C63/C63S AMG
c63 sedan tire questions
Old Jun 10, 2017 | 01:25 AM
SJY's Avatar
SJY
c63s sedan
Hi everyone, I'm thinking of putting Pilot Sports 4s (front 255/Rear 275) on my c63 sedan. I'm not Familiar with the aspect ratio, should I go with 30 or stay with 35? and I'm running with the stock 19 cross spoke wheel. thanksss!
Old Jun 10, 2017 | 07:25 AM
ezatnova's Avatar
2016 C63S
If you google tire calculator there are some good pages where they overlay different tire sizes and show you the % variance.
I just did this the other day and I believe with those minor increases in widths, it was closest by far to stay with the stock aspect ratios rather than the next one down.
Old Jun 11, 2017 | 09:28 AM
msd3075's Avatar
'15 C63S
You will be fine with a 255/275 setup on the stock sedan wheels.
Stick with the 35 aspect ratio. Difference to stock height of 245/265 size setup is negligible.
Old Jun 11, 2017 | 11:04 AM
SJY's Avatar
SJY
c63s sedan
thanks mann
Old Jun 13, 2017 | 12:42 PM
Chadbates's Avatar
2016 C63
Hi guys, apologies I'm new to this site and just stumbled across this thread.
i recently purchased a 2016 C63 and am loving the car. The only problem I have is a massive traction loss in the rear on hard acceleration from pull off. Does the increased size in rear Tyres help with this or is there something else I can do to improve it?
i currently have pilot super sports on the rear.
Frastrating not being able to put down some decent power on pull off as it just spins. Going into 3rd I get decent traction again and that's when the real power kicks in.
Old Jun 14, 2017 | 12:40 AM
skim7x's Avatar
Mercedes-Benz E63s AMG
Wider tires will help a little bit. Also, going to a stickier compound tire or one with less tread will get you more grip. Beyond that, you really just have to learn how to restrain yourself as you're accelerating. You really have to be gradual in power delivery in the lower gears and then once you get to a certain RPM threshold you can finally floor it. It's not an easy thing.
Old Jun 14, 2017 | 01:37 AM
Chadbates's Avatar
2016 C63
Thanks for the feedback.
Im going to try the wider tires and see. Even if I accelerate from second gear it spins for quite a while before it changes to third and only then do I start getting traction ( can't believe mercedes dident make the c63 four wheel drive ) I also have a cla45 and that is amazing 0-100kmh. I actually think it will be quicker than the 63 because of the traction loss.
Old Jun 14, 2017 | 08:48 AM
milan25's Avatar
C63 s Edition 1 Sedan
The C63 will never be all wheel drive lol, but I have 285/35 on my sedan
Old Jun 14, 2017 | 10:24 AM
Chadbates's Avatar
2016 C63
Thanks Milan, what size are you running in front? And what brand do you have on the rear in 285?
Old Jun 14, 2017 | 11:04 AM
skim7x's Avatar
How much of a difference did the 285's make for you, milan?
Old Jun 14, 2017 | 04:23 PM
milan25's Avatar
I have Continental Extreme Contact Sport. the front are 265/35
they are identical to PSS, even better in comfort.
Old Jun 14, 2017 | 07:28 PM
skim7x's Avatar
Are you experiencing improved reaction in the rear?
Old Jun 14, 2017 | 08:36 PM
milan25's Avatar
YES! it grips a lot more than it did before. I have already put 1k miles and no difference yet. Obviously if you have it on sport and floor it, traction will be lost but it's a lot better
Old Jun 15, 2017 | 01:24 AM
Chadbates's Avatar
2016 C63
Thanks, will give that a try.
With the pilot super sports on mine , if I floor it in comfort it spins like mad!
Old Jun 15, 2017 | 08:47 AM
msd3075's Avatar
'15 C63S
I've read a lot of great things about the new Continental ExtremeContact Sport tires. Almost every review says they have 99% of the drip grip and stability of the Michelin PSS but significantly better wet traction, hydroplaning resistance, and comfort/road noise. Not to mention they are noticeable cheaper than the Michelin tires (especially the new PS4). If your car is your daily driver, these are a no-brainer when compared to the Michelins.
More likely than not these will be the next set that goes on my car.
Old Jun 15, 2017 | 10:00 AM
milan25's Avatar
They are very good. Also very affordable because tires wear out in 15k miles
Old Jun 16, 2017 | 12:07 AM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Only adjustment OEM on the rear (or front) is Toe/directional adjustment. No Camber to change tire contact angle.
We saw the need therefore to design, manufacture and reinstate from the early ‘90’s kits that provide “precise” adjustment (on car under load direct on alignment rack). Also replacing the 4 front and 4 rear highest wearing suspension bushings at the same time. Result is no more ongoing trips to dealers or alignment shops or constantly changing tire brands. Fixing it right…. the 1st time!
Precise adjustability for day to day commuting encountering high cambered roads, altered height through lowering, load carrying or suspension sag, fitting wide profile tires, curb knock damage.
Camber adjustment to reduce costly, premature edge tire wear, improve traction and track days – increase front Camber to reduce under steer allowing to go deeper into the corners with improved traction/braking response. Fine tune rear Camber also for maximum traction.
Front Caster to correctly resolve steering pull and improve brake and steering response.
The front bushings are 2 axis/self aligning but without the oil and air voids of OEM. Result is noticeably improved brake and steering response. No modifications to fit – come with instructions and extraction/insertion tubes.
Rear kits include additional Toe adjustment to compensate for the new Camber facility. Comes with bush extraction tool allowing the Camber bushes to be installed on vehicle.
Also manufactured for the rear suspension is a full set of 12 replacement bushings for the 6 multi link arms. Providing significant improvement to rear end stability. Less flex/twitch, increased traction especially when applying power lane changing/overtaking.
W205
Front Camber and Caster
C400/C450/C43/S63 AMG 4matic #503216K $480
C63/S, S63/S65 AMG #503316K $480
Rear Camber (and extra Toe) #502226K $480
Rear multilink arms performance bush kit #502628K $480
Delivery $30 one kit or $50 front and rear (average delivery time is 3 to 4 days). We accept Visa, MasterCard or PayPal.
c63 sedan tire questions-502216-cover.jpg c63 sedan tire questions-502226-cover.jpg c63 sedan tire questions-501526-2-j-cover.jpg
Old Jun 16, 2017 | 02:02 AM
Guilty's Avatar
'16 C63-S
W205
Attachment 356984 Attachment 356985 Attachment 356986
Can you even try to be relevant? Jeez, doing business with you must be painful.
Old Jun 17, 2017 | 05:59 AM
RobboAMG's Avatar
2015 C63s AMG wagon
Have you tried lower tyre pressure like 32 psi ? Helps a bit.
I'm putting contisport 6, 275/35/19 on for a bit extra rubber, will see how that goes
Old Jun 17, 2017 | 06:10 AM
SJY's Avatar
SJY
c63s sedan
do you guys think if there be any problem if i go 255f/275r and 15mm spacer all around with stock cross spoke rim?
Old Jun 17, 2017 | 12:20 PM
milan25's Avatar
no i think you will be almost perfect,
Old Jun 17, 2017 | 12:55 PM
SJY's Avatar
SJY
c63s sedan
thanks, milan!what setup are u running?
Old Jun 17, 2017 | 01:55 PM
milan25's Avatar
265 35 front
285 35 rear
there is just a small gap and I think that extra 5mm will make it flush with the body panel.
Old Jun 17, 2017 | 03:09 PM
xxxPaulxxx's Avatar
2020 AMG GT C Roadster
I drive 265 30 19 and 295 30 19 Conti Sport Contact 6.. Got a lot more traction than the 245 & 265 Michelin.
Old Jun 17, 2017 | 06:40 PM
RobboAMG's Avatar
2015 C63s AMG wagon
Assume you must be running wider rims then? 10.5" at the rear ?
