C63/C63S AMG
Rear Axle Oil Change No Longer Needed at 2K?
Old 03-24-2016, 09:51 AM
  #76
longbow0404's Avatar
2019 E63s
Here is a picture of the diff drain plug
Old 03-24-2016, 04:23 PM
  #77
Pit-Pony's Avatar
2015 C63S E1 (sold 2012 C63 AMG Sedan (Premium & APX)) & 09 C300 Sport 4Matic
CT-AMG, where did you see the recall and what model/year cars?
Old 03-24-2016, 04:43 PM
  #78
CT-AMG's Avatar
AMG C63S
I have a 2016 C63s and another forum member went to my dealer and got almost the exact same car. Yesterday he was supposed to go and pick it up but, the Dealer called him and said he couldn't release the car until they completed the recall campaign. When asked what it was he said it was the differential plug.
So, I am assuming it is all 2016 C63s models.
Old 03-24-2016, 10:01 PM
  #79
jeremyf0923's Avatar
2021 GLE53; 2018 Audi R8 V10 Plus
Just looked on mbusa site and stated no recalls for my VIN - January build. Any further info u can share?
https://www.mbusa.com/mercedes/recall
Old 03-24-2016, 10:15 PM
  #80
CT-AMG's Avatar
AMG C63S
The member who had it performed was Jojipoji. PM him or ask him to respond. I am scheduled for mine on April 19th. I will let you know more then..
Old 03-24-2016, 11:12 PM
  #81
Jojipoji's Avatar
C63s
Hey that's me! I bought the car yesterday and got delayed by 2 hours. 1. Because they can't deliver a car with an open recall (as stated above-differential plug) and 2. They found a hairline crack on the rear brake lens.
Dealer told me I have to do the diff fluid at 1800 miles even with the e-diff.
Old 03-27-2016, 07:43 AM
  #82
theclutch's Avatar
C8, FF, C63S, 911 C4S, GTI, E350, Boxster S, 355, Esprit S4, Vantage, S5, Z4, M3, Miata, A4, 325is
Bad news folks. The differential plug that they are talking about is not the drain plug. It's actually an electronic plug that has a seal on it. Or supposed to have a seal. That's what they're supposed to check for. I just got my fluid replaced on Friday. And they showed me the recall information. It cost me around $250. I'll scan the information for everyone to see. My biggest concern now is they charged me for two liters of fluid. And I'm not sure whether they put in the right fluid and 2 is it the right amount? Another poster for charged for 3. I don't see from any manual how much fluid LSD is supposed to take in. And I found nowhere does it state what kind of fluid it is either....annoying.
Old 03-27-2016, 12:54 PM
  #83
RDOCA's Avatar
2016 C63S Sedan
it should be 3 L of 75w140-
Part # 001-989-52-03-10
Old 03-29-2016, 02:36 PM
  #84
theclutch's Avatar
Ok, so here is the "summary" description of the Recall. Note it states "LOCK DIFF PLUG". Not much there, right? The reality of it is, it's actually a "CONNECTOR" plug vs. an oil plug. Here's the description of the Recall #2016020009
WHERE does it say that it must be 3 liters? This has me worried since my invoice says they only used 2 liters.
Any help on an official source?
Attached Thumbnails Rear Axle Oil Change No Longer Needed at 2K?-capture.png   Rear Axle Oil Change No Longer Needed at 2K?-wp_20160329_14_13_41_pro-1.jpg   Rear Axle Oil Change No Longer Needed at 2K?-wp_20160329_14_33_28_pro-1.jpg
Old 03-29-2016, 02:55 PM
  #85
Dasani's Avatar
2020 C63s Coupe, 2016 C63s Sedan
I'll guess you don't want to know that my paperworks states 4 liters used when the rear diff was serviced? Mine really does say 4...
Old 03-29-2016, 03:13 PM
  #86
My2010M3's Avatar
2010 M3 E90- sold, 2013 c63 sedan p31 eurocharghed V5, 2016 c63 s 2019 F Pace SVR 2021 E63S
I had my differential service done today. I was a bit ahead on mileage, right at 1800. But I might drive it back north and wanted to get this done. SA checked for open recalls or campaign and none were found. At least, my vin. #. Mine is a 2016. Dealership was slammed, but they got me in and back on the road in a short while. All seemed to go seamlessly, hope there no further issues. Other than rattles, the car has run strong. Rattles seem to be road, temp, and humidity sensitive. As I don't always have them. When I do, just push the loud peddle and I make them go away. My paperwork showed 3 liters by the way.
Old 03-29-2016, 08:05 PM
  #87
Sbpsu354's Avatar
2016 C63 S
Mine shows 3 as well
Old 04-14-2016, 05:22 PM
  #88
Geno40's Avatar
2016 C63 S
Picked up mine after 2 days of waiting for parts to arrive. Here is the thing I wasn't charged for rear axle oil change, service advisor said it was covered by MB and was necessary service since MB puts different oil from the factory for break in process. Had to pay for engine oil/filter change only, differential plug had to be replaced as well per recall as well as my rocker panel that start coming off on the passenger side.
Old 04-14-2016, 05:26 PM
  #89
CT-AMG's Avatar
AMG C63S
I just did my 1850 mile rear diff oil change and I was astounded when I received my bill. $386 to change the oil. 3 Quarts for $96 and rest in labor and tax. 2 Hours labor, man was I pissed..
Old 04-14-2016, 05:30 PM
  #90
Geno40's Avatar
2016 C63 S
Makes me think that they could have change only axle oil and no engine oil since it's not mandatory but I insisted anyway. Description of work is on the receipt and all is there, do you think they could cut the corners? Its a big dealer btw.
Old 04-14-2016, 06:20 PM
  #91
theclutch's Avatar
Can you tell me how many quarts of eLSD oil they put in? They used 2 quarts for me, but it appears 3 quarts for others.
Old 04-14-2016, 06:48 PM
  #92
RDOCA's Avatar
2016 C63S Sedan
Seems most are 3 as mine was and if they put 3 in and it did not run out maybe yours is low -if they really did put in 2. I would see the dealer soon.
Old 04-14-2016, 08:23 PM
  #93
Jojipoji's Avatar
C63s
Must be the greenwich tax! I quoted 1 hr of labor from both hartford and north haven stealerships...
Old 04-14-2016, 11:39 PM
  #94
cyberorth's Avatar
2018 AMG GTR, 2017 GLS63, 2019 C63s
Guys the same happened back in 2009 when the W204 C63 got a LSD and the 1850 mile sticker. Some dealers charged for it, some did it as warranty and some as prepaid ( not a mbusa thing then) nonetheless all variations were due to lack of understanding and proper communication. After a couple years everybody was on the same page and as far as I can remember it was only covered w prepaid service.
Dealers that cover it but don't get paid for it from mbusa charge so much for other things that break even.
Old 04-15-2016, 09:55 AM
  #95
I just called my dealership here in ATL and was quoted $120 for the service (1 hr 15 mins). This price may not include the cost for oil. I'll let y'all know next week - having it done on Wednesday.
Old 04-15-2016, 10:09 AM
  #96
Geno40's Avatar
2016 C63 S
My receipt didn't say anything about quantity of oil, just parts numbers and yes plug has to be cured on some kind of adhesive all done under warranty.
All I paid is for oil change which costed me $160.
Old 04-15-2016, 10:52 AM
  #97
RDOCA's Avatar
2016 C63S Sedan
That's labor, and in addition they will chg. about $75 for lube and $50 for 2 drain and refill plugs.
Old 04-15-2016, 10:55 AM
  #98
That will probably end up being true...but would be f'd up considering I asked for a FULL cost for the service, not just the labor cost.
Old 04-19-2016, 03:53 PM
  #99
theclutch's Avatar
Ha! So it seems that my dealer is a lot more "efficient" than everyone else's is.... Most of you got 3 liters to fill the eLSD. Mine used 2 liters - which made me think they UNDER filled it. It turns out from MBUSA via the AMG Lounge that the eLSD capacity is only 1.2 liters... so go figure. See below.
Old 04-19-2016, 04:02 PM
  #100
Thanks for info. Am looking forward to my visit to the dealership tomorrow morning.
Quick Reply: Rear Axle Oil Change No Longer Needed at 2K?
