C63/C63S AMG
Switched headlight power for illuminated star?
Old Aug 19, 2020 | 10:22 PM
Jkcrewsn's Avatar
2017 AMG C63s Sedan, VW MKV R32 #4568, 2001 E46 M3, 2015 F350 Super Duty
I have searched and searched, and can't find an answer to this problem. Car is a 2017 C63s.
Is there a switched fuse to power an illuminated star in the engine compartment fuse box that will only power it when the headlights are on? I have tried the headlight fuses (yes, both sides) and the star never turns off. I would like for it to only come on when the headlights are on, not the DRL's, or always on. I really don't want to tap one of the headlight wires, but it is starting to look like the only option.
Anyone have a suggestion?
Old Aug 19, 2020 | 10:35 PM
Jimmy_c63s's Avatar
If you need to just splice it into your headlight DRL.
Do you really want your Star to illuminate? Can you just go without? I think illuminated stars are a bit tacky (no offence). Especially on an AMG. A Maybach....... maybe. But not our cars man 🤮
Old Aug 19, 2020 | 10:42 PM
Jkcrewsn's Avatar
Hahaha, I wouldn't disagree with you. Hence my reluctance to splice into the headlight wire! Also the reason I only want it on when the headlights are on. However, I got a good deal on one and so thought what the heck. Also, the GF saw one and thought it was cool. So......
Old Aug 20, 2020 | 03:12 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
[QUOTE=Jimmy_c63
Do you really want your Star to illuminate? Can you just go without? I think illuminated stars are a bit tacky (no offence). Especially on an AMG. A Maybach....... maybe. But not our cars man 🤮[/QUOTE]
Agreed. I wouldn’t put It on my car even for free.
Old Aug 20, 2020 | 11:45 AM
Jkcrewsn's Avatar
Apparently you missed the part where I'm getting paid to put it on.
In reality, I try lots of different parts on my cars. Not all of them stay on.
I'm also quite interested in the engineering side of why the headlight fuse doesn't work as a switched power source. I'm guessing that in a modern car, the power for the headlight is always on through the fuse and an electronic switch bypasses the fuse to tell the headlight to come on? I'm obviously not an electronic engineer.
Old Aug 20, 2020 | 11:51 AM
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
Its a bit more complicated then that, there are parts of the system that stay ON for different periods of time after the car is shutoff etc..I know that most aftermarket luminated stars put on 2016+ C63's have had issues with getting the turn on and off based on just the headlights etc..
I spoke to one person, and his star will stay on for over 5 mins after the car is turned off and locked, and sometimes it pops on or messes with the headsup .. so he disconnected it.
Apparently has to do with voltage pull, and some other items in the system. (for lights, etc)
Old Aug 20, 2020 | 12:02 PM
Jkcrewsn's Avatar
Thanks for the input! It's definitely not straightforward. There are some videos online of installing an OEM star, and there is a spot on a multi pin connector for the hot wire to be inserted. I'm just not that committed to this project to do it.
Old Aug 20, 2020 | 12:17 PM
FLC63s's Avatar
I hear ya.. if someone knows that PIN location, it would be nice to have..
Old Aug 20, 2020 | 12:43 PM
AMGMD's Avatar
2012 C63 Coupe P31 OE Tuned/ROW Airbox/K&N filters/Quaife LSD/MBH LTH, Race Cats, Midpipes, Xpipes
https://mbworld.org/forums/c-class-w...-star-diy.html
I installed this on my car a whiles back. I remember it being really easy. Check out the link above, looks similarly to what I remember doing.
Old Aug 20, 2020 | 12:54 PM
Jkcrewsn's Avatar
You beat me to it. I was just outside verifying that our fuse block is the same as in this DIY before I posted the link. I see it says that the star is always on when the car is on, is that the case for you?
Old Aug 20, 2020 | 01:03 PM
AMGMD's Avatar
Mine only turns on when the headlights are on.
Old Aug 20, 2020 | 01:04 PM
Jkcrewsn's Avatar
Oooh, interesting.
Old Aug 20, 2020 | 01:18 PM
George_1992's Avatar
C63 S Coupe
What does that even mean?
Mate don't worry about what your gf thinks is cool. You drive an AMG. She needs to recognize.
Please don't do it......... Unless you're doing the rear badge too, then you can be mates with this turkey 😂
Old Aug 20, 2020 | 08:54 PM
Jkcrewsn's Avatar
Hahaha, yeah, I've seen those on ebay for our cars. I would do it, but I don't want to have to drill a hole in the trunk. Oh well.
I guess I'll just have to ditch the illuminated star and go finish the under body neon kit I've been working on.
Old Aug 21, 2020 | 08:18 AM
FLC63s's Avatar
I detailed my engine bay ,and then cleaned my AC filter... should I add the star ?? :-)
Old Aug 21, 2020 | 08:47 AM
Cerealcreep's Avatar
2020 C63s coupe
Smile
Now that is funny af!
Old Aug 21, 2020 | 09:01 AM
FLC63s's Avatar
Old Aug 21, 2020 | 09:45 AM
Jkcrewsn's Avatar
Sweet job on the AC install! Do you have a link for the DIY? I'm guessing you used the headlight fuse for your switched power source?
