C63/C63S AMG
Burger Motorsports 2018 C63 Dyno Testing
Old Dec 31, 2018 | 10:46 PM
  #301
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
Originally Posted by Gbango
Have the jb4 installed on my c63s .Finally figured out the bluetooth connection and was able to start logging . Seems stronger already on map 1, however trying to figure out the bugs with map 2 and 3 . Check engine light comes on after driving around on map 2 or 3 and has no power at all and barely will get up to speed. So far, the trick is to clear the codes and switch back to map 0 or 1 .
Uodate**
So the car will run rough after a few minutes and cut our power and turn off .have to turn off the car, clear codes, turn on and it will go a few blocks again before reoccurring
So far we've got around 20 C63 systems out and running perfectly. I'm sure we can get you sorted.
It's a bit of a skeleton crew around here right now for the holiday, but if anyone needs help just email jon@burgertuning.com some install photos and details if it's an issue coming up right after install, or a JB4 log and the codes (read via the app) if it's just coming up under certain conditions, and he can help you sort it out.
As a reminder during the BETA we suggest everyone, especially the S cars, stay on map1 until we've had a chance to review logs from your specific car.
Old Dec 31, 2018 | 10:52 PM
  #302
BMS's Avatar
BMS
2018 C63 Sedan
Originally Posted by Mr. Pink
Let me know what you find out. Had major issues when I installed mine so I have it all disconnected right now.
Are you Eddie with the C63S, ECU flash map, upgraded turbos, I was helping via email the other day? You've got a lot going on there with the car, it's a lot more complex than the JB4 only setups most in this thread will be using, so it's best handled via email. I don't think your transmission fault (that mysteriously cleared itself) is directly JB4 related since it came up on map0 (JB4 bypassed), but I provided you some next steps via email so we can troubleshoot it.
Old Dec 31, 2018 | 10:56 PM
  #303
BMS's Avatar
BMS
2018 C63 Sedan
Originally Posted by Andre Baracat
I’ve gotten mine but haven’t installed yet. It’s a ***** to install compared to other piggybacks but that is because the JB4 intercepts the sensors and MB hid those connectors very well.
have to admit I’m not very excited reading the last posts over here..
All C63 piggybacks are a headache to access the MAP connectors compared to say the C43. I have no idea why they made everything so difficult to reach on the V8! But after you've done it once it's really not too bad.
Old Jan 1, 2019 | 02:53 AM
  #304
Mr. Pink's Avatar
W205 c63s AMG
Wasn't a transmission fault, was more of a ghost limp mode.
And I know, my car and situation is a little more complex than most so I've stayed quiet and we'll proceed as we talked about via email. Definitely here to help further development on platform and jb4 because I see huge potential here for us with jb4 available, Just need to take careful baby steps to get there safely. Not here to talk bad or complain about anything, I know what I signed up for with beta stage for all of this.
We'll get back to it Wednesday or so sir! I'll shoot you an email
Hope you had an awesome new years Terry/Jon! (Not sure who uses this account)
Old Jan 1, 2019 | 08:41 AM
  #305
ezatnova's Avatar
2016 C63S
UGreat to see that BMS is supporting modded vehicle’s, vehicles stacking other tunes, etc. However, personally would have liked to see the first round of beta be concentrated in getting things dialed in and buttoned up on stock non-S and S models, then open up to more varied and complicated applications at a later stage.
Just hoping all the time and effort that will need to be spent getting things to work in very customized situations doesn’t sacrifice rock solid reliability and quality for the vast majority who will use this on a stock car...of that group likely mostly S models, and then non S’s as a slightly smaller subset.
Old Jan 1, 2019 | 11:19 AM
  #306
BMS's Avatar
BMS
2018 C63 Sedan
We're here and happy to help anyone who wants to jump in on the BETA, ultimately everyone is going to need to be working perfectly, from the 80% of the customer base who runs JB4 or JB4+intake only, to the 20% of the customer base that goes wild with other modifications like larger turbos, stacking with existing flash tunes, etc. I just don't want anyone here in the 80% group getting turned off whatever is going on with the other 20% that will never apply to them anyway.
Old Jan 1, 2019 | 08:53 PM
  #307
notabenex's Avatar
C63 W205 17' + W205 C250@brabus + NSX 95'
I still have warranty until 2021, so thats why i decided go jb4 instead of tune.
For service inspections is it better to remove the whole jb4, or just turn it off? Do the technicians see some cables of jb4 or not ? Thanks
Old Jan 1, 2019 | 09:34 PM
  #308
C3504matic's Avatar
2015 C63S ,DME Tune, KW Has ,Kmac Bushings,BC Forged wheels,Gt Rotors,Porterfield R4S,Modal Intake
Mercedes can easily tell if you had a piggyback even if removed by looking at different tables which record within the ecu
Old Jan 1, 2019 | 10:29 PM
  #309
BMS's Avatar
BMS
2018 C63 Sedan
Fake news, often spread around by flash tuners. The JB4 keeps the ECU thinking it's running factory power levels and tuning.
  #310
BMS's Avatar
BMS
2018 C63 Sedan
Best thing is always to remove it, if you're concerned about it and don't have a friendly relationship with the dealer.
Old Jan 1, 2019 | 11:06 PM
  #311
notabenex's Avatar
I have good relationship with the dealer.
Dealers here in EU are doing strong marketing for Brabus piggy
Old Jan 2, 2019 | 12:54 AM
  #312
C3504matic's Avatar
Funny you say that . I actually work for Mercedes and if requested due to an unusual failure we have to allow Mercedes Germany access via plugging them in and they will actually go into the cars ecu and search and I've seen them deny coverage and void warranties . Think what you want but if they want to find it they will .....
Old Jan 2, 2019 | 02:41 AM
  #313
FDNewbie's Avatar
'17 AMG S63 Convertible, '17 AMG C63S Edition 1 Coupe
From this thread: https://mbworld.org/forums/w212-amg/...ch-tune-2.html
Originally Posted by Astolfo
Also most all the logs do not come or are stored from what most people talk about ECU, they are in an 24GiB R1* NVMe logging facility which is independent of the ECU or TCU. If a parameter is out of specs it will be stored until the next diagnostic.
*32GiB for the GTs/r most F1s have a similar facility with 512GiB where still telemetry gets stored until they pit.
These NVMe modules are almost 2 times larger with the reserved cells used to replace faulty or worn out cells. if there is one part of the systems that is way over engineer are these facilities, not because the car manufacturer wants to spend more money but because this the cheapest commodity hardware that complies with the different regulations and running a nano version of a pretty well adopted OS as it does the TCU, the ECU has a different OS version.
And
Originally Posted by armansd
In my world (where we design and sell ASICs and ARM based CPUs), it is rather simple to detect modded Firmware.
All you need (for the techie guys CRC check) is a checksum calculation on NVRAM (FLASH Memory side) where a pre-calculated (non modified version) is stored
and encrypted on NVRAM itself using each CPU's internal ID as its key. Basically, upon power up or reset, the first thing the program can do is to complete a checksum calculation and compare it
to the prestored value and if not a match, it will make a note somewhere and when connected to an external diagnostic it can report it.
Basically, any time a tuner changes values in the base tables (not the trims for those familiar with OBD-II protocol), this will cause a change to the checksum :-(
hence, a detectable ECU. The epoc based encryption(mentioned by Astolfo) to head quarts etc may be done to download and verify new FW versions, but I doubt is done every time MB diagnostic system
(STAR) is connected to a single car.
Old Jan 2, 2019 | 12:06 PM
  #314
BMS's Avatar
BMS
2018 C63 Sedan
Originally Posted by FDNewbie
Yes exactly why a piggyback system properly done is not detectable, while a flash map always is, even if flashed back to stock later.
Old Jan 2, 2019 | 01:21 PM
  #315
FDNewbie's Avatar
Maybe I misunderstood. When they say that NVMe logging facility is independent of the ECU or TCU, and it logs parameters out of specs, I'd assume a piggyback manipulating values out of spec, be it by the output it's providing, or by the power/torque/boost values its deviating from stock, would generate a loggable out of parameter event.
From the same thread (next page):
Old Jan 2, 2019 | 01:40 PM
  #316
BMS's Avatar
BMS
2018 C63 Sedan
Flash maps directly change tuning parameters and anything out of spec is recorded. A good piggyback like the JB4 on the other hand, by nature of how it has to work to perform it's tuning, can't change any factory parameter. The ECU has to think everything is 100% stock for the piggyback to work properly.
We offer tuning for VAG models and it's the flash maps that leave the GT1 warranty void fault behind, not the well designed piggybacks.
Old Jan 3, 2019 | 11:53 AM
  #317
achi 3.0's Avatar
C63s Cabrio
Whats about some new dynos? Maybee from a C63S.
Old Jan 3, 2019 | 02:52 PM
  #318
FDNewbie's Avatar
Thanks for the clarification!
Old Jan 3, 2019 | 05:33 PM
  #319
BMS's Avatar
BMS
2018 C63 Sedan
Hey guys,
Found an issue with some of the C63 BETA systems shipped. There is a resistor on the JB4 control board that needs to be soldered over. If it's not, you may get a check engine light, mismatched bank to bank fuel trims when looking at JB4 logs, etc.
Photo attached to identify the issue. There should be a wire soldered across the resistor as shown.
If you're missing the wire then we've got the following options for you:
1) Leave the fuel pressure connections stock for now, leaving the rest of the JB4 plugs attached. Fortunately they are relatively easy to reach connections.
2) Email me @ terry@burgertuning.com and I can send you a replacement JB4 control board which attaches to the JB4 harness.
3) If you're handy with a soldering iron you can add the missing wire yourself.
Old Jan 8, 2019 | 02:37 AM
  #320
notabenex's Avatar
Succesfull install anyone??
Old Jan 9, 2019 | 12:30 PM
  #321
BMS's Avatar
BMS
2018 C63 Sedan
Been working with quite a few guys via email with good success, hopefully you start seeing some of them post here soon.
Old Jan 9, 2019 | 03:28 PM
  #322
spikiii's Avatar
2025 AMG GLC63S E Performance | 2021 AMG GLC63S (retired) | 2017 AMG C63S (retired)
waiting for replacement board, once that's here will get right on the install
Old Jan 10, 2019 | 09:06 PM
  #323
AlexZTuned's Avatar
2017 Porsche 911 C4
Have you worked with anyone running upgraded turbos and just JB4 (no back end ECU flash)?
I’d love to throw on a set of bigger turbos I have laying around, but don’t want to ECU tune the car. And boost by gear is a must have for me, as I’m sure you’ve discovered with stage 1!
Old Jan 10, 2019 | 09:13 PM
  #324
BMS's Avatar
BMS
2018 C63 Sedan
Most of the larger turbo cars we're working with already have a flash map, and are looking to fine tune it. If doing large turbos I'd suggest the same route. Some sort of a flash to at least get it closer then we can fine tune with you on the JB4.
Old Jan 10, 2019 | 10:24 PM
  #325
AlexZTuned's Avatar
2017 Porsche 911 C4
Good to know, sounds like an OBD-II flash would be in my future... I assume boost by gear still works with flashed ECU's?
I'm curious what other features are in the works, an adjustable launch control would be awesome.
