CL-Class (W215) 2000-2006: CL 500, CL 600
What kind of tires do you like?
Old Apr 20, 2017 | 11:31 AM
Grandcouper's Avatar
Cl500
So I need new tires. But I'm not sure what to get. So the a dude at a tire shop told me pilot super sport 3. What's a little confusing are the sizes. Do I get the size on the door stickers or do I get a little bigger?? Do I get one size for the front and a difference size for the rear? Basically, am I sticking with stock or not?
Also what brand of tires do you guys like the best?
Old Apr 20, 2017 | 12:33 PM
reddog's Avatar
'03 CL500,& '18 GLS63. Gone: '83 500SEC,'99 500SL,'07GL450
Tires
What year is your Cl500?
In 2003 the base CL500 had 225/55HR17 tires front and rear. Wheels were
7.5J x 17", front and rear.
On my 2003 Cl500 with the optional "Sport Package" the tires were:
Front: 245/45 ZR18" front and 265/40ZR18" rear, high performance.
Wheels: Front: AMG 8.5J x 18" ET 44. Rear:AMG 9.0J x 18" ET44.
What tire and wheels are now on your CL500?
Old Apr 20, 2017 | 02:09 PM
Cl500
I don't remember. But I'll prob go with the more aggressive setup. Mostly because I'd like the most amount of grip as possible. Why did you go with smaller front tires and larger rears?
Old Apr 20, 2017 | 03:56 PM
tusabes's Avatar
Mercedes
Front: 225/45 ZR18" front and 265/40ZR18" rear, high performance.
those are the wrong size tires for the Amg sport package 18 inch wheels
they should be 245/45/18 front and 275/40/18 rear
to answer the original questions about why different sizes front and rear , Mercedes fitted wider rear wheels and also wider rear tires on the sports package and Amg cars . Standard cars have the same size wheels and tires on all 4 corners
as for what brand of tire , I pick a cheaper option than Michelin . I buy general G max , Firestone firehawk Indy, or sumitomo htr Z (all from tirerack.com) and they ship directly to a local installer . Much cheaper then michelin, they are only about $120 a tire and it includes free road hazard coverage
Old Apr 20, 2017 | 04:43 PM
Cl500
Tusabes, I feel like you're secretly a MB mechanic trying find out how much we know on the forum. I have the amg badging and what looks like amg body kit. So I'm not sure if that's "sport". I will say these tires are huge. Are these the sport wheels? The wheels themselves have the amg etching on them.
Old Apr 20, 2017 | 05:16 PM
tusabes's Avatar
Mercedes
Yes you have the Amg sport package 18 inch rims
correct oem size tires for these wheels are 245/45/18 front and 275/40/18 rear .
Many people put on the wrong size tires because smaller sizes are cheaper
Welwynnick's Avatar
2006 S600
If you want lots of grip, I strongly recommend having the larger rear wheels and tires (say 265 or 275 section) at the front as well as at the rear.
https://mbworld.org/forums/s-class-w...els-tyres.html
I've been doing this for a while on two cars, and it works very well.
If you want a smooth, comfortable ride, best stick to 225 or 245 all round.
Nick
Old Apr 20, 2017 | 10:21 PM
Cl500
While you guys are here. I recently ordered a crankshaft sensor for fcp euro. I got the "genuine mercedes" and saw a cam position senso. And thought I I'd get it too. For $64. I later realized the cam sensor was a Bosch. And the merc sensor was actually $200. Are Bosch sensors good for these cars or should I always get the merc??
Old Apr 21, 2017 | 12:55 AM
tusabes's Avatar
Mercedes
Bosch is fine .
Old Apr 21, 2017 | 11:00 AM
reddog's Avatar
Tire Sizes
2003 CL500:With the "Sport Package CL2. Staggered -width 18" AMG thin-spoke monoblock alloy wheels with high-performance tires. AMG-design sculpted bodywork."
The tire size as stated above is correct for this vehicle. 245/45ZR18 (front) & 265/40 ZR18 (rear).
Old Apr 21, 2017 | 06:01 PM
renault12ts's Avatar
W215 CL500 2005
There is only 1mm difference in diameter with a 245/45, 275/40 set up.
The difference is 9mm if 265/40 is used on the rear.
Old Apr 21, 2017 | 06:08 PM
W215 CL500 2005
But not the AMG engine.
Old Apr 22, 2017 | 05:29 AM
tusabes's Avatar
Mercedes
right , and if you use tires with substantially different diameters , you are more likely to get abs/wheel speed sensor errors, especially as the tires wear out.
245/45/18 front and 275/40/18 rear is the proper size, as the diameters are nearly identical . It also gives you more sidewall protection in the rear
i bought a cl600 where the owner put on incorrect size 245/40/18 front and 265/35/18 rear tires, as these sizes are cheaper . The reduced sidewall resulted in $4000 pothole damage to the wheels . You want as much sidewall protection as possible
Old Apr 22, 2017 | 10:45 AM
reddog's Avatar
With "Sport Package".
2003 CL500 Sales Booklet, pg.33: "Tires-245/45ZR 18 Front, 265/40ZR 18 Rear, High Performance.
2003 CL500 Owner's manual, pg.330: "Rims and Tires- Radial-ply tires, front axle,245/45 R18 100Y XL or 245/45 R18 96Y.
Radial-ply tires, rear axle, 265/40 R18 101Y XL or 265/40 R18 97Y."
