C63/C63S AMG
Exhaust flap issue w/ power loss
Old Feb 19, 2024 | 11:51 PM
BenzAMG99's Avatar
C63s
Hello, I’ve been searching for hours and haven’t really got anywhere.
I have a 2017 c63s that’s got DP and DME tune.
I was originally dealing with a problem on the exhaust flaps not operating correctly, when pressing the PE button inside to open the valves it would close instead and vise versa. This would make the ECU close the flaps top end causing it to cut boost due to three restricted air flow.
The actuators were after market since it came with the AWE catback (purchased the car as is)
I decided to purchase 3 OEM AMG valve actuators off eBay that were on a 2020 for 3k miles.
After installing the rear 2 and turning the car on, I get nothing at all now.
PE button turns red but the flaps won’t engage open or close, just stays open.
I plugged in scanner and received two codes,
1) Exhaust flap 2 has an electrical fault or an open circuit.
2) The exhaust flap has an electrical fault or an open circuit.
Now I’m dealing with severe power cut top end past 5k rpms where it’ll drop to 350hp on gauge.
my plan is to try and put back the old actuators to see if it’ll work again,
but is there anyone that have some tips or can point me to the right directions?
Thanks in advance!
Old Jun 5, 2024 | 04:20 PM
LR63s's Avatar
C63s W205
Any updates ? I’m dealing with this code and a rattle.
Old Oct 5, 2024 | 10:13 PM
Zuby's Avatar
C63samg w205 edition 1
Got the exact same issue tried putting new actuators in doesn’t seem to do anything presuming there’s a fuse somewhere although mine says exhaust valve 2
Old Oct 8, 2024 | 06:35 AM
Macumba's Avatar
did you found something about it ? Some fuse or wire issues ?
Old Oct 8, 2024 | 07:12 AM
Zuby's Avatar
nothing at all their is a fuse for the c43s but I don’t think the c63s has the same one my valves work when disconnected to calibrate etc just don’t work through the modes
Old Nov 17, 2024 | 02:44 PM
james111122209's Avatar
help
Thanks in advance!
I have the same problem with my 2020 c63 sedan i have catless downpipe and i have a exhaust valves error and no boost after 4k rpm
How did u solve it
Old Nov 18, 2024 | 05:34 AM
Zuby's Avatar
How did u solve it
best bet is to take it to Mercedes I absolutely tried everything with these in the end it went back to Mercedes and after about 2 weeks they managed to figure it out putting new valves in software updating it and having to play around with the coding!
its something to do with when they remap the car or if you’ve ever had a software update
Old Nov 21, 2024 | 08:17 AM
Do you mind sending a picture of the work order from the dealer ?
Old Dec 4, 2024 | 04:20 AM
AArun1120's Avatar
2020 C63 Coupe
Please see if you can find the dealer's paperwork on what they fixed because I'm having the exact same issue on my 2020 c63. It is a software limp mode but my dealer seems clueless on how to fix it so my only other option at the moment is getting a cpc tune for 2k.
Old Dec 4, 2024 | 05:01 AM
Zuby's Avatar
will see if I can get hold of the work order but it was bath Mercedes who ended up sorting mine out was something to do with fitting new valves then playing around with the coding of the valves which ended up fixing it
Old Dec 17, 2024 | 11:34 PM
Joey911's Avatar
W205 C63 Sedan
I had a similar issue when I purchased my car used. I took it to the dealer, and the technician found that the wiring was damaged (from rubbing against the body). I got a similar code and experienced soft limp mode (with no check engine light).
My symptoms were that once the flaps opened during full throttle, they would stay open. It was obnoxiously loud in the garage.
