High Speed Vibration
Hello all!!!!!!!! I am sorry if this was answered somewhere else, but I could not seem to find anything on the topic. Getting back to the main point, I am noticing a vibration throughout the car (not steering) when I'm at speeds above 60-70mph. I also noticed heavy vibration above 115mph, feels like an out of balance wheel. The thing is, I got a new set of tires installed this year and still noticed it, also all the wheel weights are in place and did not fall off. Does anyone have an idea on why this would happen?
EDIT: Also, not too sure if this will make a difference, but it's a very high-frequency vibration. The best way to describe it is to say it's like going over very soft rumble strips at around 60mph.
Received 3,857 Likes
2019 C63CS
There can be several different reasons for this. From worn suspension parts to unfavorably mounted tires. Did you have the new tires road force balanced, or just high speed balanced? The former simulates road force and makes sure the high and low points of the tire/wheel combination are properly matched to avoid vibration. It's pretty much a must with low profile tires. Regular balancing just makes sure the wheel spins freely without vibration, but it doesn't detect high and low points that cause an issue once you are actually driving on the road. Road force balancing will also identify tires that got damaged during transport or don't quite meet the specs from the factory. It's not uncommon for tires to get damaged during shipping, specially if they are bounced on the ground while unloading from the truck. Tires don't like that and the belts can actually be bent that way w/o the wheel and air pressure providing the necessary support.
It could also be from a bent rim. Did you happen to hit any large potholes or gaps in the roadway during your ownership? It's also possible a prior owner (if you bought used) may have damaged a wheel. A good wheel shop should be able to check that out for you, as well as road force balance the tires, to eliminate that as a possibility.
700HP Facelift converted PFL C63 S Coupe
Two things are causing this. Either:
• Your wheels need to be balanced and aligned
• Your wheels are cracked or buckled
Unfortunately these "forged" AMG wheels are very weak. I've repaired mine for cracks TWICE and I'm onto my 2nd set for my coupe. I'm hoping your issue is just balancing and alignment so please have those two things addressed first and let us know how you go.
Make sure your tire pressures are at least 38psi on the fronts. Never go lower or you will get cracks 😕
Any questions about alignment or wheels, i've been through every experience with these cars.
AMG themselves recommended 38psi front and 36psi rear for coupes (as posted by Sanch, here).
Nope, not at all stiff. Anything over 40psi can be a bit stiff and "crashy" on bad roads but still not too bad.
Good to hear you've pumped them up, they will feel harsher but you'll be protecting those wheels from cracking or buckling.
Day or night, grab a torch and check the wheels, especially the two front wheels, the bottom of the spokes where they join the rim for any cracks or buckles.
Let us know how you go with the vibrating issue 👍
Cool. Yeah 34psi is comfortable but for our OEM wheels, it's risky. I guarantee you running those pressures on the fronts will get your wheels bent or cracked if you hit one of those bad potholes.
In my experience, most places do a cap job at balancing wheels. I remember having this issue with my 16 GL550 and I had gone back to the dealer 3 times for vibration. They ended up sending it out to a third party who had a better tire balancing machine. Viola, problem solved.
I would go and call around some high end tire and wheel shops.
Jimmy_c63s (10-16-2020)
I do think the higher pressure helped a lot, did not seem to feel much at all, but I think I still felt it. (It was a very short drive) I will assume the tires are not properly balanced and check that out, I do not think I have any bent/cracked rims though.
2019 C63CS
