C215 windows hitting the rubber trim
I could do with some advice.....my 2006 CL 500 windows are hitting the rubber trim when i close the doors.....they don't drop far enough on either side...
all 4 windows do there thing but the front windows just don't drop quick enough to get out of the way of the trim when i open the doors or low enough to miss the trim when i close the doors...
yes i have had the batterie off but i still cant reset them if that is the problem...
any help would be welcome.
Last edited by Peter John Halm; Jan 11, 2020 at 05:47 PM. Reason: missed email address peterhalm07@gmail.com
Usually the windows do not need to be reset to clear the rubber trim when opening/closing the doors after a battery disconnect...so not sure how to help.
without:
serie is LF window then RF then RR then LR
push the windows button all down and hold it for a few seconds more (3-4)
then the same with all other windows in the serie as showed above
done
but it looks more like a soft-close problem
__________________________________________________ __________________________________________________
There are many choices for DAS/Xentry Diagnostics for MB.
Ensure you have the right information before getting one. There is too much misleading info.
I’m a forum member and programmer who’s learned the hard way. PM me if you have any questions.
I will give it a go.....the soft close works very well i think???? it pulls the door in nicely on both sides.....
the windows only drop about half the distance they need to drop to clear the rubber trim.
and when i open the door its as if there is a minor delay ....meaning the window hits the rubber on the way open as well...
Thanks guys
