C63/C63S AMG
Coupe Dyno results.
Old Dec 10, 2016 | 03:12 PM
jkob5's Avatar
19 E63s
Coupe Dyno results.
I was definitely surprised. Thanks to Eurocharged houston for hosting an AMG day at their shop. Brief video to come. Car is stock with 1500 miles.
Attached Thumbnails Coupe Dyno results.-dynofull.jpg   Coupe Dyno results.-dynomax.jpg
Old Dec 10, 2016 | 03:24 PM
gofisch's Avatar
2005 C55 AMG
Are these before or after runs?
Old Dec 10, 2016 | 03:38 PM
Dthquazi's Avatar
2017 c63s
Originally Posted by gofisch
Are this before or after runs?
Before or after what? OP says stock car
Old Dec 10, 2016 | 04:01 PM
bgm130's Avatar
2016 C63S
What dyno do thy have? Dyno jet?
bgm130's Avatar
2016 C63S
And crazy these cars all really drop at 5500 rpm.
Old Dec 10, 2016 | 07:28 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
Definitely not unusual for torque to drop off at the top end with smallish turbos. The HP curve is really flat up top which looks really good, I actually recall seeing HP drop off more in the top end on other dyno charts. Is it possible there's a different ECU calibration with the coupe and sedan?
Old Dec 10, 2016 | 09:51 PM
gofisch's Avatar
2005 C55 AMG
Ack, too interested in looking at the graphs to actual read.
Old Dec 11, 2016 | 02:26 AM
jkob5's Avatar
19 E63s
Great question. Can anyone post their stock sedan dyno? I know we can't compare numbers directly, but the area under the curve can be.
Old Dec 11, 2016 | 01:26 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
nice meeting you yesterday
Old Dec 12, 2016 | 09:55 AM
msd3075's Avatar
'15 C63S
As for the higher/flatter curve in the upper RPM range, the weather in Houston when this run was done was pretty cold out (45ish degrees F) compared to other runs I've seen from Eurocharged that were done in much warmer temperatures. I'm willing to be any difference/gains over other stock runs are almost entirely down to the cold weather.
I understand these graphs should be corrected for weather conditions, but that correction is by no means perfect.
Old Dec 12, 2016 | 11:42 AM
ignomini's Avatar
MG PB, MG Midget, Triumph TR4, Morgan 4/4, Mustang, Audi R8
Just to confirm, those are at the wheel numbers right, not calculated flywheel horsepower? Allowing for the generosity of Dynojet, they're still good strong numbers.
Old Dec 12, 2016 | 01:48 PM
dlefty's Avatar
/////PRO
The turbo upgrades available out there for these cars will take care of that flat line up top on the graph for it!
Old Dec 12, 2016 | 03:40 PM
jkob5's Avatar
19 E63s
iikewise
good point, almost all other runs will be in higher temperatures
yes, wheel hp/tq
Old Dec 12, 2016 | 05:28 PM
AmexWest's Avatar
W205 C63S
Why does HP tail off at the top end? I thought HP scaled linearly with rpm?
Old Dec 12, 2016 | 05:34 PM
dlefty's Avatar
/////PRO
turbos are running out of breath up top, hence why the tuners are seeing huge gains by porting out factory turbos and installing bigger compeller wheels.
