CL-Class (W215) 2000-2006: CL 500, CL 600
Any Interest in Custom Rear Lower Control Arms?
Old May 24, 2012 | 03:01 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
I might be having a friend jig me up some rear lower control arms with a mounting point approximately 1" (might be lower, I have to decide) lower than stock. This will allow you to go lower, but will also make the ride nicer for your daily height (in addition to prolonging the life of the strut) because it will be as if you were actually raised 1" higher than your current height.
Any interest?
Old May 26, 2012 | 01:30 AM
momentum59's Avatar
'00 RENNtech CL60, '96 850Ci, '92 850i '01 Discovery II
Will it correct the camber on a already lowered CL?
Old May 26, 2012 | 10:50 PM
OCKlasse's Avatar
MBworld Guru
This will not affect the camber. It solely serves to make the car go lower, and make the ride nicer for an already-lowered CL.
Old Jun 4, 2012 | 02:28 AM
freestylebiker3's Avatar
w215 cl65, W212 E63, R53 Mini Cooper JCW, E92 328I
it would be cool if u can adapt some kind of camber adjustment on the custom lower arms.. maybe with esentric bolt or a adjustable end link similar to the power steering rack
Old Jun 4, 2012 | 02:42 AM
OCKlasse's Avatar
MBworld Guru
I totally could, but I have no use for it, personally. Get me enough interest, and I will
Old Jun 4, 2012 | 02:47 AM
well.. the lower u go the more camber you will get, which will give u un even wear on your tires... so this camber adjustment could save you money in the long run in tires
Old Jun 4, 2012 | 03:07 AM
OCKlasse's Avatar
MBworld Guru
yeah, but for clearance's sake, I need the camber
Old Jun 4, 2012 | 03:11 AM
true. true... i know the fender has about 3/4 inch of lip that can be folded over to clear bigger tires, but it would suck to damage a CL in that matter
Attached Thumbnails Any Interest in Custom Rear Lower Control Arms?-cl65-pic.jpg   Any Interest in Custom Rear Lower Control Arms?-cl65-2.jpg
Old Jun 4, 2012 | 02:56 PM
OCKlasse's Avatar
MBworld Guru
Very clean!
Old Jun 4, 2012 | 07:41 PM
fatmike's Avatar
CLK63 BS
This was my next move if I hadn't sold it. GL Brandon im sure it's gonna come out dope
Old Jun 4, 2012 | 08:42 PM
OCKlasse's Avatar
MBworld Guru
Thanks homie!
Old Nov 20, 2012 | 12:18 PM
OCKlasse's Avatar
MBworld Guru
I have received my prototype arms and will be test fitting them tomorrow! They will be camber-correcting as well!
Old Nov 20, 2012 | 02:03 PM
ROLLNNN's Avatar
2005 CLK320 Vert & 2005 CLK55 AMG
gonna be sick! cant wait to see this...
Old Nov 21, 2012 | 03:46 PM
Welwynnick's Avatar
2006 S600
I'm pretty sure the W220 has toe and camber adjustment on the rear suspension by the usual means.
Nick
Old Nov 22, 2012 | 12:53 AM
OCKlasse's Avatar
MBworld Guru
Nick
I believe toe only.
The arms need a little bit of modification. Hopefully within two weeks I will get them back and we can try again. The prototype arms are .5" narrower, and I will record before and after camber readings to see if that will be sufficient
Old Nov 22, 2012 | 12:54 AM
OCKlasse's Avatar
MBworld Guru
I considered using eccentric bolts, but it seems like a lot of work for around one degree of adjustability. Just shortened will hopefully do the trick!
Old Dec 6, 2012 | 01:18 PM
OCKlasse's Avatar
MBworld Guru
Here's a sneak peek. I still need to perfect everything between the links and the module. Better pics to come. Note I don't drive at this height, this is just all the way down on my V2 module.
Some things:
1. Driving height camber reduced approximately one degree (from 2.7 to 1.7)
2. The car drives SIGNIFICANTLY smoother at driving height. It feels almost stock now!
So far, I'm very impressed. I need to do some light trimming on the fenders now, since I rub slightly on the outside edge because of the reduction of camber. Overall, this will be a winner for those of us looking to go low, have the car ride nice, and have better tire wear.
Oh yeah, I also am boxing in the arms, so can you say improved rear traction?
Old Dec 6, 2012 | 04:09 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Pretty sweet results.
R.K.
Old Dec 7, 2012 | 12:59 AM
OCKlasse's Avatar
MBworld Guru
R.K.
