CL-Class (W215) 2000-2006: CL 500, CL 600
2001 cl500 wont start. need help
Old May 20, 2010 | 12:52 AM
fasttoney's Avatar
2001 cl500
hey guys, i have a 2001 cl500. and i went to the store, and when i got out , the car would turn over(starter n batt good). but it wont fire. i open the hood up and checked for fuel at the rails, it was fuel there. (fuel pump ok). so i disconnected the negative battery, and tried it. nothing. then i disconnected the positive waited for about 5 mins, connected both up. and she started as normal. drove home. parked it. turned off the car. came back out 30 minutes later. no start. just cranked. figuring wat worked the first time should work the second time. disconnected positive cable waited 5 mins. connected back. started right up. ive noticed that if i just do the negative cable, it wont work. but when i disconnect the positive cable for about 5 minutes, it start right up. if anyone had this problem, or know a solution. please help. didnt see anything on the forum like this. close to this, but not this.
im thinking something is sticking in a certain position. and when removing power froms it, it unsticks. thanks guys and girls.
Old May 20, 2010 | 12:59 AM
fasttoney's Avatar
2001 cl500
ill see what happens in the morning.
Old May 20, 2010 | 11:31 AM
fasttoney's Avatar
2001 cl500
np problems this morning. i was told when it dont start, wait 30 mins and it should start. cranksensor maybe bad. keep u posted.
Old May 20, 2010 | 02:01 PM
~CL500~'s Avatar
E90 N54 & W251
Same thing happened with me and it turned out to be the crankshaft position sensor. Confirmed it with an OBD code as well. It's a known issue with our cars.
Old May 20, 2010 | 07:48 PM
fasttoney's Avatar
2001 cl500
thanks cl500.
Old May 21, 2010 | 09:24 AM
Silverarrow1's Avatar
Former Vendor of MBWorld
2006 Mercedes E55 AMG, 2006 Ford Mustang GT
If you need the crank sensor I can sell you a new Mercedes one for $90 plus shipping. Retail is $171 part# A003-153-27-28. Let me know.
Old May 21, 2010 | 08:11 PM
fasttoney's Avatar
2001 cl500
thanks silver.
Old May 22, 2010 | 10:20 AM
fasttoney's Avatar
2001 cl500
crank sensor
silver arrow. i sent you a pm.
