Fitment help 20 inch
Hi guys.
I know this subject has been mentioned a thousand times over.
I have a c63s w205 2015 sedan/saloon
im looking at buying the 20 inch ferrada fr2
speaking to someone they have given me 2 options.
Set 1- 20x9 et 35 front 20x10 et 45 rear
With 5-8 mm spacers
Set 2 -20x9 et 23 front 20x10.5 et 38 rear
no spacers needed but will poke out 5-8mm
im looking for max concavity/aggressive look.
but want no rubbing.
so was thinking maybe a lil stretch on the tyres on set 2 to avoid this?
can someone help me with what I might really expect if I go for set up 2? Or even if it will be a noticeable poke? Camber adjustments?
im
currently on stock suspension and height.
if it’s to much hassle I’m just going to settle for set 1. But really want a aggressive concave look
thanks in advance!
With 5-8 mm spacers
im
thanks in advance!
Neither set fits properly. Set 2 is a simply wrong. Set 1 front is fine w/o spacers, Set 1 in rear even without spacers pokes a little too much and would look awkward even if you use stretched tires to make it not rub. Spacers make it worse not better. Whoever gave you that advice .....
I don't remember if you can custom spec Ferrada's but look to get +55 on 10" rim in rear.
Here is my spec to compare
20x9.5+35 - 265/35
20x10.5+57 - 285/35
Stretch is not a great look on our cars and for sure not beneficial for handling/cornering.
PS: Due to high offsets on our wheels you will not get much concavity, period.
20x9.5+35 - 265/35
20x10.5+57 - 285/35
20x9.5+35 - 265/35
20x10.5+57 - 285/35
20x9.5+35 - 265/35
20x10.5+57 - 285/35
this is probably the most depressing thing for me as I don’t understand offsets etc and I’ve finally found alloys that I like and I can’t get the figments right! And I don’t think Ferrada do custom spec either I’ve been emailing everyone for the last 4 weeks and everyone has given me different fitments.
I really don’t know what to do as it is a lot of money if it turns out wrong! Shame we don’t have a place in the UK that does test fitting either!!
Long shot but from your knowledge what offsets would be the best for our cars that Ferrada offer?
also Yu got a pic of your wheels :p
look here and punch my spec in as reference and play around with the wheel spec you see an you get a feel for it.
https://www.rimsntires.com/specspro.jsp
important to add the proper tire spec as tires rub on your fender or suspension (assuming no extreme stretch) and not the rims. I recommend you don’t want to poke more out on fender than the spec I listed above (maybe another 1-2mm is fine but not more).
If not Ferrada than there at a plenty of companies who offer custom spec and are priced reasonable. I use BC forged and opted for 2-piece design. The single piece can be had for cheaper, more like FR2. HRE flow forged are also a good choice and you can get some good deals. Than look at Titan7. I just picked up a pair of Titan7- T-S5. Single piece forged and very lightweight all considered. I am pretty impressed with them. First time I have them (different car). Or hit up some of the vendors here and they can help you pick a set that fits too and have other brands like Vossen, Blackdiamond etc).
OsmanR (06-18-2021)
I’ve run forgestar’s and adv.1’s on my vehicles for the past 15 years. HRE is also another reputable brand to look into.
Like tobiet I just put a set of BC Forged on after months of searching. We talked stance more than anything and they ran with it. The offsets came out perfect IMO. Like everyone here is saying primarily the better companies know what they're doing and will get you right.
what offsets did you mange to get? Pics
