CL-Class (W215) 2000-2006: CL 500, CL 600
Check Coolant Level warning.
Old Jan 24, 2018 | 03:46 PM
navajoflyer's Avatar
2005 MBZ CL600
2005 CL 600. Check Coolant level warning came on, expansion tank level nearly full, engine temp gauge wandering between 85c-95c when freeway driving. Coolant level warning continues to come on after driving for 2-3 minutes. Water pump and hoses recently replaced. Any ideas why the warning message keeps popping up? This only happened 1000 miles after water pump replacement. No leaks are apparent.
Old Jan 24, 2018 | 04:02 PM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
is your washer fluid reservoir filled or empty?
Old Jan 24, 2018 | 11:08 PM
droc112's Avatar
cl600
w215 new headlight lens
Hey guys iv'e seen some some post on ebay where i believe it was the E class where they were selling new headlight clear lenses do anyone know if there is anything out there where there is a retro fit for the w215 headlight lens thanks in advance guys
Old Jan 27, 2018 | 01:10 AM
tusabes's Avatar
Mercedes
no there is nothing for w215 headlights
Old Jan 27, 2018 | 01:17 AM
Tomsti's Avatar
CLS55
That's the best hijack of a thread in January!
Old Jan 28, 2018 | 09:40 PM
droc112's Avatar
cl600
Lol i apologize guys i wasn't paying attention when i posted my thread
Old Jan 28, 2018 | 10:53 PM
calgary's Avatar
2001 Mercedes CL500 2006 E350 4-matic
The 2000 to 2002 CL has terrible low beam headlights. I blamed this on the lenses, and kept polishing away, without any improvement. I then found out that the factory actually installed a very thin plastic cover over the glass lense. - removing this lense cover does not improve the low beam. Mercedes, starting with the 2003 model, did come out with a much improved headlight. In order to update the earlier CL you have to buy the later headlights, plus a $250.00 wiring harness. I have not done this - it would almost add 50% to the cost of todays market value for these cars. Might as well start looking for a 2003 or later model....
Old Jan 29, 2018 | 01:00 PM
droc112's Avatar
cl600
I think I'm going to look into changing out the projectors inside the headlights with a new ballast and see what i get after i install these led bulbs that i brought online i hear led bulbs might not help either guess i'll see lol
