507 Forged Wheels - Rim Channel
Subscribe
Jan 14, 2023 | 10:31 PM
Hey fellas,
I had my full set of forged alloy wheels restored. After hiring a detailer to use non-toxic cleaners, two of my four wheels had the silver lining stripped from the channel of the rim. I attached an image for reference.
Does anyone have experience/suggestions for recreating the silver channel along the rim?
Thanks in advance!
Reply 0
Jan 15, 2023 | 12:59 PM
So that doesn’t make any sense as the silver groove is machined and not coated with anything except maybe some clear coat, so you can’t remove it literally not possible. I would say it is more likely the wheels in question have been refinished fully black including the grove and they had some silver applied over the black that was been removed. If they are factory finished you can see the machining markets in the groove, if it looks painted where the silver is it isn’t factory and the groove is never coated black like your picture, that wheel has been refinisheds.
Reply 0
Jan 15, 2023 | 03:17 PM
show a pic of the wheels still with the silver intact.
Reply 1
Jan 15, 2023 | 04:17 PM
Looks like they painted/refinished the wheel in all black and filled in the groove.. will prob need to strip the paint in that groove carefully as to not to peel it elsewhere
Reply 0
Jan 16, 2023 | 08:20 PM
Quote: So that doesn’t make any sense as the silver groove is machined and not coated with anything except maybe some clear coat, so you can’t remove it literally not possible. I would say it is more likely the wheels in question have been refinished fully black including the grove and they had some silver applied over the black that was been removed. If they are factory finished you can see the machining markets in the groove, if it looks painted where the silver is it isn’t factory and the groove is never coated black like your picture, that wheel has been refinisheds.
I'm aware. I had the wheels restored because there were a few minor scratches and curb rash along the rim of the wheels.
Several shops I called in the area do not have the 5-axis CNC machine required to create the silver etching along the rim channel. The shops I called that did have the right equipment only take on projects for specific brands — Mercedes-AMG not being one of them.
Reply 0
Jan 16, 2023 | 09:37 PM
Looks like he forgot to mask the lip when he repainted the rest of the wheel. It's just a polished finish with clear. You could probably have the guy strip them and do it right this time I would think?
Reply 0
Mar 4, 2023 | 02:55 PM
I'm aware, there was some curb rash on the wheels, so I hired a local wheel restoration company for the full set, which required sandblasting and powder coating. I wasn't present when the wheels were sandblasted, so it's very possible that the silver channel was exposed but they didn't think to mask off the channel before powder coating the wheels.
What exactly would I need to ask for to bring back the factory machined channel? I've been told by a few other enthusiasts that I'll need to find a shop with a 5-axis CNC machine to get this done.
Reply 0
Mar 4, 2023 | 04:03 PM
Check out this video and scroll to minute 9:30. I believe they’re doing exactly what you’re after.
https://youtu.be/FM7BmrjjaPE
Here is another video that shows similar process. Scroll to minute 2:50.
https://youtu.be/sgz_XHj4dsQ
Reply 0
Explore
Mar 8, 2023 | 07:27 PM
Quote: Check out this video and scroll to minute 9:30. I believe they’re doing exactly what you’re after.
The end result looks incredible. I'll be using this as a reference point. Thanks!
Reply 0
Subscribe
Currently Active Users (1)
