C63/C63S AMG
Correct oil change procedure for 2017 or 2018 c63s
Old Nov 26, 2017 | 09:16 AM
ahesq's Avatar
2021 GLE63S
Can anyone please publish the MB official engine oil change procedures?
I understand that in addition to the main plastic drain plug next to the oil filter (which is not reusable), there is another plug towards the front of the car that needs to be removed and drained as well?
Old Nov 27, 2017 | 07:40 AM
ahesq's Avatar
2021 GLE63S
No one has this info?
Old Nov 27, 2017 | 08:58 AM
srO_Michael_Orz's Avatar
C63s(lost)/E250/GTR(Sold)/GTS(Carbonerre)
https://mbworld.org/forums/c63-c63s-...2017-c63s.html
Look at this #2,#4 and#6
I suggest remove both drain plugs, for completely drain out old oil. But YOU NEED REPLACE COPPER WASHER if you do the front one, make sure you have one before you drain. part # for copper washer: N007603014106
Old Nov 27, 2017 | 12:44 PM
ZX10R's Avatar
2017 AMG C63 Sedan Iridium Silver
Thanks for that info. Have couple questions: (1) Does removing engine compartment paneling underneath to get at filter and drain plug require any special tools? (2) Do you happen to have the part numbers for the plastic oil pan drain plug and the metal drain plug near Y130? Thanks.
Old Nov 27, 2017 | 02:51 PM
1.No, normal tools.
2.Plastic drain plug #A0029902017, Technically you should discard old drain plug, but in reality plug could be reuse depends on condition. I suggest you reuse it, since it cost around $15.
3.Metal drain plug #N000908014009, 100% You do not need replace this one unless you screw it up.
Old Nov 27, 2017 | 03:39 PM
ZX10R's Avatar
1.No, normal tools.
Thanks very much. Appreciate it.
Old Nov 27, 2017 | 07:00 PM
ahesq's Avatar
2021 GLE63S
Do you know where the second drain plus is located?
Old Nov 27, 2017 | 11:16 PM
near the Y130, you can find the second one, which is metal screw.
Old Apr 2, 2018 | 12:30 PM
theclutch's Avatar
C8, FF, C63S, 911 C4S, GTI, E350, Boxster S, 355, Esprit S4, Vantage, S5, Z4, M3, Miata, A4, 325is
What is the engine oil capacity? Is 9L = 9.5 quarts correct????
Old Apr 2, 2018 | 01:09 PM
Art138's Avatar
2017 c63s coupe Fordfgt Supercar
I suggest you put in 9 quarts and then check the oil level. These are front and rear plugs respectively....
Old Apr 16, 2018 | 09:03 AM
Dave in VA's Avatar
2011 SL65 & a 2018 C63s
My Wife just got a 2018 C63s and looking at the plastic oil drain plug it appears you can use a coin or something like that to remove it (it has a curved slot in it) is there a special tool or can I just use a screw driver?
That is the black plug in the picture above.
Thanks,
Dave
Old Apr 16, 2018 | 10:10 AM
Thanks,
Dave
just flat screw driver.
Old Apr 16, 2018 | 10:20 AM
Dave in VA's Avatar
Outstanding - great thank you very much. This is the best site for information on our car.
Again thanks a lot.
D.
Old Apr 16, 2018 | 10:00 PM
Dave in VA's Avatar
Oh one other quick question - is there an oil life reset procedure? This thing has all types of different screens and I haven't found exactly where to go to/what screen to reset the oil life once I change it.
Thanks,
D.
Old Apr 17, 2018 | 05:29 AM
Art138's Avatar
This should guide you through the procedure.
Old Apr 17, 2018 | 04:50 PM
Dave in VA's Avatar
That will work thank you all very much.
D.
Old Sep 8, 2018 | 09:14 AM
ahesq's Avatar
2021 GLE63S
First Oil change
Just did my first at about 6,500 miles and 10.5 months
Drove car up on floor ramps so that front was about 5 more inches off the ground than the rear.
Exactly 10 quarts came out and 10 went back in. Dip Stick shows almost full after several different readings.
I did not drain the front plug by the oil pump valve, as others suggested, since I had 10 quarts come out of the main plug. My guess is that having the car on front ramps allowed the oil to drain back to the rear sump plug more easily.
Anyway, it was an easy job, but I wonder why they publish 9.5 quarts as the capacity?
Anyone know?
Old Mar 10, 2019 | 09:38 PM
gOt BoOsT's Avatar
‘17 GT F1A E85 Monster ‘16 C63s
Changed my oil for the first time today!
Jacked up the car, put stands on both sides of the front, removed all the 8mm metal bolts holding the two under trays, set them aside then removed the plug and the filter housing last. Once I removed the plastic flathead drain plug and the oil filter housing I let it drain until the drips stopped. Changed the o ring on the filter housing, installed the new Oem filter, then reinstalled the plug and filter housing. Put in 9 quarts, started the car, checked for leaks, put the under trays back on and set the car back on the ground. Checked the dip stick and it was barely at the minimum mark. Added the remaining quart (10 total) then rechecked the level and it was 3/4 full on the dipstick. Perfect.
Total cost was $50 for two 5 quart jugs of Mobil1 0-40 synthetic euro formula and $16 for an Oem oil filter.
Also I used this video for reference.
Old Mar 11, 2019 | 10:35 AM
Cascade1's Avatar
2019 C63WS
Do y'all reccomend changing the engine oil with the rear differential at 2K miles? 10K miles seems like a long time to have that break in oil running in the engine. I'm also asking because I have dp+tune scheduled shortly after the service so I'm wondering if I should have fresh oil for the dyno?
Old Mar 16, 2019 | 11:08 AM
ahesq's Avatar
2021 GLE63S
2k for that
Who says 10k?
Old Mar 16, 2019 | 11:23 AM
Cascade1's Avatar
2019 C63WS
2k for that
Who says 10k?
The engine oil gets replaced at 2K aswell? I have pre paid maintenance and my dealer told me 2k is just rear differential.
Old Mar 16, 2019 | 11:37 AM
Dnmscz's Avatar
AMG C63S
I was told the same by my dealer. Rear diff @ 2K miles, oil change at 10K or 1 year whichever comes first.
Old Mar 16, 2019 | 12:25 PM
ahesq's Avatar
2021 GLE63S
Sorry, I read your post too fast.
Thought you were just talking rear diff.
Yes 10k/1 year engine oil/2k diff. oil. first time only
I changed my engine oil at about 6,500 miles and 10 months or so, and it was still ok
I would say 7500/10 months if you don't drive much
Old Apr 12, 2019 | 11:52 PM
Jonathan Dunn's Avatar
2018 C63 S Coupe
Use Ramps. Anyone know oil filter bolt size?
I also used ramps and did not mess with the front (metal) drain plug. Also, next time I will only remove the rear underside cover and back 4 bolts on metal front cover to gain access to filter and drain plug.
Does anyone know the outer diameter of the oil filter housing bolt (black plastic)? Someone mentioned 32mm which I have and is way too big. My largest traditional metric socket is 20mm and was too small. Thankfully the center core of the black plastic filter cover receives a 10mm hex bit (picture below)
Note: I had to jack up the car to get the ramps underneath the front tires as the front lip is too low to drive up normally. My 2018 has not been lowered. All the best. Thanks for the tips!
Oil filter cover (black plastic) removed using 10mm Hex socket.
Front metal drain plug (red) and rear (black plastic) drain plug near oil filter cover.
Anyone know?
Old Apr 14, 2019 | 07:44 PM
ahesq's Avatar
2021 GLE63S
You should get new lower profile/gradual incline ramps so you won't have to jack the car up next time
