cell phone holders?
http://www.mountek.com/shop/categori...gift-packaging
If you do use a case, you can put the included metal plate between your phone and the case and use this:
http://www.mountek.com/shop/categori...s-plus-tablets
Instead I bought this one
Remember if you have wireless charging back, you may want to stay away from the magnetic sticky ones. So the iOttie mount would really well for me and very very stable.
That being said, I just tighten the mount a little extra and make sure it's "straight in" after putting my phone in. It's never fallen off while driving.
You don't need to purchase the expensive ProClip holders either, I coupled it with a magnetic mount (magnet adheres to the ProClip arm) that can also be easily found on Amazon (<$10) for a very sturdy mount. No fumbling with clipping the phone in or anything like that. Routed the cable discreetly from inside the armrest and it works great.
Which version did you guys choose?
Item: 855058 for Models with "Woodgrain" panels (I have the Carbon Fiber dash, so I would assume this would be my version)
OR
Item: 854996 for Models NOT with "Woodgrain" panels.
Use one in my truck daily & the wife's E63 daily. Even jumping my truck, I don't have problems with the phone flying off.
The spring is really strong, but the drawback is that you always need two hands to get the phone in and out of the holder.
The advantage of the CD mounted holder is that you can pull it out with one hand, do what you need to do and then slide it back in with one hand. If this isn't part of the way you use your phone, the AirFrame+ would be a great option!
Just my $0.02...
https://www.iottie.com/Product/Detai...-CD-Slot-Mount
This one's very solid and doesn't slide out at all. Also, it goes in and out of the mount super easily! Would definitely recommend this!
