C63/C63S AMG
Air Intake Options
Old 01-28-2020, 12:58 PM
  #326
blowoff's Avatar
S205 C63s
Whatever ! The JB4 does not lie.
Old 01-28-2020, 01:10 PM
  #327
PayKoHan's Avatar
AMG C63S T-Model
lol, ok 🤦🏽‍♂️
Old 01-29-2020, 01:56 PM
  #328
Muski_C63's Avatar
Mercedes C63
@blowoff Maybe your JB4 is wrong....Motortrend quotes a '15 non S at 16 psi and the S version at 17.4. : https://www.motortrend.com/cars/merc...3-first-drive/
Not sure how we even got on this topic on an air intake thread
Old 01-29-2020, 02:17 PM
  #329
blowoff's Avatar
S205 C63s
Nothing wrong with my JB4.
Head over to the Burger Motor Sports forum https://www.n54tech.com/forums/forumdisplay.php?f=38
and check out all the peoples logs. Look at the table within the log ecu psi there are 2 of these for both turbos and you will see 9psi under full load.
My logs are around 12psi due to ecu tune. https://www.n54tech.com/forums/showthread.php?t=59916
The psi can spike when coming off full throttle due to the small blow off valves. Have seen up to 17psi but this is a spike only. The logs will show it all.
Here are the map details for the JB4
Map Guide as of V2 Firmware:
Map 0: Stock operation, JB4 disabled
Map 1: Default performance map, 4psi peak over stock, taper to redline
Map 2: 5psi peak over stock, taper to redline
Map 3: 6psi peak over stock, less taper to redline, suggested for E85 mixture or octane booster
Map 4: 6.5psi peak boost request over stock, less taper to redline, requires unleaded racing fuel or E85 mixture
Map 5: 7psi peak request over stock, less taper to redline, requires unleaded racing fuel or E85 mixture
Map 6: Custom additive boost profile, boost request over stock
Map 7: Progressive WMI (water/meth) mapping based on boost additive setting and WMI flow
Map 8: Low boost VALET / Safety map
to get your heads around how the JB4 works have a look at this
https://www.n54tech.com/forums/showthread.php?t=55094
Old 01-29-2020, 03:22 PM
  #330
PayKoHan's Avatar
AMG C63S T-Model
The low boost would atleast explain the 60-130 time with jb4
for all ohters: the mechanic from mercedes told me today, the boost is 1,2bar.
Old 01-29-2020, 03:51 PM
  #331
blowoff's Avatar
S205 C63s
Boost pressure from the turbo to the engine has loss due to mechanical and friction losses in the gears, bearings, pipes, exhaust, intake etc. Why do you think a engine with free flowing intake and exhaust will make more power on the same boost.... less loss and restriction.
Yes the turbos might make 17psi but what the actual engine sees is 9psi. Ask any good tuner. On average if the engine is seeing 20psi the inside of the turbo would be seeing 36psi up depending on a lot of factors with some listed above..
Location of the boost sensor within the system has a lot to do with the reading too.
With the JB4 on map 0 it is NOT adding any additional boost, it is fully disengaged so at the boost sensor it's seeing 9psi on wot, on map 5 it adds 7psi so at the sensor it will read 16psi, confirmed by the logs.
Hope this explains things.....
Old 01-29-2020, 05:16 PM
  #332
BMS
Former Vendor of MBWorld
BMS's Avatar
2018 C63 Sedan
Not been following.. What is the question? Boost readings on map0 seem lower than expected on a flash map?
Old 01-29-2020, 05:19 PM
  #333
PayKoHan's Avatar
AMG C63S T-Model
god...no one talks about this boost. you are jb4 fanboy and activ in n54tech forum, so you should know it.
if these BMW guys Talking about Maps or bigger turbos, they never would say, "im runing around 12psi" their numbers are much higher, around 20-30psi and higher...no matter 35i,m3 oder m5 engine...
Old 01-29-2020, 05:33 PM
  #334
PayKoHan's Avatar
AMG C63S T-Model
same when you watch YouTube and read mods list, you will Always find, the boost where i did say...the turbo boost. what a unnecessary discussion
Old 01-29-2020, 05:51 PM
  #335
PayKoHan's Avatar
AMG C63S T-Model
how much boost have the amg c63s, but question is solved.
Old 12-15-2020, 08:55 PM
  #336
Erik Apple's Avatar
2018 C63
I really like the way the Zac motorsports intake looks. Especially because you can keep the amg builder plaque
Can anyone explain to me how the BMS intake is different from the Zac?
Old 12-15-2020, 10:26 PM
  #337
///Bruce's Avatar
2020 C63S Coupe & 2018 Macan Turbo
Yeah. They’re spelled different....
Old 12-16-2020, 12:00 AM
  #338
Erik Apple's Avatar
2018 C63
Thank god you're here
Old 12-16-2020, 12:50 AM
  #339
VictoryRoadPerformance's Avatar
E55 C63
if youll hold off about 2 weeks we have a kit coming in the ~$600 price range which will include new inlet tubes, larger piping than BMS, Larger filters than ZAC, and boxed heatshields. We are just waiting for a custom coupler.
Old 12-16-2020, 02:53 AM
  #340
RDO247's Avatar
C63S
Any Photos?
Old 12-16-2020, 01:12 PM
  #341
E55 C63
Originally Posted by RDO247
Any Photos?
check our IG, @vrpspeed
Old 12-16-2020, 01:31 PM
  #342
Erik Apple's Avatar
2018 C63
im not in a giant hurry. Ill check your IG
What about the amg builder plaque?
Old 12-16-2020, 02:35 PM
  #343
Drisso88's Avatar
Current: 2017 C63S Prior: 2016 CLA45, 2015 Evo X Final Edition
I'm on your IG page, and the only intake I see for the M177 is the BMS intake.... what am I missing here?
Old 12-16-2020, 03:07 PM
  #344
Erik Apple's Avatar
2018 C63
Originally Posted by Muski_C63
Modalworks is currently taking pre-orders if you go to his website - just placed mine.
I like his design as it incorporates a heat shield while still utilizing the stock "ram" intake tube to reach the filters
I just looked at this. I like it alot
ModalWorks (12-16-2020)
Old 12-16-2020, 03:18 PM
  #345
Sea63s's Avatar
C63s AMG
It's way down there, look for post from Nov 6th.
Old 12-16-2020, 06:55 PM
  #346
E55 C63
This was just a test fit of our U tubes, But we have heat shields (waiting for ceramic coating), and inlet tubes, with custom adapters for both stock and Aftermarket intakes, We will have a CF option aswell as aluminum, also you will be able to use any filter you want with a 3" inlet with our custom sensor bungs, Just drill a hole and pop our bung in. We will offer heat shielded and unshielded options. We sampled the inlet tubes on an IG story, once they are wrapped up we will make a more formal post. We have a slew of new M177 products, We will get the intakes on the dyno asap once the heat shields show up!
Old 12-16-2020, 08:35 PM
  #347
Rochviper's Avatar
2017 C63S AMG Coupe
I'll apologize up front. I'm sure these will perform. But they are just like the BMS units - ugly. My opinion and I know what they say about opinions.
Old 12-16-2020, 09:29 PM
  #348
Sea63s's Avatar
C63s AMG
Haha I sort of see your point about VRP's, I was actually hoping I would look similar to BMS.
I personally do not mind the look of BMS intake, looks very nice to me, I would have loved if 1. it had a flat indented spot for engine name builder plate, and 2. did not have BMS on the heatshield.
Old 12-16-2020, 09:32 PM
  #349
mjcw77's Avatar
2016 C63s Estate Edition 1
Found these on Instagram
here's my 2 cents worth... I've got the Zac Intakes. Look cool, sound cool but do they make any real difference to HP. No. Ive dynoed them and have results before and after. Nothing. For $2k the hassle I went through in fitting them was a royal pain in the ***. Gave feedback to Greg on fitment only to be told I have no idea and he is the best on the market and everyone copies him blah blah blah.
Now, if I was bleeding money, I would go the Eventuri ones: https://www.scuderia-autoart.com/p/e...VE-C63S-CF-INT
but **** me $4.8k AUD. Better results paying for good downpipes and having them ceramic coated and ECU/TCU tune.
at the end of the day, I totally agree that breathing nice cooler air into the turbos is the way to go but all the ones on the market currently, which all copy each other, except Eventuri, make no real noticeable gains, period.
But, if you have the cash, want a cool looking bay and a spool up noise, go the open air intakes like the ZAC. Just done expect HP gain... it's all show at the end of the day...
Old 12-16-2020, 10:40 PM
  #350
SPONSOR
ModalWorks's Avatar
W205 C63
I respectfully disagree, it is not truthful to say every other company aside from XYZ does not provide gains. Our design has been tested internally and with users (on this forum) and has shown time and time again to improve 60-130mph times and increase power. We use in house ANSYS FLUENT CFD conducted by a simulation expert to create and organic flow profile that optimizes the fluid path. Additionally, our heat shields have a reflective thermal barrier and a sealed top to prevent hot air from entering the filter element.
You can see all of our performance test data, as well as a bunch of customer testimonials in this thread: https://mbworld.org/forums/c63-c63s-...ks-intake.html
Erik Apple (12-17-2020)
Quick Reply: Air Intake Options
