C63/C63S AMG
c63s owners jerky 3-4 shift in manual?
Old Mar 26, 2017 | 07:34 PM
Bespoke88's Avatar
bmw
When I am in driving in sport + mode I notice in manual shifting mode on it has a slight jerk almost always going from 3rd gear to 4.
Anyone else experience this or should I have it look at it?
It won't do it if I drive it slightly harder as in gas slightly more, but otherwise I almost always feel it.
Doesn't happen in any other gear either.
Old Mar 26, 2017 | 08:51 PM
jkob5's Avatar
19 E63s
I have it as well. Mercedes looked at it nothing they could do
Old Mar 26, 2017 | 09:03 PM
Bespoke88's Avatar
bmw
is it only 3rd gear to 4?
Old Mar 26, 2017 | 11:07 PM
Alex98's Avatar
2017 C63S Coupe 2018 Ford Raptor 2017 Corvette Z06 2013 Mercedes C63 2012 Mercedes C63 BS
My car personally use to do this, almost like a lunging action but after the run in and stopping by the dealer it no longer does it. I don't know if it needed to be ran in more or dealer adjusted the clutch packs. But at 6k miles, I haven't had it happen to me since basically brand new.
Old Mar 27, 2017 | 12:11 AM
MUZZIE's Avatar
2017 AMG C63S Coupe , Range Rover Sport
yep mine does it too...3rd to 4th ...only have 1500klm on it ...hopefully it will get better with more klms....
Old Mar 27, 2017 | 05:57 AM
dviolagis's Avatar
2018 GLC 63
Shifting from 3rd to 4th.
I had the same problem. Take car to your dealership and ask about PTSS Case #89001. AMG engineers discovered an issue with certain vin numbers. Car runs fine now.
Old Mar 28, 2017 | 01:37 PM
Bespoke88's Avatar
bmw
Thanks I will do it... did you only have this problem during 3-4 gear change or all gears?
Old Mar 28, 2017 | 02:14 PM
dviolagis's Avatar
2018 GLC 63
Jerky 3-4 shift in manual
Just 3rd to 4th in manual mode
Old Mar 29, 2017 | 05:53 AM
Uga Uga's Avatar
2021 C63S coupe
Thanks for the info.
I just hit the 1K mark and tried the paddles.
Same jerk from 3rd to 4th. I will have it looked at when I go for my differential oil change.
Old Mar 29, 2017 | 09:44 PM
Bespoke88's Avatar
bmw
in all modes or just sport +
Old Mar 30, 2017 | 03:01 AM
Unicorn_'s Avatar
AMG C63S
Had the same problem. Just a software thing, required the workshop undertaking new adaptations for 3rd and 4th gear. Took them about a day to sort and fix.
Old Apr 11, 2017 | 04:30 AM
NARCOGP's Avatar
2017 C63s Coupe
I really think this is not a big issue guys, it only happens in sport + and race. If you are changing gears early in these modes then you get the jerk movement. If you change at higher revs the change is smooth.
Old Apr 12, 2017 | 07:50 PM
1 SIC DR's Avatar
2017 Benz C63S Coupe
Same for me, just in sport + mode, brand new car 100 miles....
Going to give it a few weeks and might bring it in...
Thoughts ? My first auto.... always driven stick....
Marco
Old Apr 12, 2017 | 11:05 PM
lenk's Avatar
"Unicorn" is correct, just got my car back today after reporting the same issue, and they followed the same process as indicated in "Unicorn's" post and the car is significantly better now. They dealership must drive the car at least twenty miles after doing the software upgrade for the adaption to take effect.
Old Jun 25, 2017 | 05:49 AM
ninjatim's Avatar
c63s 2017
Just started using my care in race mode to use paddles today (only at about the 1000km mark) and 3-4th gear change is jerky. Tried at low and high revs and same jerky motion.
Might take it to dealer if it's still happening after 2000km. Hopefully the car warms up to it.
