CL-Class (W215) 2000-2006: CL 500, CL 600
CL600 to SL65 AMG Black Power steering pump
Old Jun 25, 2018 | 10:17 PM
brdstf40's Avatar
2004 cl600
Will the power steering pump from the AMG Black SL65 fit the 5.5 liter CL600? That would completely eliminate the ABC pump. I've found a pump for sale, but don't want to get it, if it wont work
Old Jun 25, 2018 | 10:58 PM
ItalianJoe1's Avatar
2003 CL 600
In theory it should (it fits a V12 that doesn't have ABC), but I haven't seen the black series pump in person. Got pictures?
Old Jun 25, 2018 | 11:11 PM
2003 CL 600
You made me curious. This is the p/s pump replacement doc specific to the black series SL65. It looks like it has brackets on the pump to adapt to the V12 mounts. This is probably what you need for an ABC delete on any car. If your pump is not including those brackets, it won't help. I'm still looking into it but I'd bet the pump, without the brackets, is the same as the V8 p/s pump
I see two brackets, A0004663140 and A0004663240 that are shown for only the P99 option (Black series) cars. I feel that those are the adaptor brackets to make the pump fit the v12.
It has a different pulley too, I'm guessing the non-abc car doesn't use the 7 rib belt? Or maybe it's just smaller.
File Type: pdf
Old Jun 25, 2018 | 11:17 PM
brdstf40's Avatar
2004 cl600
Here's the pump I found
https://www.buyautoparts.com/1/1/972...-54669901.html
Old Jun 25, 2018 | 11:23 PM
2003 CL 600
If you get a bare pump like that, you will be missing the brackets I posted, and the smaller pulley (although, I'd assume the 7 rib will probably bolt on ok).
All black series pulleys and the belt have a model specific designation, so it looks like it's a smaller or different belt.
Old Jun 26, 2018 | 01:42 PM
smartadze's Avatar
2003 CL-500
Or use a V-8 pump
Converting V12 ABC pump to a V8 power steering only pump
My V-8 pump was $89 Replace tandem ABC pump with ... ? power steering pump
Old Jun 27, 2018 | 04:34 PM
pmercury's Avatar
member
CL
is there a complete set now that can be mounted without building parts ?
I don't want to go into crafting supports
Old Jun 27, 2018 | 07:14 PM
2003 CL 600
I'm fairly certain if you get the brackets I posted, which the SL65BS uses, you can run the regular v8 pump and mount it to the v12, use the 6 rib belt and off you go.
Old Jun 27, 2018 | 07:35 PM
pmercury's Avatar
member
CL
where did you post that ?
what is a SL65BS ?
what 6 rib belt ? the one we use already ?
thx !
Old Jun 27, 2018 | 08:30 PM
2003 CL 600
what is a SL65BS ?
thx !
3rd post, check the link, it shows pictures of the brackets, and I posted part #'s.
Our belt is 7 rib no? Or ours is 6 and conventional is 5, maybe that's my mistake. I know the V12 belt is one rib wider than the non-abc cars. Haven't checked on an ABC V8 car.
SL65BS = SL65 Black Series
