CL500 Trunk Alignment-Body Shop Question
I cannot tell what is causing this. Can anyone give me a clue?
Anyway, the lid's adjustment is repairable. He thinks that the reason he could not get it lower was that the original hinge may have been bent in an accident or during the repair process. A hinge is $212.00, I also need the whole weatherstrip around the edge and that is another $120.00. I also requested the driver side door be adjusted. The whole thing is estimated to be about $550.00. I did not think that was to bad considering I have almost got the car back in a comfortable condition where the vehicle will not require anymore repair work until spring. The blower motor will be next...it is chirping on start up and then intermittently.
I will post more as things get done. I plan on putting the vehicle in the shop between March and March 8.
I wonder if a weak spring could cause the lift at the hinge. I do not think my springs are weak because the lid will quickly fly up without any assistance. Shoot, in a stiff 40mph Texas wind like we are having today, I am afraid to use the opener from the inside because a think the trnk lid would leave its attach points.
I was very happy with the results. The new assembly offers the ability to adjust the spring load to slow the opening of the trunk. Before the trunk would fly open and scare the person to death opening it when the stops hit.
Park Place Mercedes Bodywerks, Grapevine Texas, did the replacememt and accommodated my needs without question. That included a free ride to DFW and dropping the vehicle to another parking lot for my pick up late at night.
in regards to the original thread, the trunk lid is able to manipulated by slightly loosing the 10mm screws that mount the hinges, and using a piece of wood with a hammer to nudge the hinges around until you find the spot that works best
I can't find this setting on the simulation anywhere. That, and I thought there was a trunk calibration setting in DAS but I can't find that either.
Cheers.
Cheers.
also, its seems in SIm mode trunk settings don't show up
I'll connect to car later to print you a screen for your trunk lid reset
Trunk is one thing I never got fixed in terms of little slam
Try without the emergency triangle (its very heavy) and if it is satisfying keep it that way of fix
can be arms, can be gaskets in hydrolic fluid system somewhere....
