C63/C63S AMG
W205 C63S Aftermarket street brake pad options
Old Nov 18, 2021 | 01:46 PM
  #101
untamedd's Avatar
2019 AMG GT R
i wouldnt be able to tell you that because i didnt even open the box when the brakes got delivered and just took it straight to the shop
Old Nov 18, 2021 | 08:50 PM
  #102
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
If it hasn't been mentioned, the rears are the problem. FL and pre-FL rear pads are quite different. The fronts are prtty much the same. First time I ordered Red Stuff for a FL 20 C63S coupe, the rear pads had the silver tabs and did not fit. A year later they caught up with the design and I got the correct rear pads. The FL versions have the traditional side tabs we're use to. Call the company you're buying from and verify before you buy.
Old Nov 18, 2021 | 09:42 PM
  #103
hoodat's Avatar
2019 C63S AMG, 2008 335XI N54
oh okay great, i got the correct rear pads. Oh wow I didn't know the fronts are interchangeable.... the current front pads i have don't have the huge circular tabs on them, so i thought they wouldn't fit the calipers!
Old Nov 18, 2021 | 09:45 PM
  #104
///Bruce's Avatar
Double check on the fronts. Mine had the circular tabs.
Old Nov 18, 2021 | 10:38 PM
  #105
hoodat's Avatar
ahh okay and yours is C63S with the red calipers right? smh so confusing with all these little differences.
Old Nov 20, 2021 | 04:06 PM
  #106
ggogobera's Avatar
C63S 2015
Oh man, I’m so disappointed of Porterfield street compounds.
Brake performance is very good, but noise… It started after 500miles.
The combo is Porterfield and Brembo discs. I’ve installed new sets.
I don’t know what to do with brake noise anymore
Old Nov 21, 2021 | 01:55 PM
  #107
mischief's Avatar
W205 AMG
Did you bed in your new pads and rotors? If not that's probably causing your noise. Follow this procedure.
Old Nov 21, 2021 | 03:36 PM
  #108
ggogobera's Avatar
C63S 2015
Thanks for response.
The street compounds doesn’t need to be bedded. I’ve had a call with their ops about that.
When you change discs and pads together wearing starts evenly, so discs are in the best operating state.
Noise happens in some temperature range not always. If driving aggressively and it’s hot, there is no noise. When you chill in the streets and press slightly it starts then, but if I depress harder it’s gone. Clearly indication about materials. “High performance noisy brake” bs happens
I haven’t change clips and other hardware components tho they were in a good condition.
I’m coming to conclusion that noise cannot be avoided.
It’s not too loud, but still embarrassing kinda. You drive in the streets with this car and brake squeak, lol
Old Nov 22, 2021 | 11:51 AM
  #109
1slick_c63amg's Avatar
C63 AMG
Interesting to hear this feedback. I have fitted new brakes - OEM rotors with Porterfield RS4 pads front and rear and have absolutely no noise (stockers were very squeaky!). Front have probably 4k miles and rears 1.5k miles on them.
Old Nov 22, 2021 | 11:59 AM
  #110
ggogobera's Avatar
C63S 2015
Yeah, it’s very strange and I’m surprised as well.
It shouldn’t have noise. Others have posted that they are quite.
It might be my driving style, sometimes I drive very aggressively which can be a factor for street compounds
Old Feb 25, 2022 | 10:40 AM
  #111
dreupnu1's Avatar
AMG C63s and E300
Angry Frustrated
I bought these pads from Tire Rack for my 2020 C63s and my installer is telling me that the front is the wrong size and also the pads should of came with silencers. Also since i have a electronic parking brake that his computer will not mirror up with my car for the command code ?. I verified the part number with Porterfield website as well. Thoughts?
and my installer is saying the front pad is wrong and I also verified the part number with Porterfield. The next thing is that he's saying they should of came with a silencer, is this true for the 2020 C63s ?
Last edited by dreupnu1; Feb 25, 2022 at 10:41 AM. Reason: forgot to put the model
Old Feb 25, 2022 | 02:25 PM
  #112
jj18's Avatar
2019 C63S Coupe
Recently I had front brakes and rotors replaced at MB Dealership for 2019 C63s. The 2 Invoice photos below shows what parts were used with Part #. Don't know about a Silencer? Hope it helps.
Old Feb 25, 2022 | 03:00 PM
  #113
dreupnu1's Avatar
AMG C63s and E300
Appreciate it, yep I had the part number but cant seem to find the size. Im good though, I will just returned the pads and will order Porterfield pads
Old Feb 26, 2022 | 12:51 PM
  #114
mischief's Avatar
W205 AMG
This is interesting as I've never hear of anyone having issues with the front brake pads being the incorrect size. Ppl have reported issues with the rear brake pads between model years. I believe the rear pads changed for either MY18 or 19. Did you installer compare your existing pads to the new Hawk one's you bought?
Not sure what installer is referring to when he says silencers? Is he talking about the shim plate that some pads have on the piston contact side, or is he talking about the anti-squeal paste that should be placed on the piston contact side? Not all pads have shim plates and you can choose to add them should you wish. Some think it provides a better thermal shield against heat transfer between the pads and pistons/brake fluid. Not all pads come with the anti-squeal paste either. Its a common shop supplied material you installer should have. It can also be bought at your local auto parts store for a very small amount of money.
Your installer should need to plug your car into his computer to release the electronic park brake. It can be done using the steering wheel and instrument cluster. The video below shows you how to do it on the FL models.
Old Sep 22, 2022 | 01:41 PM
  #115
profi's Avatar
2015 C63s E1 Irridium silver, 2008 C300 rwd, 2007 Audi Q7 3.6 S line premium, 2002 Renault LagunaII
What about non OEM rotors for front and rear anyone please help?
Old Sep 23, 2022 | 03:51 AM
  #116
Iridium.C63s's Avatar
16' C63s, 22' RAM 1500
Originally Posted by nineonenine
Does anyone have any good recommendations for low dust aftermarket street brake pads for a 16 W205 c63s? (Non Carbon Ceramic)
Trying to search around but not finding much. What is a good site to purchase from?
Thanks in advance!
if anyone is interested I have a brand new set for sale. I went with carbotech instead of running street pads..
for red caliper c63s!!!
Pads front and back are R4-s
$400 shipped
Old Sep 23, 2022 | 09:39 PM
  #117
cls5504matic's Avatar
C63 Vert
you need an m12 spline. I'd watch a few videos on replacing Porsche brakes. similar setup. rears may be similar to a Camry but the fronts are going to be different. use a screw driver to give some space between front pads before removing.
Old Sep 23, 2022 | 09:41 PM
  #118
C63 Vert
there are Brembo 2 piece options, I believe about 400 each side on fcp euro
Old Sep 23, 2022 | 09:47 PM
  #119
C63 Vert
Originally Posted by kzflags
is there anything less expensive than the porterfields for the base c63 with gray calipers? i found nothing
Check out rock auto. I'm trying out the dynamic friction 5000 front and rear for a bit. If they aren't good I'll change with OEM or porter field on next try. They are about $120 for front and rear.
