Help:Bad smoking and oil on the exhaust
So last night I drove on a dark deserted road would slowly climb to 60 mph and then cram on the brakes with two feet. I did this three times no tire squeal just slowed down aggressively
On the third time I noticed as I looked in the mirror there was a ton of smoke coming out of the back of the car again no tire squeal
Then I realize the smoke didn't stop as I was driving and I thought maybe my brakes are locked up in the rear but I didn't hear or feel anything odd. And then I could smell an oil smell.
I pulled over into a local gas station and noticed that there was smoke coming out of the driver side exhaust pipes. And if I gave it some throttle the smoke increased pretty badly. I use my finger to wipe the inner part of the exhaust tips and notice that there was an oil residue inside. But only carbon build up on the passenger side
Here is a video after I let it sit overnight and turned it on this morning
https://youtube.com/shorts/ALJciDwX1qk?feature=share
Fuel trims ?
No CEL
No rough idle
I'm hoping it's just the PCV 🙏🙏
His advice is sound, also to answer your other question, no I would not drive the car until you can properly diagnose where/what the issue is.
The amount of smoke coming out is extensive enough that you have a consistent issue that isn't something you can "drive around" and not potentially either cause more or even extensive damage in places that are not affected yet.
This may sound odd but is there anything you smell that you can identify?
Normally oil is a bluer tint but you can also sort of smell it as well...
Otherwise, start checking your plugs as suggested above and don't drive the car.
Gonna pull plugs tonight when I get home and then report back..able to borrow my parents car...
Hard part is I have no extra car lol
Wife needs hers
The NSX has all parts pulled for Rack and pinion and blown shocks and then this
When it rains it pours
https://blueridgemb.com/
Pulled first plug. How does this look to you
At first I thought the stuff on the threads was oil but then I realized it's probably anti-seize
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
It's not oily though. It's thick and sticky on nature. Any other suggestions?
