CL-Class (W215) 2000-2006: CL 500, CL 600
2002 CL500 STOPPED CHANGING GEAR
Old Aug 26, 2013 | 03:04 PM
Jumbojim's Avatar
Mercedes CL500
Gentlemen
My car is stuck in 2nd. or 3rd. gear, cannot tell which.
Checked the autobox and found it to be empty of trans. oil.
Can I just fill up and drive away?
If so what is the correct oil?
Old Aug 26, 2013 | 03:32 PM
biker349's Avatar
cl600
i think you better find out where the leak is and repair it.
Old Sep 1, 2013 | 06:43 AM
Jumbojim's Avatar
Mercedes CL500
Yes Maz,
The leak proved to be the usual problem of failed seals around the electric plug. I found that I could top up the ATF level through the dipstick hole with a couple of litres of Red 134, then the car worked well enough to take in to the local Merc specialist. Repair cost £220. which included ATF and Filter change.
Old Sep 1, 2013 | 01:28 PM
awiner's Avatar
2003 CL55 AMG
Another reason why the tranny should have a dipstick. Its stupid Mercedes moved away from mechanical measuring tools on the owners end.
Old Sep 10, 2013 | 02:43 AM
JUNEBLOOD's Avatar
00 cl500 turbo 03 e500turbo w203_63 w203 m271sc/turbo
Originally Posted by Jumbojim
Gentlemen
Did any lights come on on the dashboard when it stop changing gears
Old Sep 17, 2013 | 04:48 AM
Jumbojim's Avatar
Mercedes CL500
THERE'S MORE
The above was not the only fault as the box stopped auto-changing the next time I got it really warm, then worked again when it cooled. Had to have the gearbox's electric controller circuit board replaced which added another £400 to the bill.
Old Sep 17, 2013 | 10:02 AM
mohd.awaly's Avatar
mazda mx5
it was possible to avoid all that ... this oil leakage happens slowly , it might take a long time for the tranny to lose all the oil in it , and at a point you will feel it slipping , hard shifting , weird shifting !! if you noticed that before you wouldnt have payed that much on your transmission ....
Old May 3, 2014 | 06:36 PM
B4DBJ's Avatar
CL 500 (W215)
I'm having the same issue limp home mode only when warm slight noise too fingers crossed for an easy oil and filter change
