C63/C63S AMG
Check engine light on C63s edition 1
Old Sep 7, 2015 | 12:41 PM
  #51
AMGFTMFW's Avatar
W203 C230 SPORT
I have a suspicion that the "software upgrade" is bull****, and that most dealerships just turn the CEL off, hoping it doesn't come back.
Old Sep 7, 2015 | 01:00 PM
  #52
irablumberg's Avatar
2015 C63S E1; 2016 C450 AMG
That was not my experience but I can't speak for other dealers.
Old Sep 7, 2015 | 01:12 PM
  #53
RDOCA's Avatar
2016 C63S Sedan
I don't think so, as there has been too many posters saying the same thing and after update agreed it was fixed.
There was also a transmission update that seems to have fixed some shifting abnormalities.
Just picked mine up yesterday so no first hand experience yet.
Old Sep 7, 2015 | 02:46 PM
  #54
mister2d's Avatar
15 AMG C63S ED1
Originally Posted by irablumberg
About 2 months ago, I noted a similar CEL problem with my car. After checking with the factory, the dealer determined that there was revised engine management software that altered the air / fuel mixture to make it more lean. After applying the new software, my car has been just fine. I suspect this is the issue for many other people now suffering the same problem. This may also explain why some people are experiencing misfires. If the engine runs too rich for too long, there is the possibility of fouling one or more spark plugs.
This is a totally reasonable explanation. Running rich would do this. My SA mentioned they are working with a MB engineer to nail down the problem.
Originally Posted by Will617
Did you guys feel any difference in power after the update?
If they make the mixture more lean, then there should be a measurable difference. Even in fuel economy.
Old Sep 7, 2015 | 05:41 PM
  #55
Will617's Avatar
2016 C63S
I thought my car felt a bit stronger after the update. However as there was no objective testing involved, this could easily have been a placebo effect.
I had a tune with dyno on my Mustang some years ago and she was running too rich. When they leaned her out a bit she made more horses.
Old Sep 7, 2015 | 06:44 PM
  #56
True, but changes in the weather, on-going break-in (my car only had 2,500 miles at the time of the new software), the fact that the car is reset to original factory settings and begins learning all over again after the update, and different driving patterns all impact fuel economy and can hide or exaggerate the effect of the new software.
After the software update, my exhaust note did sound different and I believe there was less popping on deceleration. Again, these are all unscientific observations, but I believe the car felt stronger and sounded different after the update.
Of course the other thing is that I have not had any new problems during the 1,500 miles I have driven since the update.
Old Sep 7, 2015 | 08:25 PM
  #57
JPMBenz's Avatar
17 C63 S Coupe
My car also had a ECU update. I had a minor shake in the engine at idle. That did fix that. Also, the car seemed to be faster, exhaust got louder, and the fuel MPG went from 16 to 18.5.
Old Sep 8, 2015 | 01:15 PM
  #58
AMGFTMFW's Avatar
W203 C230 SPORT
If so, then it begs the question - why aren't new deliveries being shipped WITH the most updated software possible, leaving it to be done on a dealership level?
That makes zero sense to me.
Old Sep 8, 2015 | 04:30 PM
  #59
Sulfatron's Avatar
C63 AMG W205
The transmission update did work on mine, downshifts in auto mode/comfort are now smoother, 4th to 3rd gear downshift was really harsh before..
The only issue left is an annoying ticking sound at idle, apparently it's the purge valve doing its job.. Annoying
  #60
mister2d's Avatar
15 AMG C63S ED1
Dealer update on my CEL.
Misfire in cylinder #5. They are linking it to a bad ignition coil. No parts available and no ETA yet on when they can get a new coil in.
Old Sep 9, 2015 | 04:48 PM
  #61
mister2d's Avatar
15 AMG C63S ED1
Another update:
Dealer can't find an ignition coil anywhere, and my case has been escalated. To me that means nothing because the turnaround time now is the first week in October. That's right! One month to source an ignition coil. How pathetic. This loaner sucks too. New C300 with no nav, slow small screen, and no BT audio. This will suck commuting in traffic for a month while I hope that this addresses my issue.
What a crappy way to treat a customer who just spent 90K.
Oh...and they are transitioning ownership. Making this process ever so smoother. /sarcasm
Old Sep 10, 2015 | 12:06 AM
  #62
NelsonRealTime's Avatar
2015 C63S
Another update:
Wow, that is quite unbelievable. Can't you tell the dealer you dont want the car anymore because of all this hassle is bringing you?
Old Sep 10, 2015 | 12:54 AM
  #63
.dee's Avatar
RR Vogue; C63s; GT4 on order
Got the dreaded CEL today, car idles rough and runs like sh*t, 2,500km, dropped it off at the dealer lets see what they'll find.
Told them about the g/box update too as i had the rough downshift from 4th to 3rd.
will update the once i know more
Old Sep 10, 2015 | 07:57 AM
  #64
mister2d's Avatar
15 AMG C63S ED1
I'm not quite there yet. The car is pretty awesome when it's working. A whole month to source a part is sickening. And it isn't even guaranteed to fix the problem.
Old Sep 10, 2015 | 08:48 AM
  #65
.dee's Avatar
So i picked up the car this afternoon, and they confirmed misfire in cylinder 1, did the software update and all running well so far.
It was interesting that after the update it took a good 5km of driving and a couple of restarts for the car to feel normal again, what i mean by that is that it felt very restrained and laggy post the update yet now it is back to normal. I guess some sort of "adjustment" was needed for the ECU etc.
Old Sep 26, 2015 | 10:22 PM
  #66
Thguns's Avatar
2009 Mercedes C63 AMG, 2013 Mercedes C350 4Matic Coupe. 2012 GLK 350 4Matic
Well guys, don't know what to say, bought a 2009 in spring 97000 Km's on it. As I absolute car nut, my 4th MB, previous were, 1986, W124' 560 SEL, and SEC, Koineg wide body and a 1990 190E sport line, have always done most of my own work, what I can. This car shortly after buying it, not from a MB dealer, but reputable VW Porche, dealer had a couple of check engine lights, evaporative emission, can't remember the other, cleared them myself. Changed oil, new air filter and not problems since, was out drag racing all day, shutdown several mustangs, and a Skyline, was out at an old local airstrip , so no fancy lights and timing, but a bunch of local boys got their asses kicked, with some Europeon muscle. Through the traps, 1/4 mile approximately , 200 KPH. As a gear head, I study the crap out of my cars, have all the MB disks, etc for full maintence on my laptop, virtual library. Put some Bridgstone, R11's on it, best tires ever. Best MB ever, and to think, I was out to buy a CLS, came home with this hot rod. Sorry I'm rambling.
Old Dec 16, 2015 | 07:47 PM
  #67
Gugie1's Avatar
2015 AMG C63S Edition 1, 2004 Ferrari 360 Spider, 1987 Swift DB2
Check Engine Light
I had the same problem at less than 5000 miles. First time engine light eventually went off. Second time car went into limp mode. Dealer reported cylinder faults in all cylinders. Escalated to MB yet it is reported that there is not yet a software fix. And, because the problem corrected itself after a restart, there was not enough data to determine the problem. Also in the shop when shocks locked in sport plus mode. Supposedly fixed the problem, yet had the same issue again two days after coming out of the shop. Again, issue resolves after turning the car off and then on. MB has not offered to do anything other than to say nothing is wrong with the car (or everything has been fixed). Not even an apology by Mercedes Benz for the fact my car has been out of service 3 times in the last month.
Old Jan 3, 2016 | 06:43 PM
  #68
Hendra Wijaya's Avatar
2015 c63s w205
my c63s get fuel pump replace after 2k miles and rear camera wont open at 1k miles.
i hope in the 3k mark nothing gonna happen
Old Jan 3, 2016 | 08:40 PM
  #69
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
4000kms and no major issues yet
Old Aug 28, 2017 | 02:00 PM
  #70
Cavemanal's Avatar
2016 amg c63s
2016 c63s in shop for over 5 weeks!
18 months old. And 18000 miles. Check engine light appears. Dealer has replaced 2 cylinders. And now replacing turbo charger! And still in the shop after 5 weeks. As they r still working on it! Is this a lemon? It has shifted poorly since I got the car and very uncomfortable stiff ride. Even in comfort mode. Am disgusted with this car. Any suggestions?
Old Aug 29, 2017 | 12:05 AM
  #71
RDOCA's Avatar
2016 C63S Sedan
The ride is what it is but the rest sucks. How many times in for the same complaint as maybe it qualifies for a lemon law action in your state??
Old Aug 29, 2017 | 12:45 AM
  #72
Cavemanal's Avatar
2016 amg c63s
they just texted me that they replaced the turbocharger... but the car is still having problems.. contacted Mercedes of usa... they said they will look into it.. as a possible lemon.. will let u know what ends up happening!
