ABC problems?
Here is a DTB (I'm sure you have seen it) regarding some ABC problems in 2002 models...
DTB
Date: August 23, 2001
Order No.: P-B-32.50/5
Supersedes:
Group: 32
SUBJECT: Models: All S55/S600V vehicles beginning with serial number A228578
All CL500/CL55/CL600 vehicles beginning with serial number A018300
S430V/S500V vehicles beginning with serial number A228578 with
ABC, Option Code 487
ABC Erratic Behavior
For vehicles that begin in the described VIN range, please inspect for an orange decal marked "ABC" located
on the left front “A” pillar near the door hinge. If the vehicle does not have this indication, please follow the
procedure outlined below.
ABC System Function Test:
· Vehicle engine at operating temperature
· Connect DAS (Version 8 plus Patch CD delivered with Version 8 on approximately 08/21/01) and access
the ABC system
· Read and record DTC data for Warranty Claim text field
· Erase all DTC’s in the ABC system
· Enter into “Actuations Menu”
· Enter into “Regelventiltest”
· Conduct this test 5 consecutive times
· Back out to “Actuations” and enter into “Wanken”
· Enter “Wanken” program by pressing the F3 key.
· Observe all four struts while the “Wanken” program is running.
· If one or more corners are not moving, stop the program by pressing the F4 key and return to the
“Regelventiltest”. Conduct the “Regelventiletest 5 consecutive times and then return to this test and
run it in its entirety, approx. 15 min.
· Back out to “Actuations” and enter into “Nicken”
· Enter “Nicken” program by pressing the F3 key.
· Observe all four struts while the “Nicken” program is running.
· Back out to “Actuations” and enter into “Rodeo”
Have you messed around with the 'Norway' settings ? Supposedly you can make the arming and disarming of the factory alarm audible via it...
I have since given up and asked my Atlanta Dealer to issue me a full refund for the car. For $118,000.00 the repeated failures of the ABC system are just unacceptable! I am now looking at getting a new 2003 7 series instead.
MB has got some serious issues that need addressed, They seem more occupied with keeping a lid on this then fixing it. I also have two friends that are now seeing the same failures in there s55 sedans.
I have owned almost all the AMG cars since 1999 and cannot believe the issues i have had with the so called "flagship"
I do not consider the 2002 s's and cl's safe cars, and would never put my family in one from what i have experienced.
On the other hand, my ML55 and E55 have been Bulletproof!
ABC in the sport mode in particular is quite impressive, as the wheels stay planted in corners and over uneven pavement, even during braking, which I obviously avoid in corners. In either mode the car handles rough surfaces better than any that I have driven. However, faulty suspension is obviously very dangerous. Has anyone who has experienced failure of ABC seen signs or gotten an eraly warning from the car's warning system before failure?
Luckily, I've only seen my ABC warning light come up a few times without any detectable change in suspension. Probably a false warning. This was fixed at the dealer along with a false engine oil warning and other warnings.
On one occassion immediately following turning off the engine, I felt the car drop in the rear momentarily.
Before I purchased my car I asked several executives in charge of the CL in Germany about the reliability of the ABC. I was really concerned about "bugs" in the system.
They reassured me that this was a system that Mercedes was commited to for the future.
The fact that the ABC is now being featured in the S class sedans and the new SL should confirm MB's commitment to the ABC system.
For the driver of the CL55 2002 model year, why not try a 2003 CL 500. Maybe the AMG version has some strange errors. At least get a rain check for one in 2003.
I really don't think that the problem you had is final.
I love my CL500 and I am going to get a new SL with ABC when they arrive in the US. I think the two will make a good pair; one for open air sporty driving and the other for touring.
Good Luck!
My 2000 CL500 has 38,000 miles
