Hit raccoon = killed engine
Then I stop the car check for damage, lucky there was no body damage at all, front bumper wasn't damaged. So I keep driving, but after 10 min normal driving, engine turns bad, I heard ticking knocking noise from engine. I stop the car right away, then check closely. I found my engine oil cooler was damaged! engine was running NO OIL!!!
EVEN UNTIL I HEARD NOISE STOP THE CAR, I DID NOT GET ANY WARNING MESSAGE FROM DASH! NOTHING ABOUT LACK OF OIL! NOTHING ABOUT LOW OIL PRESSURE LIGHT!!!!
FUNNY THING I CAN STILL SEE ENGINE OIL TEMP.!
Worst thing was I did not have cell phone signal at all(This is Canada)
, we push the car for about 1.5 km to get barely 1 bar 2G EDGE signal.Pretty similar like AutoVlog, I need new engine or my car totaled.
NEW UPDATES #29 FLOOR
Ticking happens fairly quickly as soon as you go to lower oil levels, so you may have not been completely starved. Since you stopped as soon as you heard the ticking, you might be OK.
Though it does look like it's positioned similar to the M3/M4, and quite a few had issues/damage with debris hitting and puncturing it.
I would file an insurance claim and they should cover the cost to fix or total the car under the comprehensive part of your policy.
I COULD NOT BELIEVE EITHER, BUT IT HAPPENS. I GUESS WHEN I HIT THAT RACCOON (AROUND 60 KM/H), THE IMPACT HAPPEN UNDERNEATH THE CAR NOT DIRECTLY ON FRONT BUMPER. AND BROKEN BONE CAUSE THE COOLER DAMAGE.
BTW: WHEN THE CAR JACKED UP, FOUND THERE IS NOT ONLY OIL COOLER DAMAGED, ALSO COOLER COVER AND ENGINE BOTTOM COVER DAMAGED. IF IT HIT A ROCK HOW COULD FRONT BUMPER NOT DAMAGED BUT BROKE AND BEND COOLER.
And stop yelling.
Mud got from when we drove to camping Saturday(rain), we used water hose washed car at camp(sorry waste a lot water
), when we heading back on morning of Monday, we choose another route back which has most road are paved, condition far more better than we went to camp, this can poof by this picture:
If we hit in mud caused damage on we way back, front bumper could not clean like this.
