CL-Class (W215) 2000-2006: CL 500, CL 600
W215 CL500 abs / ESP warning lights and ignition issues
Old Nov 15, 2012 | 05:55 PM
iain1969's Avatar
2004 c215 cl500
Hi - thought I would repay the favour of posting a solution to an issue I investigated on this site as a guest. Bought my second CL500 2 months ago and after getting the ABC pump replaced 2 weeks into ownership using a non manufacturer warranty ( essential investment in an 8 year old CL !!) it began to refuse to start on turning the key and then displayed ABS/ESP warning lights. After a bit of googling and a few visits to the excellent MB specialists Creevy Motors on Ballygowan Rd in Belfast they discovered the brake light switch was faulty and it was throwing up the faults through the CAN / EIS electronics !!
A much cheaper solution than I thought possible bearing in mind the warning lights it was triggering so thought it worthwhile to post this solution for future puzzled CL owners to investigate !
Old Dec 5, 2012 | 12:49 PM
Jumbojim's Avatar
Mercedes CL500
Hi Iain1969
Are you saying that just by changing the Brake Light Switch on the brake pedal, you managed to fix both "no authority to start" and ABS ESF BAF warnings?
Old Dec 5, 2012 | 02:16 PM
awiner's Avatar
2003 CL55 AMG
Yes, the brake light switch does go bad and will cause these issues. I forgot about it until Iain's post.
If you search the forum you will find many people that have had this issue.
I wonder if this simple and inexpensive fix would rectify your ABS/BAS/ESP issue.
The No authority to Start is not an issue with a bad brake light switch, however, not seeing you standing on the brake pedal is and therefore lockouts the starter motor.
Old Dec 6, 2012 | 12:03 PM
Jumbojim's Avatar
Mercedes CL500
Thanks Guys, I am going to change that Brake Pedal Switch soonest. Will let you know if it fixes anything.
Old Dec 9, 2012 | 10:37 AM
Jumbojim's Avatar
Mercedes CL500
Brake Pedal Switch
I have changed the stop light s/w on the brake pedal, and it seems to have fixed all my engine starting problems. Best £20 I ever spent.
Thanks to you guys for suggesting it.
Old Jun 17, 2024 | 03:47 PM
c215-james's Avatar
c215
Simpleton here! Just changed the brake light switch on my c215 (06). Was tricky to get to but very possible. I had eps and abs lights come on on the dash after several minutes driving and brake lights remaining on even when not pressing brakes. Changing the switch solved all. Happy days.
Old Dec 31, 2024 | 10:29 AM
Lpm03's Avatar
2003 cl500
ABS, ESP and BAS warning lights
Hi all,
New owner of '03 cl500 here. I was working on the car the other day, testing some fuses as my passenger side door intermittently loses power (only when car is running) with the battery disconnected. After reconnecting the battery 3 warning messages were triggered; ESP malfunction, ABS malfunction and BAS malfunction. All working fine before with no issues.
What could this error be, I've seen plenty of messages about the brake light switch being the source but not sure this could be it as my brake lights don't stay on after I remove my foot from the brake. Any help/suggestions would be greatly appreciated!
Edit: car still shifts into gear, drives and does not go into limp mode, just no abs, esp or bas.
Old Dec 31, 2024 | 11:44 AM
c215-james's Avatar
c215
Originally Posted by Lpm03
Hi all,
Hi, before changing the brake light switch can you try clearing the faults with a code reader of some sort? I had similar issue but the brake lights were staying on sometimes even when the brakes weren’t applied.
As for the door loosing power- the wiring looms in these are susceptible to fraying and breaking due to the double hinged door. Most likely frayed cables. Very manageable repair for a regular person. obvs careful of electricity and all that.
I have repaired many cables in both doors, replaced the abc suspension with yellow speed coilovers and replaced the plastic switch in the gear shifter. Let me know if you have any questions on any of that. I think these are the most common issues on these
Old Jan 2, 2025 | 04:57 AM
Lpm03's Avatar
2003 cl500
Thanks for getting back to me.
Just bought a diagnostic tool, arriving early next week so will try and clear the fault codes then. I'll keep you updated!
With the door, we've tried to rewire it 3 times and no luck, and after consulting a local garage they've said it may be a faulty ignition relay switch. I'm going to look at the fuse box diagram to see which one it may be, have you heard of an issue like this before?
Old Jan 2, 2025 | 04:19 PM
c215-james's Avatar
c215
Yes keep me posted on both! Thanks. Would be great if it’s a matter of just replacing the relay. My issue was broken cables.
Next problem for me to address is non functional sunroof. Hoping it’s as simple as a fuse but I fear it may be the motor
Old Jan 6, 2025 | 07:40 AM
Lpm03's Avatar
2003 cl500
Unhappy
Hi,
Just checked the warning lights with the icarsoft v2.0 diagnostic tool and tried clearing them. Bad news, they didn't. I seem to have an issue with the bosch ABS unit.
The error I'm getting is:
- C1401-007: A7/3m1 (High pressure and return pump) does not switch off
Would this be a faulty component in need of replacement? Or is it a bad relay? I'm tempted to try the relay first, if that works it would explain why the error tripped when I was fiddling with the fuse boxes in the engine bay.
Any progress with the sunroof?
Edit:
I'm more and more convinced that relay K25 has gone bad, it would explain why this all triggered after i fiddled with the fuses. Additionally, the ABS light hasn't been triggered since i purchased the vehicle and the (reasonably) low mileage would suggest that the brushes in the ABS system are unlikely to have gone bad. I may just be waffling but that's my view. And the lights are now permanently on, always on startup.
Old Jan 6, 2025 | 03:01 PM
Lpm03's Avatar
2003 cl500
Talking
Hi,
Edit:
UPDATE:
Fixed, I swapped the relay for one that definitely worked, cleared the error code and voila, ESP, ABS and BAS back online and working as before!!!
