C63/C63S AMG
C63S Replacement Rotors
Old Sep 13, 2019 | 12:42 PM
  #101
RacingBrake's Avatar
Former Vendor of MBWorld
CLS550
Originally Posted by Star4life
are there any 2 piece rear brembo options?
OE is one piece, RB's light weight 2pc rotors are available here:
https://www.racingbrake.com/RB-2pc-Rotor-Kit-for-Mercedes-S63-65-SL55-63-E63-p/2357.htm
components are in stock.
Old Sep 13, 2019 | 01:19 PM
  #102
Star4life's Avatar
2017 C43 AMG
I found a 1.5 OEM piece rear rotor mainly used on s63 and amg gts. 222-423-20-12. spendy though, $1000 for one rotor!
i will stick to solid rears or go the racing brake option.
any other good 2 piece options out there?
Old Sep 14, 2019 | 01:37 PM
  #103
CLS550
Originally Posted by morte
What are these brake pads like for brake dust?
Do you guys ship to Australia?
Racing Brake makes me happy
https://mbworld.org/forums/sl-class-r231/530843-racing-brake-makes-me-happy.html#post5939978
Yes we shipped to Australia all the time.
Old Sep 15, 2019 | 01:30 AM
  #104
morte's Avatar
C63S Edition 1
Sorry posted this by mistake.
Old Sep 20, 2019 | 09:13 AM
  #105
Star4life's Avatar
2017 C43 AMG
question for racing brake. Ive been doing a lot of research on rotors and looking at dimensions and such. as a EE at one of the big 3, i know the process we go through to design something to last to oem spec. i am not a mechanical guy so i have a few questions pertaining to the rotors. i have a c43. i am upgrading to the c63 brakes. as i look at the dimensions of all of these rotors, i see where the weight is taken out. the first and most obvious is the 2 piece rotors use an aluminium hat. the oem and your design do this. this helps to reduce the weight of the steel hat and also allows the friction surface to expand and contract without effecting the hub as much. great design it seems as you and brembo/benz agreee on this.
the next part is where you and brembo/benz differ. the heaviest part is the rotor friction surface. the c43 and base c63 share the same size front disc. they are 360mmx36mm. both base models are solid one piece. the hat thickness on c63 is 4mm thicker but other than that the dimensions are the same. the difference between them in weight thought is a lot. the c63 base one piece rotors come in at 35-36 lbs. the c43 rotors come in at 27 lbs. almost a 10 lb difference in the same size rotor. how is that? looking closer besides the thicker hat, the friction surface is also thicker. total rotor thickness is 36mm. the space between friction surfaces on the c43 is 17.5mm. so 36mm - 17.5mm is 18.5mm/2 is 9.25mm friction surface thickness per side. the c63 rotor is 36mm-11.5mm = 24.5/2 is 12.25mm friction surface per side. so same size disc in the 63 has thicker friction surface making it heavier. now lets compare 2 piece to 2 piece. looking at the brembo (aka black series rotors) 2 piece. you can see the gap between is slightly less than the solid disc at 13mm and weight of the 2 piece comes in at 29 lbs.
so how can you lose another 5 lbs? hat for hat, aluminium rotor hats are going to be very similiar since you cant really change much of those dimensions. I am assuming your friction surface thickness is less by looking at the pictures. where else is weight removed? And why can you remove weight here where as the OEMs decided not to? When you say soft vs hard iron what does that mean? Fe is Fe to me. is it a different alloy? You say oem uses soft iron? I will assume the oem uses soft iron to make it cheaper to mass produce where as hard iron alloys are more expensive and specialized? Please tell me what makes your 2 piece rotos better than the brembo units and how you can make them lighter but still being strong to stand up to track usage. do you have a drawing we can see for your rotors?
c43 rotor
c63 rotor
2 piece c63 base rotor
Old Sep 20, 2019 | 09:22 AM
  #106
FCPEuro's Avatar
Mercedes
C43/C450/C400 etc rotor is not a one piece design. Your rotor has thin high tensile sheet steel that is geared to the friction surface.
--Kyle B
Old Sep 20, 2019 | 09:32 AM
  #107
Star4life's Avatar
2017 C43 AMG
--Kyle B
thanks for pointing that out. thats pretty cool i was wondering why that design was there. looks like the brembo replacements dont have that.
Old Sep 20, 2019 | 09:36 AM
  #108
FCPEuro's Avatar
Mercedes
Correct, to keep costs down Brembo's aftermarket replacements do not match their OE design
--Kyle B
Old Sep 20, 2019 | 09:43 AM
  #109
Star4life's Avatar
2017 C43 AMG
--Kyle B
once i get the c63 brakes on, are there any negatives to the brembo c63 rotors vs oem? I was planning to go with the brembo 2 piece fronts 360mm and i actually already bought the brembo solid rears as i didnt see any difference between the brembo rears and the oem rears and price was half in addition to the nice black coating. i wanted to buy the brembo rears from you for the lifetime warranty but didnt see them for sale. only see the front 2 piece and oems.
if racing brake has a good answer to the weight reduction, i may try theirs out but they are very expensive. but the unsprung weight saving is very tempting.
Old Jan 15, 2020 | 11:23 AM
  #110
KAHBOOM's Avatar
GL450, AMG C63S Coupe
I just installed the Brembo rotors from FCP Euro. They look great behind the wheels with the black hat and retaining screws. The braking feels the same as the OE rotors I had. From what I researched prior to purchasing, they were standard on other AMG models including the SLS63 and the C63 Black Series. Install was plug and play.
Old Feb 5, 2020 | 02:34 PM
  #111
untamedd's Avatar
2019 AMG GT R
Hello,
From what Ive gathered from this thread, for a C 63 S Coupe for example, I can use the following:
Front Rotors: https://www.ebay.ca/itm/For-MB-W219-...72.m2749.l2649
Rear Rotors: https://www.ebay.ca/itm/352090761454
Has anyone used these and can confirm? Thanks.
Old Feb 5, 2020 | 03:01 PM
  #112
deftronix's Avatar
17 C63S coupe
I will know within a week or two since my set will be arriving Sat. BTW, you have the links reversed. I went with the 2 piece front you have linked but also got the two piece rear from the same vendor. Not 100% on fitment yet as I'm not sure it will fit with the electronic ebrake or that the set scew holes will line up even though thats not as important. Fronts should be good from my research. Have a set of ebc redstuff pads will be installing as well to minimize brake dust.
Rear 2 piece
Old Feb 5, 2020 | 03:04 PM
  #113
untamedd's Avatar
2019 AMG GT R
Rear 2 piece
yeah i did have the links reversed. fixed it now. I didnt know that vendor had rear rotors too because previously they didnt. Messaged the vendor on ebay.
*nevermind I didnt see the hyperlink in your post
Old Feb 5, 2020 | 03:13 PM
  #114
deftronix's Avatar
17 C63S coupe
They technically aren't listed as compatible with the car. I paid listed price, $400/ea. Was surprising that they are more than the fronts but probably because they aren't as widely available since the are made for an older SL and the fronts are used on many different current platforms. They match all the specs of the oe one piece rears so hoping for the best. I would hold out and wait to hear back from me, it would be worth going with the 2 piece!
Old Feb 5, 2020 | 03:28 PM
  #115
untamedd's Avatar
2019 AMG GT R
https://www.ebay.ca/itm/For-MB-R230-...53.m2749.l2649
Oh its $400 each and not $400 for the set? I assumed it was the set because the price they quoted for the front rotors is $720 USD for the pair unless im mistaken?
Old Feb 5, 2020 | 04:21 PM
  #116
deftronix's Avatar
17 C63S coupe
Yep, you're correct. Paid $730 for the front pair & $800 for the rears. Let ya know if 6 rotors show up but pretty sure they're individually priced.
Old Feb 5, 2020 | 04:50 PM
  #117
untamedd's Avatar
2019 AMG GT R
yeah that sounds about right.
Have you changed brake pads? Any recommendations there? Was going to get Porterfields but recent feedback from users here hasnt been all that great. HAWK only makes pads for the front!
Old Feb 5, 2020 | 04:57 PM
  #118
deftronix's Avatar
17 C63S coupe
Will be switching out pads to ebc redstuff on all 4 corners to cut the brake dust. I usually run Hawk HPS on my other cars but went with these for the same reason you mentioned. Will post part #'s once I can confirm everything fits.
Old Feb 5, 2020 | 06:36 PM
  #119
untamedd's Avatar
2019 AMG GT R
So that EBAY vendor took my VIN and said they dont have rotors for my car even though those links clearly show they are in stock. Is it because they arent specifically for our cars but still fit? Im mostly just curious about the one in the front because rear being the same price, Id prob just buy OEM.
Old Feb 5, 2020 | 07:30 PM
  #120
deftronix's Avatar
17 C63S coupe
Yes, most vendors will only list the cars that are officially referenced by the manufacture. FCPeuro and others do the same thing since they dont want to be held liable in case there is a problem with fitment since they usually have not had the opportunity to mount the item to the exact car you're asking about themselves.. There's also a chance that the set screw holes will not line up with the hub which is not a deal breaker, you can still run them as long as everything else is in check. The fronts, from research am very confident will fit, set screws as well. The rears are more up in the air and worried about the electronic ebrake. Although I did look into 2011 SL65 (what the rear rotors are listed for) tech and it had an electronic ebrake and not a drum ebrake. Guess we'll see.
Old Feb 6, 2020 | 11:26 AM
  #121
untamedd's Avatar
2019 AMG GT R
Thanks for the help. Just ordered pads and rotors all around for a total of $2550 CAD versus $4160 that I would have paid at the stealership!
Old Mar 18, 2020 | 11:50 AM
  #122
Chigs's Avatar
2018 C63S Sedan
Sorry to revive an old thread. Anyone have the torque specs for the various bolts on the front calipers? Rears too for that matter.
Old Jun 15, 2020 | 05:32 PM
  #123
FDNewbie's Avatar
'17 AMG S63 Convertible, '17 AMG C63S Edition 1 Coupe
FCP and RacingBrake, do either of you offer a cryo treated rotor option (for an additional cost)?
Old Jun 15, 2020 | 06:49 PM
  #124
FCPEuro's Avatar
Mercedes
@FDNewbie We do not, I only offer OE options at the moment.
--Kyle
Old Jun 15, 2020 | 08:32 PM
  #125
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
--Kyle
How much for oem coupe rear pads with red Brake caliper?
