C63/C63S AMG
C63 coupe Mercedes star emblem removal
Old Nov 5, 2020 | 12:28 AM
GilsE63s's Avatar
2018 GTR
Fellow AMG folks, I had my badges replaced with black ones today, except the shop couldn’t remove the Mercedes star on the back. The others came off easily but this rebellious star didn’t budge, even with heat gun, they just couldn’t get the wire to get behind it to break the adhesive. They didn’t want to be too aggressive since the camera is attached to it.
Any idea of what I can do now??
Old Nov 5, 2020 | 08:02 AM
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
If I remember correctly, its the assembly, I dont know if that star is ONLY mounted with 3m adhesive.. (I could be wrong) but I just remember ready something , sometime that makes me think it was different...
Old Nov 5, 2020 | 10:26 AM
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
Research this. I believe I had seen something on this stating you might need to get to the back of the emblem from inside the trunk.
Mine was different since it was attached to the backup camera.
Old Nov 5, 2020 | 10:52 AM
FLC63s's Avatar
Hitting the bottle early Bruce ?? j.k lololo :-)
Old Nov 5, 2020 | 12:24 PM
///Bruce's Avatar
Actually you are looking at almost a quarter million dollars associated with those two keys.
Old Nov 5, 2020 | 12:49 PM
Encore818's Avatar
2019 C63S Coupe, 2020 G550
The star in the rear is held in by adhesive on the outer edge and three pegs near the center. I don't think it can be removed with heat and floss/fishing line.
This is the way I did it, at a certain point you'll have to decide how to finish it off. In trying to remove the star from the camera cover I scratched the paint had to get that whole piece repainted. So all I can say is don't try to use a flathead screwdriver to lift the circle around the star up.
Somewhere in the infotainment screens you can open the camera. Do that.
Between the camera cover and the camera assembly there should be two small cutouts each of which you can place a finger in. Squeeze and then either slide up or down (sorry I don't remember) and pull. I had to squeeze reallyyy hard. Now you should have the white circular camera cover in hand.
From this point, do whatever you can to safely get the cover and emblem separated. I used a small screwdriver to push the pegs through. The adhesive around the edge of the emblem was my biggest issue and is what caused the scratch. But like I said, I didn't do it perfectly, and there is no right answer. Goodluck!
Old Nov 5, 2020 | 01:22 PM
FLC63s's Avatar
@///Bruce ?? and ? was the directed at me from my comment ?
Old Nov 5, 2020 | 01:28 PM
Encore818's Avatar
I was wondering why the photo was shared in the first place actually lol
Also, in scrolling down this thread, I found a similar thread which goes into more depth with more photos.
https://mbworld.org/forums/c450-c43-...val-coupe.html
Old Nov 5, 2020 | 02:48 PM
RaceTank's Avatar
GLE63s C63s S560
plastidip
Old Nov 5, 2020 | 02:57 PM
///Bruce's Avatar
yeah...
Old Nov 5, 2020 | 03:01 PM
///Bruce's Avatar
I started having the same issue with my camera star. I tried floss. Wound up using an exacto knife. It was then enough to break it off piece by piece. Then a little Brakeclean. Washed it good then pressed the new one on. Scratches are very possible. You must be very patient.
Old Nov 5, 2020 | 03:34 PM
FLC63s's Avatar
yeah...
ok well in that , I guess your drinking champagne because you have almost 250K in cars ??
TBH, from most of your post, I wouldnt have expected something like that from you ( stating that its almost 250K worth of cars)
I mean, I know I dont care, as I didnt think it was a pissing contest, but I have 1 key that tops both of those plus add 150K more...
So I guess I will go take a pic of some OJ, and we can have mimosas
Old Nov 5, 2020 | 06:19 PM
///Bruce's Avatar
My wife ordered her car last August and took possession a week before Christmas. It was a small celebration for her. She earned it.
To your success, I say congratulations!
Old Nov 5, 2020 | 06:29 PM
deftronix's Avatar
17 C63S coupe
We went over it pretty in depth on this thread as well. Floss & heat worked for me -
https://mbworld.org/forums/c63-c63s-...ck-badges.html
Old Nov 5, 2020 | 08:51 PM
GilsE63s's Avatar
2018 GTR
Success folks, thanks for everyone’s feedback.
1. was able to remove the flap by depressing the tabs on the backside, used a flat head screwdriver one side at a time, it’s a bit tricky
2. Used wife’s hairdryer to heat it up for a minute
3. Tried using fishing line and while some was able to get tucked in there it was awkward and difficult to maneuver effectively so..
4. Used exacto blade and carefully worked it around circumferentially, slowly, ensuring not so scratch paint, once I was able to easily go around a few passes I started to rotate blade bit by bit moving all around in small increments to wedge it off. And finally was able to pull it off
5. Used fingers then goo gone to clean up remaining adhesive. then popped on emblem and reinserted onto car
Old Nov 6, 2020 | 08:04 AM
FLC63s's Avatar
Awesome !! congrats
Looks great!
Old Nov 6, 2020 | 08:08 AM
FLC63s's Avatar
Thank you.. I work hard..
I guess we were just all confused as to why the photo was posted with the conversation at hand, and that is the reason I responded that you must of "hit the bottle" early... ( as stated j/j <- = Just Joking )
Thats a GREAT x-mas present for sure, hope she has been enjoying the heck out of it.. (even thou covid restricted some things) Cheers
Old Nov 6, 2020 | 03:05 PM
///Bruce's Avatar
My wife turned 68 last August! It’s her third one. Each one has been faster than the previous one. Frankly she’s a great driver. However I will admit driving and riding has a different effect on my nerves. 😄
In progression...
I apologize if it gives the appearance of high jacking this thread. So, back to the rear star, finished product.
If you zoom in real close you’ll see a small scratch at the top of the star. It was a bear getting it off. But worth it.
