W215 V12 turbo removal
Maybe if you drop the subframe and fight taking them out from the bottom, but honestly it's not that much more work to just remove the entire engine, and once it's out the turbos come off pretty simply.
I dropped the front subframe (4 bolts plus a couple of little tricks). Got lots of pictures.
Why do you want to remove them?
Nick
https://mbworld.org/forums/sl55-amg-...sl-models.html
These are all the things you don't have to touch if you don't drop the engine:
- Fan
- Bulkhead
- Wiring
- Engine Cooling
- Heating
- Air con
- Oil cooling
- Charge cooling
- Transmission cooling
- Alternator cooling
- ABC
- Exhaust
- Propshaft
- Transmission
- Engine
Nick
I have a tiny oil leak in that area right turbo
Just in case I would find the leak coming from the turbo gaskets and not something easy
