Front bumper vs normal C300 wider or same?
What are the differences? Mounting points? Width? Height? etc etc. I'm curious if a regular C300 bumper would fit on the 63 (this is just about fitment ignore cooling holes etc) I looked and most places say the body is the same width the 63 just has more flared fenders. does anyone know?
Received 2,842 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Won’t fit it’s not even close /thread
explain? as in not even close the width is different or the openings are different? this is purely a question if if the DIMENSIONS of the bumper are the same, not if the mounting holes and air vents will line up.. you have compared them?
Yes the width is considerably wider. You would need to do the fenders as well. And they would require some different mounting hardware as they and the hood are longer va the c300. Just leave your c300 and save up for an actual c63...
lol i have a 63 and want to put a 300 bumper on it i've actually owned BOTH and i dont remember the actual bumper being bigger ill have to find one in the wild and measure it...
To clarify for everyone
1. I OWN THE 63 i want to put the 300 BUMPER on it... sleeper style.
2. I KNOW the 63 is wider but I thought that was just rim offset + wider fenders meaning the BUMPER would be the same width?
3. I also know the mounting system would be different, and ventilation would need to be dealt with. purely a dimensions thing.. you know what maybe ill go on the 300 forum and ask someone to measure and settle this.
I swear the questions get stupider and stupider here every day.
Hey genius. You know what the bumper attaches to? The front fenders. If they are wider, what do you think the bumper is?
Yes please go to the “300 forum” to “settle it”. We are all holding our collective breath in anticipation, this is exhilarating stuff.
EDIT: you’re the same dumbass that told everyone to add like two quarts (19mm) more oil over the dipstick fill level because you completely misunderstood a Tasos video then double and tripled down on it. You rode the short bus to school didn’t you. https://mbworld.org/forums/c63-amg-w...08-2012-a.html
GRP (07-27-2023)
Question is only stupid because you assume, if all you're implying is a little Bondo on the end to build up the fender area on the bumper, then this will work. So it IS the same width the only difference is the connection points the parts I SPECIFICALLY said I didn't care about?
Are you on drugs? Do you have any extra, they sound fun.
I'm glad tweedle dee and tweedle dum had input and I have my reasons for wanting to know the information, but obviously neither of you know the information... but want to seem knowledgeable about said information so put down anyone who asks something. also yes.. extremely clapped out...
3 people already gave you the exact same answer Einstein. It won’t fit. We don’t owe you a reason. Get lost.
"its wider" is not and answer to the question of where it was wider at.. is it along the entire length or just the flares at the end... you act like that question is answered somewhere in this thread... its not.
05 SL55, 10 C63, 12 SLK350, 20 S560, 08 Bentley, 14 Porsche Cayman S
You should be able to answer your own question. You have a C63 and a C300 . Park them next to each other and you can measure yourself.
Go out and look at your car if you have one. Look at the fenders and how they line up with the bumper. Now imagine the bumper is 1 3/8" less wide on each side. Will it fit ? Yes it will bolt up it has the same mounting points. But will it line up and fit? No it wont. You'll have to add the less width fender which happen to also be a shorter length so you'll have to change the front substructure and a shorter hood. Or have mad gaps and uneven fender. I guess you could get a custom one off set of less wide fenders and some smaller width rims and tires and have it all line up. Of course no one would spend thousands to make there car literally worse in every possible way just because... so there's some bs smell coming here...
The circular support posts on the front frame that the bumper cover slips onto is almost a full inch wider. Bondo can't make the inside profile of the C300 bumper cover wider.
You could possibly cut the C300 bumper cover in half down the center so you can attach both sides and add "a little Bondo on the end to build up the fender area on the bumper" then add a lot in the center to bring it together.
Thank you deadlyvt/jasonoff, this was the information i was looking for I was wondering where the wider portion was.
