Hydraulic fluid pouring out from front left?
Can anyone tell me what might have gone wrong?
Checked ABC reservoir and almost empty, almost all gone.
What is located on drivers side under reservoir that would leak like that?
If you start it up it pours out?
Thanks in advance for your help.
DO NOT drive it , you will ruin The pump. Buy some pentosin and fill it if you need to move it into a parking spot or on to the tow truck
Do I have to order the line or is it one that can be made?
If I have to order a line how do I know which one?
Hydraulic fluid pulled up under left front.
Again ,
Thanks for responding.
The other high pressure hose is a much bigger deal cause the engine mount has to be unbolted on that side and the engine lifted on that side for the hose to be removed and replaced.
I had both done the hose to nowhere twice and the other hose once. The hose which requires the motor mount to be removed is very pricey.
Also it is usually an indicator that your accumulators are bad or going bad.
If so it needs to be replaced or the hose will burst again which is what happened to me.
There are 4 accumulators but usually it is just the 2 self leveling accumulators.
One in front of the left front tire, the tire has to be removed and the inside fender splash guard removed to get to it.
The other is in the back just above the right side muffler (maybe left) but you can get to it very easily.
They are black spheres you can't miss them once you see it, they are nitrogen filled sphere that act as a type of shock for the hydraulic abc system, basically they hold the fluid and act as a shock for the pressure spikes in the system as you go over rough roads, pot holds, to fast over speed bump, etc..and it helps with the active leveling as the car corners and such and is pivotal for the smooth Mercedes ride.
If your ride is feeling a bit rough and your tires are not really bad then it is definitely an accumulator issues, or strut but as far as total ride feel and control it is the accumulators.
Good luck and get a good Indy and do your do diligents.
