What is the expected sequence? If someone has similar vehicle perhaps you can help by telling me the sequence so I can eliminate things.
I am assuming that dashboard lighting up when i open the doors is what happens when you don’t have any keys. So what is the very next thing that happens when you do have keys?
Thanks. If anyone can offer advice, I’d greatly appreciate that.
- Should FOB be detected first and some indication on dash when it’s in the vehicle? Is this the first thing that happens?
- If steering lock ESL is the issue, would that stop ability to Lock/Unlock vehicle with FOB or central locking using buttons in doors?
- Is my logic incorrect? If FOB needs to recognized first, then is the issue to do with FOB receiver system?
- Or does steering lock issue affect everything?
if so then what is before that which allows FOB to lock/unlock car?
thanks.
