Leaking injectors
To catch it early you'll notice not only the Check Engine Light but your ECO start stop button won't illuminate green anymore and be totally disabled. Another reason why you shouldn't be tuning this function out. Sadly, a lot of tuners will tune it out and some will never know until it's too late. Couple of guys here in Sydney grenaded their M177's due to injector playing up
To catch it early you'll notice not only the Check Engine Light but your ECO start stop button won't illuminate green anymore and be totally disabled. Another reason why you shouldn't be tuning this function out. Sadly, a lot of tuners will tune it out and some will never know until it's too late. I know of two guys here in Sydney who grenaded their M177's due to just one injector playing up and they both had the ECO start stop tuned out and ignored CEL's.
In 3 years my pfl will be 10 years old so the very early models are getting on now 🙁
But there's tips and tricks that we can all share to minimize our downtimes for those who still want to run these cars and one of those tips are not to tune out the ECO Start/Stop as that little green light serves as a warning system if an injector is dying.
i had my e diff replaced under warranty around 40,000 km so hopefully thats one thing i dont have to worry about
what made you change your engine mounts? What symptoms did you get? Thanks
Nothing obvious at the start but thumping noises on takeoff and suspension always stiff if I put it in Sport mode and switch back to Comfort it wouldn't loosen up again
clogging and carbon build up,. Also part of the B Service includes VPS Fuel Injector cleaner $13.90 part# 891566. that just get put into the gas tank which should be a full tank o gas.
My car was running fine when I brought it in but after the Service it had felt more powerful smoother ride that was ready to really open up.
I had one leaking on bank 2... no cel! no misifres.. no hickups... but still leaking... since pressure was dropping to quickly... plugs was black as fck on cyl 7....
But yes as I said, injectors can get clogged due to bad fuel quality such as debris in the fuel or a driving style that promotes carbon build up, or not using Top Tier fuel.
HPFP has been revised on the FL models.. hence ending part nr on 501 instead of 401.. injectors have been the same from day one...
You cant compare theses injectors anymore to years ago... these babies run on around 200 bar pressure... thing s will just go eventually....
.I had three leaking on bank 1... car started crappier, slight misfires occasionally... car was hesistant on full throttle... car was also fuming on full throttle out of the exhaust.. so if people dont feel that.. they are stupid!
fuel pressure dropped quicker then a blink of an eye when engine shutting off....
the last one one on cyl 7 , was just one... car runs perfectly fine!! couldnt be noticed for now.... i did plugs and saw it... plug was all black.... and had error message fuel presssure was low... did live log and it lost pressure way to quick when engine shutting off..
So if your having a leaky injector it doesnt mean your gonna experience the big boom.....
Leaking injectors are easy to be diagnosed... pull plugs.. .have a look... if black ---> 90 % leaking injectors, car also started less aggresive then normal...
Also do a live log , pressure shouldnt drop quickly after turning off car... and youll get the low fuel pressure bank 1 or 2 and you cant erase code...
ive talked to a few specialists now and its a common thing with the "modern" injectors running at 200 bar .. . BMW has the same problems .with their ****ty injectors..
We have big plus... and that is that our injectors are used on all common normal MBs as well....!!
