C63/C63S AMG
Air Intake Options
Old Dec 16, 2020 | 11:39 PM
  #351
tobeit's Avatar
AMG C63s
Originally Posted by Erik Apple
im not in a giant hurry. Ill check your IG
What about the amg builder plaque?
As far as I know only ZAC have a spot for the plate. Pics of mine below. VRP says larger filter than ZAC ...hell no, ZAC filter are already barely fitting why would you want bigger. I already switched to K&N to get some clearance.
K&N left, ZAC right ...
Old Dec 17, 2020 | 12:44 AM
  #352
Erik Apple's Avatar
2018 C63
that engine compartment looks amazing for sure.
I think i like the Modal set up with the way they isolate the filter from the rest of the engine and heat
who makes the carbon fiber ram air set up you have? Very nice
Old Dec 17, 2020 | 01:02 AM
  #353
SJGetsome's Avatar
W205 C63 AMG Coupe
Looks like it's made by Gruppe-M.
Old Dec 17, 2020 | 03:05 AM
  #354
mjcw77's Avatar
2016 C63s Estate Edition 1
Originally Posted by ModalWorks
I respectfully disagree, it is not truthful to say every other company aside from XYZ does not provide gains. Our design has been tested internally and with users (on this forum) and has shown time and time again to improve 60-130mph times and increase power. We use in house ANSYS FLUENT CFD conducted by a simulation expert to create and organic flow profile that optimizes the fluid path. Additionally, our heat shields have a reflective thermal barrier and a sealed top to prevent hot air from entering the filter element.
You can see all of our performance test data, as well as a bunch of customer testimonials in this thread: https://mbworld.org/forums/c63-c63s-...ks-intake.html
ok, fair enough. I'm just also advising that bang for your buck, none are that great. tell me how the air gets to the filters if they are sealed against the bonnet? Curious...
Old Dec 17, 2020 | 08:02 AM
  #355
tobeit's Avatar
AMG C63s
Thanks. Yes, it's Gruppe-M as states eaflier. I also installed the ZAC heatshields. They basically also touch the Bonnet and work similar as the MW boxes to shield against hear from the engine.
Old Dec 19, 2020 | 03:17 PM
  #356
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
best bang for your buck is downpipes by far. The fact you can get downpipes for $750 (1/2 the cost of some of these intakes) is crazy
our kit isnt done, Carbon tubes or powdercoated tubes should really look awesome especially with our custom turbo heat shield. we will have a spot for your engine builder.
Old Dec 19, 2020 | 03:35 PM
  #357
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
Just another aftermarket come-on...
Old Dec 19, 2020 | 03:39 PM
  #358
AlexZTuned's Avatar
2017 Porsche 911 C4
Uh how do you think air gets the the filters in the sealed OEM boxes? There are air scoops and an intake tube that draws air from the front of the car and rams it into the sealed airbox - it still uses that do primarily draw air in aftermarket intakes sealed to the hood, closed, open, etc.
Old Dec 19, 2020 | 05:25 PM
  #359
Erik Apple's Avatar
2018 C63
Did u really have to alter the hood for the intake to fit?
Old Dec 19, 2020 | 05:32 PM
  #360
tobeit's Avatar
AMG C63s
The manufacture recommends to "massage" the under hood padding. I did but then also replaced the original ZAC filters with same style K&N, which came 3/4 less rim diameter. That makes all the difference.
Old Dec 19, 2020 | 07:23 PM
  #361
Erik Apple's Avatar
2018 C63
I saw the massage thing, so funny
Probably better to do what you did
Old Dec 19, 2020 | 09:20 PM
  #362
mjcw77's Avatar
do these K & N filters have a part ID #? I have the same intakes as you (ZAC) and definitely want to get a good quality smaller filter like that...
Old Dec 19, 2020 | 09:26 PM
  #363
tobeit's Avatar
AMG C63s
https://www.knfilters.com/ru-2590-un...-on-air-filter
Old Dec 19, 2020 | 09:58 PM
  #364
mjcw77's Avatar
legend... thanks mate...
Old Apr 6, 2021 | 12:04 PM
  #365
Mark Cameron's Avatar
w205 c63s
Hi Jatt143,
I am looking into purchasing the same cai from BMS. Was this an issue that warrants concern? The issue of metal shavings within the CAI. Was it resolved by the BMS?
Many thanks,
Old Apr 6, 2021 | 01:06 PM
  #366
SPONSOR
E55 C63
Check ours out! https://www.vrpspeed.com/product/vrp...take-kit-m177/
Old Apr 6, 2021 | 01:37 PM
  #367
C63_KB's Avatar
2019 C63 AMG
Originally Posted by Mark Cameron
Hi Jatt143,
Many thanks,
im not the person you asked but I’ll give my experience with BMS.
The piping is cheap and came with metal shavings that I ended up having to use wd40 and water to get out. But before that was an issue they sent me the wrong parts and gave me flak for trying to hold them accountable for it.
Once the actual parts I was supposed to get arrived; the piping doesn’t have any crimping or a way for the hoses to stay attached even with the clamps. So you have to crimp the end of the piping yourself if you don’t want the hose to pop off.
Don’t waste your money with BMS.
Old Apr 6, 2021 | 01:48 PM
  #368
tobeit's Avatar
AMG C63s
crimping aka a ridge or similar at both ends of pipe to either cause friction with turbo adapter and filter or to make it a seat/groove for the clamp to press the turbo boots in to avoid slipping off? If so, I don't think any of the metal and even some of the CF tubing intakes have that (BMS, VRP, ZAC, MW, Blackboost)?! They are all just flat at the end. Maybe Eventuri has it? Dont remember if even turbo inlet itself have that "crimp/ridge"?
Old Mar 4, 2022 | 11:25 AM
  #369
sno's Avatar
sno
EQE 350+, EQS 450+, AMG C63
The only issue with the BMS is that it is on perpetual back order. @BMS any idea when they will be available?
the same with VRP... backordered LOL
Old Nov 7, 2022 | 07:31 AM
  #370
Belong's Avatar
W205 C63S T
Originally Posted by BMS
Do you remember if it was one or both pipes? They're all cleaned and bathed before powder coating, so it's very odd to see that still there.
I'll take a closer look and check some of them out when I get into the office.
-Payam
Nice intakes bought straightaway from Alibaba.com
Old Nov 8, 2022 | 05:05 AM
  #371
ZAC MOTORSPORT's Avatar
SPONSOR
AMGs :)
The filter shown here with the K&N is the filter from Gen1, discontinued a few years ago.
The new smaller one can be purchased here.. and is as small a diameter possible while still fitting the 100mm inlet.
Our website has just received a major update, more spare parts will be online soon, in the meantime if you need anything just contact us via the website.
Old Nov 8, 2022 | 05:57 PM
  #372
Belong's Avatar
W205 C63S T
Nah.....
Old Nov 8, 2022 | 06:26 PM
  #373
Belong's Avatar
W205 C63S T
Here is your "BMS" kit from China.. for all the people so that they can see how much they got a$$raped pricewise
Old Oct 28, 2023 | 03:05 PM
  #374
Impasta's Avatar
2021 GLC63s Coupe
Damnnn, i didn't know BMS rolled like that. I thought they manufactured in-house. I'm not too concerned about the price hike because ordering, redistribution, quality control, all that costs money but i didn't think they just sold pre-fab stuff from China.
Old Nov 9, 2023 | 07:53 PM
  #375
Taylorjh6's Avatar
c63s
Good, but I would get ones that are enclosed.
