C63/C63S AMG
AMG C63s Tire Size increase
Old Feb 27, 2017 | 08:55 PM
  #126
CT-AMG's Avatar
AMG C63S
I blame the guys on these forums for me busting up both of my front rims. WHY? Because I followed the leader and lowered the tire pressure to get more rubber on the road and by doing so the tire didnt have enough rebound to save my rim. Now that I have larger tires I fill those suckers up high so no rim dents. Thats my solution over a 35 tire
Old Feb 28, 2017 | 12:42 AM
  #127
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
How low was your tire pressure? 36/33?
Old Feb 28, 2017 | 05:49 AM
  #128
CT-AMG's Avatar
AMG C63S
Yes, 36/33 and now its over 40 but, I haven't checked today
Old Mar 14, 2017 | 10:07 AM
  #129
Vertice's Avatar
2016 C63S AMG
After a little over 6k miles, my stock Dunlop Sport Maxx RT's are ready to kick the bucket. For the C63S Sedan, what's the consensus for going wider and properly matching the fronts?
I'd like to go to 275 rears, but what thickness should I go with and what size should I do in the front? Can I keep the stock front size?
Also, I am running the stock 19in rims.
Thanks in advance for any input!
Old Mar 14, 2017 | 10:32 AM
  #130
CT-AMG's Avatar
AMG C63S
Vertice: I am not the tire expert but, I did plenty of research before I switched sizes. I had the factory Dunlops and they were shot at about 10k miles, around the same time I dented both front rims and needed to repair them and replace the tires.
I can't tell you the absolute maximum size but I went with 265 on front and 285 rear. I have the factory forged alloy 19" rims. I also kept the 30 profile from stock and did not go with 35's.
My reasoning was kind of primitive but, heres my thinking..
Factory profile was 30 and not 35 so I preferred to stay with the factory number. I also prefer a lower profile look and was concerned with rubbing if I changed the height from 30 to 35. So, I kept 30.
Factory profile kept a "20" differential between front and rear. 245/265. I didnt want to throw off the geometry or change it too much from factory numbers. So, I kept the same "20" differential and went with 265/285. I know that people have gone larger in rear but, I wanted to keep that factory ratio.
I can tell you that between the rubber switch and increased size, the car drives like a much different vehicle. Much much better, less wheel spin, better handling. I can only assume the MB didnt go bigger because of some EPA or MPG issues because there is no reason to have those puny factory tires that spin with the slightest throttle pressure when you can add width and have significantly better handling and acceleration.
Hope this helps..
Old Mar 14, 2017 | 10:34 AM
  #131
Vertice's Avatar
2016 C63S AMG
Hope this helps..
Awesome, thank you for the detailed response! Did you have to add any spacers with the larger tires?
Old Mar 14, 2017 | 10:43 AM
  #132
CT-AMG's Avatar
AMG C63S
No spacers at all.
Old Mar 14, 2017 | 01:57 PM
  #133
Vertice's Avatar
2016 C63S AMG
No spacers at all.
It doesn't seem Michelin makes the PSS or the new PS 4S in 285/30/19, should I go to 285/35/19?
Attached Thumbnails AMG C63s Tire Size increase-screen-shot-2017-03-14-1.56.15-pm.png
Old Mar 14, 2017 | 02:48 PM
  #134
blaferty's Avatar
2015 C63S
fwiw, stock 19" Dunlops are 35 not 30
Old Mar 14, 2017 | 03:04 PM
  #135
RDOCA's Avatar
2016 C63S Sedan
+1
Old Mar 14, 2017 | 03:30 PM
  #136
RDOCA's Avatar
2016 C63S Sedan
I am researching this also as I will need tires soon and will go to the new PS 4S and probably go with a 255/35/19 in front on stock rims.
My thinking on this is that Tire rack charts say the widest tire on a 8 1/2 in rim is a 255. It is .2 inch larger dia. This doesn't mean you can't fit a larger tire in the wheel well but it will not ride flat on ground with proper air pressure. Others have done it but that doesn't mean it is the correct size.
On the rear I am leaning toward the 285/35/19 as they also show it is the largest tire for a 9 1/2 inch rim. Several reasons for this 1). .6 inch larger dia. and will fill the wheel well a little more. 2). It keeps the 35 aspect ratio as this car rides a little rough as it is and I don't want to go with a 30 as it would ride worse even if it was available. 3). More rubber for some better traction we all want.
Maybe the best is to go with a 275/35/19 but it would not have the traction the 285 would.
I know this goes up 1 size on front and 2 on rear but I don't think it will be a problem except on track and maybe not there.
Speedo will show 80 mph when you are actually going 81.8 so watch your speed (2.3%)
Remember these tires are for areas that don't dip below 40 deg F
Old Mar 15, 2017 | 01:54 AM
  #137
MarkC63's Avatar
2016 C63 Wagon
Does anyone know if the speedo read from the front wheels or the back wheels?
Old Mar 15, 2017 | 08:14 AM
  #138
CT-AMG's Avatar
AMG C63S
My bad guys.. My tires are 35's and not 30's. I reversed the numbers but, my opinion hasn't changed.
I kept the 35 profile because thats what MB had as stock, not 30's...
Old Mar 15, 2017 | 09:38 AM
  #139
Dasani's Avatar
2020 C63s Coupe, 2016 C63s Sedan
Technically, neither. It uses the transmission, which in this case is connected to the rear wheels. So, the rear tire diameter affects the speedometer.
Old Mar 15, 2017 | 09:38 PM
  #140
Alex98's Avatar
2017 C63S Coupe 2018 Ford Raptor 2017 Corvette Z06 2013 Mercedes C63 2012 Mercedes C63 BS
I'm currently running 305 SS on the rear of my coupe.
Old Mar 15, 2017 | 09:46 PM
  #141
RDO247's Avatar
C63S
Sweet, photos please.
What size wheels eels are you running?
Old Mar 17, 2017 | 06:03 PM
  #142
RDO247's Avatar
C63S
295/30/19's
Old Apr 8, 2017 | 07:37 PM
  #143
soslow's Avatar
C63S
Originally Posted by RDO247
295/30/19's
Do you have issues in comfort suspension mode? Thanks.
Old Apr 8, 2017 | 08:20 PM
  #144
RDO247's Avatar
C63S
No issues in comfort mode, however, I'm only Drive in Sports Plus.
Old Apr 8, 2017 | 08:24 PM
  #145
soslow's Avatar
C63S
Am I right saying that you haven't tried the speed bumps in comfort? =]
Old Apr 8, 2017 | 09:04 PM
  #146
RDO247's Avatar
C63S
I'll try today and get back to u.
Old Apr 11, 2020 | 12:46 AM
  #147
ShaneN.'s Avatar
2018 e63s edition 1
Lots of back and forth in the thread, just want to double check before I order (mostly concerned about the front width)
Have a 2017 sedan. Going to probably order
Ps4s in 265/35/19 front and 285/35/19
That should give me no problems, correct? No confused traction control or anything?
Old Apr 12, 2020 | 03:15 AM
  #148
SimMB's Avatar
C63S
Originally Posted by darwin329
Hows your 295 with the stock wheels.. I was thinking of moving the stock rear wheel with 265/35/19s to the front and get 2pcs 20s ( coupe 63s) for the rears.. are they cross spoke design too..
you saying 19 front and 20s rear for sedan will work right 265 front 9.5 wide and 20s rear 285 or 295 10.5 wide
Originally Posted by Sanch
front and rear wheel off sets are different.. will not fit.
They will fit with a spacer.
Sedan rear - 9.5 J x 19 ET56
This guy is using 9.5j x 20 with a 35 offset
A 20mm spacer will take the offset from 56 to 36 for the rear wheel, which means they will fit on the front, so sedan owners just need the spacer and can buy coupe rears for a working set. (In theory)
Old Apr 13, 2020 | 07:18 PM
  #149
ShaneN.'s Avatar
2018 e63s edition 1
Anyone?
Old Apr 13, 2020 | 07:31 PM
  #150
rbohgan's Avatar
c63s sedan
Anyone?
i ran the same on my lowered sedan. no issues at all. i even ran with spacers 10mm and 15mm rear. no issues anywhere just a wicked stance.
