C63 AMG (W204) 2008 - 2015
M156 P0300 Misfires when warm
Old Sep 26, 2024 | 12:23 PM
  #76
HLG600's Avatar
2009 SL63 AMG
Originally Posted by MTBSully
I haven't yet. because I am hesitant to start cutting up my factory harness sheathing to potentially check for a ghost wiring issue, but it may come down to that.
For what its worth, theres no way that pic is a factory splice either, right? Looks like a solder repair someone did at some point.
Tough to tell from the condition of it in that photo.
That tech is claiming it was a factory splice. Seems like enough similarity between the issues on that car and yours to warrant a look, IMO.
Phantom issues on European cars often lead to something electrical being the culprit, no?
Old Sep 27, 2024 | 01:40 PM
  #77
MTBSully's Avatar
2006 E55
Latest updates!
Old Sep 27, 2024 | 03:46 PM
  #78
WeisseTiger's Avatar
~ 2011 E63 AMG
Glad you're back on the hunt! I am confident you'll figure it out!
I kinda agree with this guy... the word "exhaust" kept ringing in my head after watching you troubleshoot this issue. Like he said, it doesn't hurt to try - remove the X-pipe and see how she likes it.
Best of luck!
Old Sep 28, 2024 | 05:00 PM
  #79
alyqc's Avatar
C63 AMG 2009
see reply below
Old Sep 28, 2024 | 05:01 PM
  #80
alyqc's Avatar
C63 AMG 2009
This is from factory, i only removed the insulator was on it. Trust me , not the first bad weld from mercedes factory i saw !
Old Sep 28, 2024 | 05:10 PM
  #81
alyqc's Avatar
C63 AMG 2009
Also , did you check for engine harness oil contamination ? just remove ur ECU engine harness from the computer and check for oil inside ... i saw a lot of these on mutiple mercedes engine ! This can cause a lot of strange issues !
Old Sep 30, 2024 | 09:28 AM
  #82
MTBSully's Avatar
2006 E55
I did check the main connectors at the ECU. They were clean and dry. The only oil I have seen in my harness is on some of the injector plugs, which seems to be somewhat normal on these cars, and doesn't cause issues from what I have seen.
Old Sep 30, 2024 | 04:41 PM
  #83
NZ-Merc's Avatar
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
Hi,
Can you swap the cam solenoid from left to right cylinder head or borrow a r/h solenoid from someone just to try it on your engine.
Old Sep 30, 2024 | 04:43 PM
  #84
MTBSully's Avatar
2006 E55
Originally Posted by NZ-Merc
Hi,
I did that. No change.
Where is everyone getting Xentry from? I see a few downloads on Etsy for ~$20. I ordered the Tactrix Openport 2.0. Will be running on my windows 10 laptop.
Old Oct 1, 2024 | 01:24 AM
  #85
Slava30490's Avatar
W212 E63, W203 C55, L405 4.4
Mhh Auto is a good source, for openport need special xentry revision. If help needed - text me
Old Oct 1, 2024 | 09:50 AM
  #86
MTBSully's Avatar
2006 E55
Thanks! I'll check it out
Old Oct 3, 2024 | 08:33 PM
  #87
alyqc's Avatar
C63 AMG 2009
yes i saw a lot of time oil in injectors plugs. its a ''normal'' condition for these motors
Old Oct 22, 2024 | 04:22 PM
  #88
MTBSully's Avatar
2006 E55
Got my xentry setup working using the Tactrix openport 2.0 and Xentry I downloaded from Etsy for $20 lol. Seems to work well, trying to figure out how to properly run the cam adjuster tests. Did a cam position re-learn, no change.
Old Oct 22, 2024 | 05:11 PM
  #89
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Which one did you DL from Etsy?
Old Oct 23, 2024 | 08:59 AM
  #90
MTBSully's Avatar
2006 E55
This one:
https://www.etsy.com/listing/1693182...aid=d478380b5e
Old Dec 1, 2024 | 08:51 AM
  #91
MTBSully's Avatar
2006 E55
Bump. The battle continues. Think i might have it narrowed down to an adjuster problem, but who knows lol.
Old Dec 3, 2024 | 10:37 AM
  #92
blay127's Avatar
W204
man what a battle. thanks for keeping us updated. its an awful problem but certainly an interesting one.
Old Dec 16, 2024 | 08:33 AM
  #93
MTBSully's Avatar
2006 E55
Update: bought 2 used cam adjusters on ebay, along with a new cam adjuster cover complete with cam sensors and solenoids. Rebuilt the adjusters using my 63 motorsports plates.
Exact. Same. Issue. No change at all.
Checked and cleaned all of my grounds, some of which had some corrosion. Still no change.
Might pull the ECU apart and look for damage and/or send it off for testing. Not sure what else it could be at this point. Very frustrating.
Old Dec 16, 2024 | 02:32 PM
  #94
6_Myles's Avatar
1998 E300TD
Damn dude......I admire the persistance and thankful the car is with someone who wants to try and fix it, even though she doesn't appear to want to be fixed.
Old Dec 16, 2024 | 02:45 PM
  #95
MTBSully's Avatar
2006 E55
Thanks. She's got only 68k miles and is super clean. Too nice to give up on. Part of me wishes it had high miles and was beat so I could let go easier lol
Old Dec 16, 2024 | 02:47 PM
  #96
6_Myles's Avatar
1998 E300TD
I get it. I rebuilt my engine because mine was a 36k mile cream puff for the same reason
Old Dec 16, 2024 | 03:16 PM
  #97
HLG600's Avatar
2009 SL63 AMG
We're rooting for you and the E63. Has to be something that is resolvable.
Might be time to check into the wiring.
Old Jan 2, 2025 | 10:23 AM
  #98
MTBSully's Avatar
2006 E55
ECU is off at ECU pros being tested. They sent me a video of another car running (idling) with my ECU and claimed no issues with the ECU. I didnt know what kind of testing they were going to do and didn't know they were going to put the whole ECU on another car, so i originally didnt tell them anything about my particular issue. I have told them that my car only misfires at ~1500rpm and asked them to re-test. Hoping they get back to me today or tomorrow.
In the meantime i've found the wiring diagrams for the engine harness and have started checking all of that. Continuity and resistance values. Nothing out of the ordinary so far.
Assuming the ECU is fine, once I get it back I am going to install an oil pressure gauge and make sure that is in spec as well.
Any ideas what else to check? Knock sensors? Gas pedal sensor? i really dont think this is a coil pack issue since i've swapped coil packs around and the misfires don't change, but anyone know what pins I could probe on the coils to check resistance?
Old Jan 2, 2025 | 12:08 PM
  #99
debrass101's Avatar
G320
How’s the oil consumption ?
If it’s a lot, then it could be a piston oil ring issue .
Old Jan 2, 2025 | 01:37 PM
  #100
BalanBro's Avatar
2012 C63 P31 Sedan
Do you have anyone you can swap a gas pedal with and test? Not sure how that could possibly lead to the issues you're experiencing, but that is a very common failure on these cars that will throw them into limp mode (mine went bad at only 53k miles). If you know someone with a car that uses the same pedal, it's a super quick swap to test out.
