Worried new C63 owner desperately needs help!
I am would really appreciate if someone could please help me with this.
I just picked up my C63 yesterday brand new (23 miles on the clock). I was really disappointed to find a number of small issues with the car. There is a stone chip and few scratches on the skirting which dealer is sending a smart repairer around to fix tomorrow. There are also wrinkles on the leather seat which look like it was caused by too many people getting in and out of the car.
The other thing I really worry about is the engine itself. Lifting up the bonnet, I can see the two turbo feeds look rusty (please see picture below). I really worry about this because the pictures of engines from other used C63 and C63s (W205) on Mercedes website don't even look rusty like that, mine is brand new. So if you currently own a C63, could you please confirm whether this is normal and yours also look like that when you picked up the car from brand new?
Also what do you think I should do about the minor damages above? apart from getting dealer to do the repair.
Many thanks in advance!
Getting the dealer to repair is really your only option with the other damages. . . Just make sure they don't send a sales guy outside with a friggin touch up pen or anything. This one of the main reasons is why 5 years ago I started ordering all my cars to my own spec so there is no question of what happened to them before they arrive for me (and also because European Delivery is awesome).
I'll inspect it at the lot and take it off their hands as it came from the factory and drive it to my trusted detailer for a new car treatment.
is rust bad immediately? No, in most cases like this an oxidative later can actually help to arrest further damage (or leaching of iron from the body of the cast iron piece.) So yes it isn’t pretty, but mechanically the part should still be okay. When you get very severe oxidation is when you get severe loss in mechanical properties.
as for the leather, unfortunately it’s happening soon, but get Used to leather (organic material) losing its rigidity over time. You could always put on a super styling synthetic cheetah print seat cover (kidding).
But, hopefully it gives you peace of mind knowing that all turbos typically have this issue. High heat, most likely not perfectly dry climate, and highly corrosive metal, rust even like that can happen in hours. And if you have a cast iron skillet, you can run the experiment, visible rusting can happen in minutes. Maybe they will see that and replace it though if you bug them enough?
Part of the AMG experience is to have that lovely engine to look at, at least complain and return the car if the rust isn't gone after a few drives.
I think the quality of the leather is questionable on the newer cars, MB should at least offer synthetic as an option. Lower spec cars with synthetic leather hold up so much better than nappa cars, mine looked tired after a month of use. We really should stop with leather all together, much better synthetic and cruelty free materials available.
Rust on turbine housing?
Where was your car built ? Germany? It took a cruise on a cargo ship and sniffed salty vapors.
Your car is not days old but months and the ocean voyage takes weeks.
Then it sits in the harbor free trade zone, sniffing more salt, till the dealer trucks come.
Cast iron rust protects the cast iron.
When you are out of the break in and can give the car some go, that housing won't heat up to red, but to yellow. The rust will turn to a dark crust which is how all turbine housings look like.
The seat sounds like an issue you should have noticed before you took delivery. Car was probably in the showroom and had people in and out of it despite not being driven. Happens to cars at the auto show. Try a leather conditioner or just don't worry about it. That little bit of wrinkling is hardly cause for concern, and a replacement seat cover as suggested above will never fit as tight as the original one, if you're not happy with this you won't be happy if they replace the cover.
I understand these are expensive cars, but boy you guys get up in arms about some small issues. A quick inspection before you bought the car would have solved all of this.
I had the driver’s seat bolster replaced under warranty on my old W204 C63 and it was perfect, no problems whatsoever.
I thought about looking at the engine when picking the car up but I just couldn’t wait to drive it away, I certainly wouldn’t have taken it had I seen the rust.
