C63 M177 - Stage 2 Tune - What Spark Plugs?
I am now running a decat with Stage 2 tune on my car:
The spark plugs are 'old' (10k miles) and need a change to help with the new tune.
Any recommendations on what plugs to use?
Are there any 'step colder' plugs that work well with a stage 2 tune?
I found this:
https://mbworld.org/forums/w212-amg/...k-95770-a.html
Does any one know the correct part number for oem plugs? Maybe colder plugs as im on euro charged stage 2? Do oem come pre gapped @ .025?
As for oem is this the correct plug?
000-159-05-00
EDIT
I just talked with MB over the phone 000-159-05-00 is the correct part number for oem plugs.
This must be the one!
Champion Double Platinum Plug Number KEC4PYPBF-1 Spark Plug
- Heat Range: 4
Champion 4 is NGK 9
**Unfortunately** these Champion plugs have 14mm thread and are matched according to Champion website.
This Champion 7600 is one step colder if in fact the stock plug is NGK SILZKFR8F7S which the same heat rating for Champion 9069
Champion Iridium Plug Number KEC6WYPB-1 Spark Plug
... and BRISK QR12LS
Searching NGK website I found...
NGK 93253 R2556G-9 Racing Plug
I inquired with NGK to find out if these or another one step colder plug works, and also if ignition coils need to be swapped for these plugs.
If I get a response I'll update.
I'm not there yet. I'll give these a try after I install Pure 900.
https://www.premiertuninggroup.com/p.../000-0409-1773
000-159-05-00
EDIT
We have the HKS plugs in stock as well
Just check that it's not caused by coil packs. Have you had the coil packs changed since owning the car? If so, you can rule that out.
The misfire has only happened once and I was on the track when it happened, about 3/4 through my session.
2019 with 30k miles.
. MB Dealership replaced Coil Pack 5 and 6.
. NOTE: Coil Packs are warranty by Dealership till 100,000 miles. So no charges. They had my car for a long 2 weeks
. I also noticed they replaced a spark plug which may have been installed incorrectly.
. It so noticed they replaced a spark plug which may have been installed incorrectly.
