C63/C63S AMG
Active sound module
Old Jun 7, 2018 | 03:36 PM
  #451
lovepower1's Avatar
C63 S AMG
I'm not from the US otherwise I would have bought yours WellesleyGL.. Just ordered mine from website, hope it works out well. 2016 model
Old Jun 7, 2018 | 07:28 PM
  #452
TLDream's Avatar
a UFO
everyone except me have the non-performance exhaust it seems jealous....
Old Jun 8, 2018 | 04:20 AM
  #453
FDNewbie's Avatar
'17 AMG S63 Convertible, '17 AMG C63S Edition 1 Coupe
Originally Posted by Slowlane
Sorry I missed that.
Still looking for one? Selling mine...
Old Jun 8, 2018 | 07:31 AM
  #454
Lizard's Avatar
c63 BS; lc500; F-pace SVR; Jaguar P8, c63 p31
Originally Posted by WellesleyGL
This is the (ME2)
I have a 2018, selling mine. Never installed.
I want to recoup my cost from Germany. But, you'll have it within days.
Was It was 299 Euros: - I bought it for 268 euros
2018051103 Flap ControlTotal
€268.00 EURDetailsSent to asr-RemerscheidPM me, please...
Send me $314.00 and I'll ship it today. (would have been $350 plus shipping)
PMed you.
Old Jun 8, 2018 | 11:58 PM
  #455
w62820616's Avatar
C450 | BRABUS 600 AMG GT | C63S
Anyone know why 2018 wont work ?
Old Jun 9, 2018 | 04:16 AM
  #456
Fordgt40's Avatar
C63 amg esate
I would love to know that as well, it opens the valve and keeps it open but makes little or no difference to the sound of the stock loud setting which from what I can visually see has the valve closed on idle.
Old Jun 9, 2018 | 02:57 PM
  #457
AlexZTuned's Avatar
2017 Porsche 911 C4
Ok guys, I feel the need to post an update on my ASR module. I have a 17' Coupe and the module which has worked perfectly up until today.
Now, when I click between "Stock/OEM" and "Fully Open" and watch the valves move, they stay 100% open regardless of setting (it does not revert back to that 60-75% or so open on the stock setting). Only the 100% closed valve function is working.
In addition to this, as I was playing around with the key fob settings while driving around to see if I could hear any difference at all between stock and fully open with the ASR and the car threw itself into limp mode and started switching my traction control settings.
To be honest, I'm quite frustrated with this unit having only had it a few weeks. For reference, when I had my AWE sims (which I just sold to someone on here) I NEVER had limp mode issues.
Word of caution, DO NOT SWITCH TO 100% CLOSED while driving. I believe this may be what threw my car into limp mode. I'm uninstalling the unit now and will reinstall to see if that gets the car out of limp mode. But with my OBD scanner, I don't have any codes stored, yet the car won't make more than 350 HP in the 100% open mode with ASR, and will only make a peak of 480 HP with the OEM/Stock setting. Both are obviously lower than stock.
I'll report back after reinstalling to see if that resolves the problem. If it doesn't, my ASR will be going up for sale or I'll be contacting Daniel for a refund at this point.
Old Jun 9, 2018 | 03:42 PM
  #458
skim7x's Avatar
Mercedes-Benz E63s AMG
Yikes, that's no good. I never close the valves for one, though... Never liked the idea of increasing back pressure... So far I've been okay :crossing fingers: You might need the dealership to reset the limp mode bro. Good luck
Old Jun 9, 2018 | 03:49 PM
  #459
JWreck's Avatar
C63 S AMG, Jaguar F Pace S
Interesting, as you’ve been very positive so far. I quickly tested the HP/TQ numbers and it seemed ok but I’ll have to test again.
I only got the one that has just the two options - fully open and OEM. No fully closed option.
Old Jun 9, 2018 | 04:19 PM
  #460
AlexZTuned's Avatar
2017 Porsche 911 C4
Ok, so quick update. I unplugged the ASR and went back to stock and everything is back to normal now (no more limp mode). With the unit unplugged, the OEM/Stock setting with the exhaust button on now shows the valves back to the 60-75% default setting. I will say that the car is SO much quieter than when the valves were 100% open with ASR. Even at wide open throttle it's more mellow.
Tomorrow, I will reinstall the ASR and see if the valves are switching back and forth properly between the OEM exhaust button on versus ASR 100% open... maybe the ASR box or the ECU glitched when I had the valves in 100% closed for a short time when testing it out today. Still odd because I was never more than part throttle when I switched to 100% closed.
I think there is a major flaw that was overlooked when designing this module by including the 100% closed valves button. When running OEM programming, with the exhaust button off, the ECU will still dynamically open the valves based on engine load and rpm. With ASR's 100% closed button, if you give it too much throttle of boost, the valves will NOT open at all as it would stock and the ECU can recognize that as a failing valve and (rightfully) put the car in limp mode to protect it against high rpm/high load pulls with the valves closed.
Moving forward, I've decided never to touch or use the 100% closed button when I reinstall the unit. If I want quiet, just switch back to OEM/Stock setting and close the valves with the exhaust button. I recommend this to anyone having problems with limp mode.
I'll report back tomorrow to see if all is well after reinstalling.
Old Jun 9, 2018 | 04:58 PM
  #461
bigsid05's Avatar
2017 C63s Sedan
This explanation actually makes a ton of sense to me. I assume if the car cannot open the valves when it thinks it should it will throw a fault. Luckily, I bought this module to make the car as loud as possible so I wasn't planning on touching that button anyway.
Old Jun 9, 2018 | 06:01 PM
  #462
-krikke-'s Avatar
C63 S Coupe
Thanks for the info Alex.
Maybe a stupid question but how does one know if the car is in limb mode? Does it show a warning/message on the dashboard or you only feel a loss in power?
Old Jun 9, 2018 | 08:58 PM
  #463
AlexZTuned's Avatar
2017 Porsche 911 C4
If you have a 2016 or later, you can see it on the HP/TQ display in Dynamic Select. There is no warning/message or even a fault code (because it's a soft fault). The HP will be capped at 350 HP on the gauge, and you will feel the lack of power at wide open throttle.
Old Jun 10, 2018 | 03:23 PM
  #464
AlexZTuned's Avatar
2017 Porsche 911 C4
So I reinstalled the ASR module last night and tested it and everything is working properly now. Stock open and ASR open buttons are working as intended, and I won’t even bother touching or testing 100% closed. I still feel strongly that the closed feature should be removed from the module, at least on this platform since limp mode can be triggered so easily with closed valves.
Happy to have everything back in working order, and a small lesson learned to never use 100% closed
Old Jun 10, 2018 | 03:40 PM
  #465
lovepower1's Avatar
C63 S AMG
Thanks for your updates! Waiting for my ASR module and you got me worried big time! Besides your experience with the limp mode on the 100% closed feature, any other problems? How long have you had it?
Old Jun 10, 2018 | 04:23 PM
  #466
BrownDog09's Avatar
C63 AMG S Coupe (Sept. 2017)
I just went out and pulled this little piece of junk out of my car for piece of mind. Biggest waste of money in recent memory.
Old Jun 10, 2018 | 06:52 PM
  #467
ezatnova's Avatar
2016 C63S
Only junk for 2018’s. Works great on earlier years.
Old Jun 10, 2018 | 08:28 PM
  #468
superstarR's Avatar
AMG C63S
Works great in a 2016 C63S. No issues and sounds great in comfort mode. Would pay twice as much for the unit for the great sounds. So it's a bargain.
Old Jun 10, 2018 | 09:25 PM
  #469
JWreck's Avatar
Yep I actually really notice mine, sounds especially nice going up 4 floors in my parking garage at work every day.
The group buy price was perfect, though I’m not sure I’d have paid much more for it.
Old Jun 11, 2018 | 08:39 AM
  #470
FDNewbie's Avatar
Am I the only 2017 that isn't working? Guess I'll reach out to Daniel in hopes that he has any ideas...
Old Jun 11, 2018 | 09:34 AM
  #471
skim7x's Avatar
Mine is a 2017 and it works.
Old Jun 11, 2018 | 09:45 AM
  #472
AlexZTuned's Avatar
2017 Porsche 911 C4
You may want to try uninstalling, drive around with the OEM valve programming for a bit, and then re-installing the ASR (obviously be sure to follow the sleep procedure when installing). When you reinstall, do not use the 100% closed/comfort button on the ASR keyfob. Don't even touch it! My module started to glitch out when I messed with that button while the car was running - reinstalling it fixed it.
Old Jun 11, 2018 | 11:52 AM
  #473
FDNewbie's Avatar
I've had it disconnected for days. So I have a few hundred miles on it as-is.
What's the sleep procedure? I read what you had written in your AWE Simulators thread. But how are you accessing the trunk without raising the car out of sleep mode? I gotta unlock the car to get to the trunk. Or are you popping the trunk, then locking the car (assuming you can do that) with the trunk open, leaving it open for 10+ min, then reconnecting the ASR module (while leaving your key far away)?
Then when do you start/lock/unlock the car afterward?
And you said don't touch the keyfob...so does it default to open mode? And leave the OEM valve button in default off? Or press it to open?
Yea I'm being a little particular, cuz I REALLY wanna get this to work =-/
Old Jun 11, 2018 | 01:14 PM
  #474
munis's Avatar
2021 Mercedes C63s AMG Coupe
When you guys say it is not working for 2018 modules, do you guys mean that the valve is not opening 100 percent? Or you guys just don't see any volume increase? Like if you have the module set to open, do you guys still see the valve partially closed? If you do not know what 100 percent open looks like, if you turn off the car, the valve is setup for fail to open, so that is how 100 percent open should look like. If you turn the car car on the module set to open, the valve opening should not change. You will need a second person to compare this if you want.
I tested all of this using one of my friends, and the module is working for me. Just fair warning, as I was starting at the exhaust's end like a retard ,I was also inhale ling what is probably raw C02. I was feel dizzy for the entire day after my little experiment.
Old Jun 11, 2018 | 01:19 PM
  #475
Fordgt40's Avatar
C63 amg esate
Valve is opening 100% and remains open but no increase in volume, it’s very odd.
