Newbie wheel question
https://tiresize.com/comparison/
https://www.tyresizecalculator.com/t...ize-calculator
https://www.wheel-size.com/calc/
WRT traction control, if you figure that new/wearable tread thickness is 7-10 32nds of an inch and do the calculations, you'll find that a tire's rolling surface (circumference) can vary by 3-5% (depending upon size), just from tread wear. Thus, traction-control systems MUST be able to take this much variance into account (in spite of what many shops will tell you).
The rear offset will work but for the front you want around ET 30 . If the car is lowered the 10.5 may rub the bumper where it meets the 1/4 on some drops in the road . I ran +57 and it hit but then again my suspension was lowered , stock height it will clear no issues
The Enkei I used to run was 9j et25 and 10j et45, the bbs e88 I am running is about the same fitment but the rear is 10.5J
https://mbworld.org/forums/c63-c63s-...x-bbs-e88.html
Look at the amount of camber you're running in the front lol . Thats only way that will work . I had a KMAC kit installed to stop tire wear and that offset would have hit the fender . I ran +52 w/ 10.5 in the rear the first set and they hit and I didn't even have anyone in the rear so they made me a new set at +57 and never had an issue with that offset , I can't even imagine a +45 . It would be okay on flat roads with no dips and no one in the rear thats it . On mine you could clearly see where they were rubbing with the +52 but than again I was running 20's with a taller tire for ride quality
If u have a coupe my friend has H&R lowering springs and 305/30/20 ps4s on the rears but that didn’t fill up the entire space.
thanks
To be honest I don’t know. I have stock 19 in cross-spoke rims. I know for these rims biggest size your technically able to run is 265 and 295. Any bigger, big name tire shops will refuse to mount the tires.
Based off google I think they are et38 and et56 but don’t quote me on that.
