How is the Burmester sound system?
Thanks,
JAM51
Thanks,
JAM51
I'm having to resort to playing music through my phone via Bluetooth and boosting it . I use poweramp and also my Samsung s8+ has decent inbuilt EQ which dials up the bass. The effect is pretty dramatic and the bass sounds great coming from the same speakers. it's definitely more than sufficient and while perhaps ever so slightly lacking on true low end , it is quite brilliantly otherwise.
Not sure which demographic merc thinks people who buy a c class come from but they sure could do a much better job of tweaking their offering to modern music by simply letting you boost the bass. had this same problem with the HK system on the gla 45. while the sub in the back had enough power to vibrate your teeth , having to screw around with only unlocking that through a Bluetooth device isn't ideal
Treble -7
Mids -10
Bass +10
This is the equivalent of Treble +3, Mids 0, Bass +10 on a regular system (which is usually where I'd end up).
I agree, there should be a higher maximum volume and definitely more bass. But I make do with the above settings and it definitely helps a lot compared to Bass +10 alone.
I don't feel like dealing with huge boxes in the trunk anymore, let alone having some custom fabricated thing done just to make this sound decent. I'm kind of annoyed. Looking at the Rockford Fosgate P-300 powered subs, either in 10 or 12" right now but still not happy since I don't wan't a stupid speaker box taking up half of my trunk.
Seriously, this Burmeister sound system sucks ***.
Maybe one day a solution will be made for this vehicle...
Not sure if you can tell the difference on youtube but when i quickly shot and edited the video this morning, there is a marked difference in bass. (Headphones needed) Uploaded to youtube here: https://www.youtube.com/watch?v=caRE...ature=youtu.be
Not sure if you can tell the difference on youtube but when i quickly shot and edited the video this morning, there is a marked difference in bass. (Headphones needed) Uploaded to youtube here: https://www.youtube.com/watch?v=caREO9pd8wg&feature=youtu.be
- Added a JL Audio 8 channel amp to overpower the existing system and run the sub: http://www.jlaudio.ca/xd800-8v2-car-...plifiers-98259
- Change door speakers to a 1" tweeter and 4" mid from Focal: https://www.focal.com/en/car-audio/c...-kits/es-100-k
- Added crossovers to both sides in the front to separate the speakers
- Added an 8" JL MicroSub to the trunk: http://www.jlaudio.ca/car-audio-subw...stems-microsub
On the average, settings need to be down a bit on the highs/mids -2/-2 up on the bass 6-7, I find I do adjust these a lot depending on what I'm listening to.
SO MUCH BETTER. Crisp highs', some nice bass and WAYYY more volume. It went from 74 dB to 96 dB. A huge difference.
Another option is to add an OEM digital signal processor, I just asked about this today to potentially help balance out the system http://www.jlaudio.ca/fix-86-car-aud...m-tuning-98103
On deck is moving to a 10" sub from the 8", just to give it that little bit more.
Would love to hear your setup sometime!
