C63/C63S AMG
Air Intake Options
Old Oct 2, 2019 | 08:26 PM
  #201
skim7x's Avatar
Mercedes-Benz E63s AMG
Originally Posted by BMS
Do you remember if it was one or both pipes? They're all cleaned and bathed before powder coating, so it's very odd to see that still there.
I'll take a closer look and check some of them out when I get into the office.
-Payam
Wd
Old Oct 3, 2019 | 12:13 PM
  #202
jatt143's Avatar
2018 C63s AMG
-Payam
Both pipes
Old Oct 3, 2019 | 11:26 PM
  #203
blowoff's Avatar
S205 C63s
BMS Intake installed.
No issues with wrong kit delivery and dirty pipes.
WOW what a difference in sound and performance this intake has made.
Under Bonnet / Engine Temps have dropped by 8% also. Really happy about the drop in temps.
Car has pipes and stage 2 tune with 295/30/19 R888R's on the rears and it wants to break traction now when I did not before.
Took me about 2 hours to install with the help (NOT) of our 4 year old. LOL !
Delivery to Australia took 9 days via UPS.
Got K-Mac front and rear camber kit + rear bush set to install along with Eilbach springs in the quest for traction.
Old Oct 4, 2019 | 12:53 AM
  #204
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
[QUOTE
Under Bonnet / Engine Temps have dropped by 8% also[/QUOTE]
Not sure how’s that possible with an open air intake but you should be worry about air temp not engine temp. Too high of an air temp will retard timing.
Old Oct 4, 2019 | 01:11 AM
  #205
blowoff's Avatar
S205 C63s
Today here in North QLD its Warm, 28 degrees.
Drove the car hard for over 30 minutes in sports + engine temps prior to the install would get no higher than 105 degrees and normally sit around that.
After install sat around 92 to 96 degrees and with NO loss of power via retarded timing. Did repeated lorches with same conditions.
About 1 month ago after seeing Zac intakes findings on under bonnet temps when they were testing I took his advice and removed the engine bay seal that fits on the underside of the bonnet when closed, see the above pic. That has helped too.
Make the motor and turbos not work as hard by easy air in (intake) and out (dump pipes and exhaust) and it's a proven winner ! Less restriction.
Klinh from your prior posts we can see your a skeptic and not taking on board anything.
Old Oct 4, 2019 | 01:22 AM
  #206
mstraka's Avatar
amg C63s
The pipe design running from the filter to the turbo doesn't appear to be designed for maximum flow. There are too many dirrectional changes in it – from the filter element you have 5 parts: straight pipe, curve #1, 2nd straight pie, curve #2 of a slight radius difference from curve #1, and finally the last straight pipe attached to the turbo. A pipe with one radius, or one constant increase or decrease in the radius, would benefit air flow. Looking back on the photos of the systems installed on this post its interesting to see how different manufacturers addressed this flow path in the design of their pipe.
Old Oct 4, 2019 | 01:33 AM
  #207
jmelcher's Avatar
2019 Mercedes C63S Cabrio
Make the motor and turbos not work as hard buy easy air in (intake) and out (dump pipes and exhaust) and it's a proven winner ! Less restriction.
Couldnt make out in the kit what engine bay seal you removed. Could you point me to that post or be more specific on the image? I had to return mine and the new ones aren’t coming until Monday but I should have time to install next Sunday! Also, do you hear turbos spoiling AND the diver gets letting off pressure or just one of those sounds? If one which one? Just debating not doing vta adapters if that sound is audible through these filters.
thanks in advance for any insight
Old Oct 4, 2019 | 01:48 AM
  #208
Klinh's Avatar
Air intake temp is totally different the engine temp. Just common sense, how can an open air intake now sucking in hotter air is running cooler the the stock air box without doing any other upgrades like intercooler, methanol sprays... etc?
As for no retarded timing. Did you did the car or based on butt dyno? My friend, timing retard can not feel it with butt dyno unless a major retard with major power lost.
Old Oct 4, 2019 | 01:53 AM
  #209
blowoff's Avatar
S205 C63s
Seal was not in the intake kit. It's the OEM seal to the rear of the engine bay that makes the engine bay air tight using the bonnet. Zac's have good videos on the testing google zaccomposites its on instagram.
I would hold off on getting the adapters, the turbo and blowoff valves sounds (Both) are loud ! and with removing the seal they get + 50% again louder. Even when driving with windows up you can clearly hear both.
Old Oct 4, 2019 | 06:11 AM
  #210
alexasa's Avatar
c
so removing the engine bay seal reduced oil temperatures?
genuinely curious about this - i'm not sure what the purpose of it would be other than noise reduction and stopping extra crud from getting in. people have been spacing the rear hood latches in the drift world for a long time to get air venting out the rear.
Old Oct 4, 2019 | 06:37 AM
  #211
blowoff's Avatar
S205 C63s
Yes mate and as said before Zac did testing on this using 2 temp probes, see prior post. The engine bay temps dropped a fair bit along with intake temps the down side you get hot wipers.. lol !
links
View this post on Instagram
Old Oct 4, 2019 | 07:16 AM
  #212
Klinh's Avatar
Which make sense because hot air is not being trapped inside the engine bay. You might as well remove the engine plastic bottom cover as well for even cooler.
Old Oct 4, 2019 | 07:56 AM
  #213
alexasa's Avatar
c
would imagine those shields would help with coefficient of drag
Old Oct 4, 2019 | 07:58 AM
  #214
alexasa's Avatar
c
links https://www.instagram.com/p/Bkrhf0QF9Vr/
https://www.instagram.com/p/Bkrht-PFrnB/
pretty neat - would definitely do that w/ these open air intakes. i saw very bad heat soak on the c43 platform with the BMS system - w/ some sort of retarded timing or boost cut
Old Oct 4, 2019 | 08:37 AM
  #215
ezatnova's Avatar
2016 C63S
Removing other unnecessary things put there by the silly AMG engineers like the hood and front bumper will also cool down the engine a lot more.
Old Oct 4, 2019 | 11:34 AM
  #216
chongl's Avatar
2017 C63
Your engine bay might be cooler but your actual engine temp will run hotter, just ask any seasoned track driver. The undertray in place keeps the engine bay as a low pressure zone so that the air actually passes through the radiator and cools efficiently. I suppose your decision depends if you prioritize colder IAT, or cooler water temps
Old Oct 4, 2019 | 02:35 PM
  #217
Klinh's Avatar
Old Oct 5, 2019 | 09:25 PM
  #218
jatt143's Avatar
2018 C63s AMG
I just finished installing my JB4 and Intake kit. I'm missing two screws that hold the driver's side heat shield. overall happy with the install.
Old Oct 5, 2019 | 11:18 PM
  #219
Klinh's Avatar
Old Oct 5, 2019 | 11:54 PM
  #220
mstraka's Avatar
amg C63s
Reminds me from the 'Wizard of Oz.'
The Lion - "I do believe in spooks, I do believe in spooks, I do, I do, I do." The Witch - "You'll belive in more than that when I'm finished with you."
Old Oct 6, 2019 | 03:48 AM
  #221
dangreene's Avatar
S205 C63S
Is there any videos or real world feedback on the sound of the intakes?
Is it just induction noise that’s louder or turbo spool noise?
Old Oct 7, 2019 | 04:25 AM
  #222
RDO247's Avatar
C63S
Ok check these newly released ZAC Composite C63S & GL63S Carbon Fibre intakes out.
Now with an 80mm turbo inlet so ready for those running big turbos and a step down coupler for those still running standard frame turbos.
https://www.zacmotorsport.com/
Old Oct 7, 2019 | 08:52 AM
  #223
AlexZTuned's Avatar
2017 Porsche 911 C4
Looks nice, but it’s more than double what the BMS costs and I don’t see any benefits over it in terms of heat management. The carbon looks pretty though...
Old Oct 7, 2019 | 09:02 AM
  #224
RDO247's Avatar
C63S
This post is for all Aftermarket Intakes not just BMS’s.
Old Oct 7, 2019 | 09:04 AM
  #225
untamedd's Avatar
2019 AMG GT R
Do any of these intakes have ANY effect on an otherwise stock car?
