C63/C63S AMG
W205 c63s transmission crunch sound
Old Jun 25, 2018 | 02:23 AM
Johnny Wang's Avatar
w205 c63s edition1
Hi all
Does anyone experience the crunch sound coming from transmission when put from park to drive in the morning cold start?
below are the link that shows the sound .
This is 2015 made w205 c63s
Old Jun 25, 2018 | 08:53 AM
gtracer's Avatar
'13 C63 & AP2 S2000
Bring it to the dealer...?
Old Jun 25, 2018 | 09:04 AM
w205 c63s edition1
Thanks for reply, but my car is over warranty.so I’m not thinking to take back to the dealer,just want to see if anyone got the same issue . Besides, the car runs well and smooth nothing strange .
Old Jun 25, 2018 | 05:01 PM
Chigs's Avatar
2018 C63S Sedan
Do you let it idle down from warming the cats? Sounds unrelated but it allows the fluids to get some heat.
Old Jun 25, 2018 | 10:03 PM
C3504matic's Avatar
2015 C63S ,DME Tune, KW Has ,Kmac Bushings,BC Forged wheels,Gt Rotors,Porterfield R4S,Modal Intake
That doesn't sound good . How many miles/ kilometers are on the vehicle ? Have you had the transmission serviced by a dealer regularly ? How often do you use race mode/ or launch control ?
Problem is they don't sell parts for the transmission only complete units which means "expensive" unless you can find a used transmission .
Old Jun 25, 2018 | 10:35 PM
w205 c63s edition1
I’ll try to warm up a bit more to see if this issue disappears. This sound is like when park on the hill without using the handbreak straight to P position . And the next time put into Drive , the clutch crunch.
Old Jun 25, 2018 | 10:50 PM
w205 c63s edition1
this car is around 6000miles .It’s sencond hand car. So I don’t know the ex owner did to the car. The car condition is very good. Just this issue annoying me . I haven’t had the transmission service by the dealer. Because it’s in low mileage.
In my hand I haven’t launch the car and always in comfort mode.
Ill try to warm up abit more. Let the fluid go through the transmission to see if it reduce to happen.
Old Jun 26, 2018 | 08:27 AM
Harold1898's Avatar
2015 E400 Coupe
johny, take it to the dealer and ask them to analyse the problem and quote on rectification. At least you will know what is wrong and it won't cost you anything other than a little time to find out without obligation.
Old Jun 27, 2018 | 02:50 PM
Chigs's Avatar
2018 C63S Sedan
As a follow up. Drive it around until everything is warmed up, then shut it down and start it back up to see if the noise is still there. That should clear things up.
Old Jun 27, 2018 | 03:16 PM
alexanderfoti's Avatar
2013 W204 C63 AMG, 2008 W221 S65 AMG
Its sounds more like the ISM - The selector motor that is bolted to the side of the gearbox. Has it gotten louder over time?
Old Jun 29, 2018 | 10:03 AM
w205 c63s edition1
after fews days of trying to warm up more time during morning cold start. This crunch sound is gone. I have also try to warmed up and shut down and start again put into park and then drive. No strange sound.
Old Jun 29, 2018 | 10:06 AM
w205 c63s edition1
it didnt happen every time .and hasn’t got any louder . But I noticed that it would only happen when I didn’t warm up in the morning . Like start engine and drive straight away without any warm up.
Old Jun 29, 2018 | 12:50 PM
munis's Avatar
2021 Mercedes C63s AMG Coupe
Is your garage parking on an incline? If so the gearbox can get pre loaded in parking gear. Then when you shift to D or R, it makes a rattling noise.
Old Jun 29, 2018 | 12:57 PM
gamoon's Avatar
Foot on brake release "park" brake first then into gear never any noise. I found myself putting the car in gear then release parking brake and crunching noise would happen.especially when on an incline.
