C63/C63S AMG
Who's at stage 3?
Old Jan 6, 2022 | 11:31 AM
Raheelssj's Avatar
C63 w205
Who's at stage 3?
Any c63 stage 3 turbo upgrade builds on here?
Old Jan 6, 2022 | 01:58 PM
Fishy22's Avatar
2017 C63sAMG
Not sure if this is considered stage 3 but I have PTG1000 turbos and tune Redstar catless down pipes AWE track exhaust
Old Jan 6, 2022 | 02:11 PM
Raheelssj's Avatar
C63 w205
Damn what are you running and what's your set up?
Old Jan 6, 2022 | 02:19 PM
Fishy22's Avatar
2017 C63sAMG
Originally Posted by Raheelssj
Damn what are you running a dn what's your set up?
not sure what you mean by dn . 🤷‍♂️
Old Jan 6, 2022 | 02:35 PM
Fishy22's Avatar
2017 C63sAMG
Old Jan 6, 2022 | 04:27 PM
noremaC's Avatar
17 C63S Coupe PTG1000
Running a similar set-up as Fishy22, minus the AWE track exhaust. On Michelin PS4S (295 rear) can spin to the top of 3rd gear, if the tires aren't fully warmed up (and sometimes even if they are).
The next step after these set-ups is additional fueling, which is typically meth. The downside is it's not a great set-up for a daily driver.
Working on getting a dyno session soon but have been told to expect 650-670whp on 93 octane.
"Big Turbo" set-ups like the PTG1000's, the ECU tune moves the power curve over ~2k RPM, to about 4-4.5K RPM, so it's definitely a different feeling from a stock (or "stage 2") C63S when the boost comes on.
Hope that helps.
Old Jan 6, 2022 | 04:55 PM
AMGMD's Avatar
2012 C63 Coupe P31 OE Tuned/ROW Airbox/K&N filters/Quaife LSD/MBH LTH, Race Cats, Midpipes, Xpipes
Anyone have 60-130mph dragy times?
Old Jan 6, 2022 | 05:20 PM
noremaC's Avatar
I don't yet but it's on the list of things to do/get. If I had to guess, I'd say I'm somewhere in the 6's but it's hard to tell.
Old Jan 6, 2022 | 07:02 PM
PayKoHan's Avatar
AMG C63S T-Model
I have too Stage3, TTH880 Turbos and catless Dp. Around 800Ps/1000Nm and 5.2s 100-200km/h.
Old Jan 7, 2022 | 12:50 AM
zipzap's Avatar
W205 C63s 2015
Stage 3
I'm like most of the guys above
PTG1000 turbos
Catless downpipes
Spool HP pumps
Weistec intakes
Aquamist water meth
Best 100-200kmh time I managed was 5.10 with traction issues, im running 295 R888R's and it still roasts them.
Unfortunately where I live the fuel is crap so there definitely will be faster guys out there with the same setup.
I'm waiting for a decent in tank upgrade fuel pump upgrade to come out so I can run higher E fuel blends
ZAC has rumored they are developing a split cooling system that's going to be more affordable than the 3000USD PTG system , so waiting for that also
Old Jan 8, 2022 | 01:32 AM
deanoo's Avatar
2019 C63S
PTG 1000 Turbos
Downpipes
Meth Kit
Zac Intakes
Currently at 715WHP
Car needs to go back for a CPC module but thinking maybe to replace the exhaust with a AWE track version before it goes back on the dyno
Old Jan 8, 2022 | 09:38 AM
noremaC's Avatar
Originally Posted by deanoo
PTG 1000 Turbos
Downpipes
Meth Kit
Zac Intakes
Currently at 715WHP
what meth kit are you running? this your daily?
Old Jan 8, 2022 | 10:57 AM
AMGMD's Avatar
Also curious to see what methanol system everyone is running. Are you tuned for methanol using it for extra fueling or just using it as a cooling/octane booster? ZIpzap how is your experience with the spool HPFP? How involved is the install and where they difficult to dial in? I see you have methanol also, what system are you using and would you recommend it? I'm still on the stock fuel system and looking into methanol kits vs Spool HPFP as my next upgrade. Appreciate any insight, thanks!!
Old Jan 8, 2022 | 11:46 AM
deanoo's Avatar
2019 C63S
Its a aem meth kit with a custom tank in the engine bay
No its not my daily but it can be be driven as a daily
Old Jan 10, 2022 | 11:42 AM
will11's Avatar
c63s
2017 c63s
Right now I have pure1000 turbos running a conservative 93 meth tune makes 730whp . best time is 5.93 but it does 6.0-6.05 almost every time. I roll into it from 3rd vs 2nd. r888rs do great above 45mph for me. Just installed spool hpfp and lpfp gonna take it back for e50 tune hopefully shoot for 850-900
Old Jan 10, 2022 | 12:17 PM
noremaC's Avatar
sub-6 seconds is MOVING!
I'm super curious about the meth set-up you (and everyone else) has.
What are the basic costs and level-of-effort to implement (kit cost and install effort) and run meth (do you just buy by the gallon)? I've never seen or built a car with meth injection so curious about the process on this platform (i.e. pros and cons).
On top of 93oct, it seems like meth can gain you a good 50-75whp extra. Is that a fair statement?
Old Jan 10, 2022 | 01:22 PM
will11's Avatar
c63s
I did the burger motorsports meth kit. it was $800 but you will need to buy your own controller for it if you don't have a jb4 installed. I have a snowvc50 for like $250. A lot of people use the weistec trunk kit its about $1500. Did all install myself probably 6 hours of labor total. 50-75 is probably a safe range for sure. Also use boost juice its 50/50 water meth and can be bought anywhere online
Old Jan 11, 2022 | 12:45 PM
raphman's Avatar
'16 C63s
For you guys running WMI kits, are the hp increases due to a custom tune for utilization of the WMI or as a result of reduced intake temps?
Old Jan 12, 2022 | 03:18 PM
will11's Avatar
c63s
Yes you have to tune for it to get any substantial gain
Old Mar 29, 2022 | 08:58 AM
will11's Avatar
c63s
Made 850whp 774 wtq on e50 with the spool fuel system added on. Car runs 5.44 60-130 now
Old Mar 29, 2022 | 02:03 PM
SJGetsome's Avatar
W205 C63 AMG Coupe
Impressive numbers and time. How is your transmission holding up?
Old Mar 29, 2022 | 03:52 PM
will11's Avatar
c63s
It was slipping before this power so I upgraded to Blackboost clutches
Old Mar 29, 2022 | 04:57 PM
SJGetsome's Avatar
W205 C63 AMG Coupe
How many miles on them so far and how are they holding up? What made you go with them over some of the other brands out there?
I don't know anything about that company, so I'm genuinely curious.
Old Mar 29, 2022 | 09:44 PM
AMGMD's Avatar
That’s fast!! I’m on the stock fuel system, no meth, running 93 octane and my best 60 to 130mph was a 6.31. Your car is moving!! Congrats!!
Old Mar 29, 2022 | 11:12 PM
Gencheezy's Avatar
2015 C63s Edition 1 Sedan
any chance you got an IG?
