C63S Replacement Rotors
He also mentioned that a big brand of forged wheels starting with V has their wheels made in Taiwan aswell.
At the end of the day it's the product itself and after sales service that matters for me.
OEM at dealer (front rotors/pads) - $3300
Brembo from FCP, $900 for pair rotors - https://www.fcpeuro.com/products/mer...mbo-2304211212
Platz, $1125 for pair rotors (drilled above, slotted on website) - https://platz1motorsports.com/Platz1...AMG-p147333155
Racing Brake, $2915 for front and rear rotors, pads - https://racingbrake.com/mb-irk-12
The RB links above don't work and I cannot seem to find the rotors only, as I am using EBC Blue pads from FCP (yeah, probably should switch to a harder track pad for track days) so do not need the whole package.
So would the Racing Brake rotors be able to handle the abuse of track days better than the Brembo/OEM, or just suck it up and do FCP and replace when they are worn down?
If you want a proper track pad, there are some at
https://mbworld.org/forums/market/821362
So I believe there is room for getting at a better price at the MB Dealership if you elect to go that way.
https://mbworld.org/forums/c63-c63s-...ml#post8470628
At the MB Dealership I had both replaced based on the indy recommendations and the MB Dealership findings on the front rotors: Rotor min thk 33mm actual 34.1 and 34.3mm.
My car was there for other issues
so just had it done.
In case anyone is interested, here's the EBC part numbers I do have (these came from EBC) ...
For 2016 AMG C63 S Sedan (fronts are 3-piston/side, red calipers, 390 mm/15.4 in, iron rotors)
orange stuff front pads: DP91939
orange stuff rear pads: N/A
yellow stuff front pads: DP41939R
yellow stuff rear pads: DP42350R
blue stuff front pads: DP51939NDX
blue stuff rear pads: DP52350NDX
RP-1 front pads: DP81939RP1
RP-1 rear pads: N/A
RP-X front pads: DP81939RPX
RP-X rear pads: N/A
I've used Yellow Stuff and Blue Stuff and am moving to RP-X for track-only running (with Blue Stuff on rears). I run Blue Stuff for street use and have also run Yellow Stuff on the street. Blue/Yellow are both fine for street use.
When I swap to/from winter/summer wheels/tires, before putting the wheels up on the rack, I always clean the wheels and apply a coat of ceramic paint protection (I just use the cheapo Amazon Mr. Fix 9H stuff and it works just fine). As such, I never worry about brake dust since it comes off easily just using a soft brush and Palmolive dish soap (I use Palmolive because it has an almost neutral PH, 7.2 IIRC).
