CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Cl55/65 Front calipers part numbers W215
Old Dec 19, 2011 | 07:53 PM
maxwerks's Avatar
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
Can anyone help me with the part number for the front calipers for the CL55/65 and are the calipers one piece with the brackets or are the brackets to attach the caliper to the knuckle a different part ? Thank you
Old Dec 19, 2011 | 09:28 PM
1995E320Cab's Avatar
2003 CL600 2005 745Li
Why not upgrade to a 2 piece light weight set like the E55 guys do ?
Old Dec 19, 2011 | 09:32 PM
ch33sehead's Avatar
2005 CL65 (current), 2001 CL600 (chopped)
CL55 calipers are smaller than CL65 ones. 55 calipers require 18" wheels minimum, while CL65 calipers require 19" wheels minimum. They all bolt directly to the knuckle. Probably won't fit on a W210 I don't think.
Old Dec 19, 2011 | 09:39 PM
Sorry I was thinking of this set up, its on a CL55 so would work also
https://mbworld.org/forums/w211-amg/...50lbs-off.html
Old Dec 20, 2011 | 06:05 AM
maxwerks's Avatar
sorry guys thank you for your comments , I should have clarified better , my E55 ( w210 ) has Brembo front and back ....the brake swap I am thinking of is for my CL600 ( w215 ) ..I wanted to know if the 8 piston AMG front calipers , as used on the ( CL55, 65 W215 ) are one piece ( bracket & caliper ) or two separate parts and if so what are the part numbers . If my guess is correct and thats a guess ..all AMG 8 piston calipers are the same , R230 : SL55, SL65 , W215: CL55, 65 , or the W211 E55 ...and different chassis require changing only the bracket to change the offset / and position of the caliper in relationship to the hub/rotor.
Karl if I may ask .. on your CL600 , I know you have the calipers I am thinking of , do you have the stock 600 rotors or are the rotors different also ( P030 ones ? )
Old Dec 20, 2011 | 06:24 AM
calemonlaw's Avatar
Honda
This system can be fitted to CCM-equipped models, however the hand-brake calipers will not fit properly. The hand-brake calipers from a standard brake model can be obtained and used.
Old Dec 20, 2011 | 09:09 AM
maxwerks's Avatar
Old Dec 20, 2011 | 10:24 AM
The stock CL rotors are smaller that the AMG rotors, there is a good sized difference but I'm not sure how much.
Old Dec 20, 2011 | 12:42 PM
maxwerks's Avatar
so on your car not only are the front calipers are different but the rotors also , do you have the true two piece rotors ( P030 style , hats and friction rings ) or the one piece floating rotors ( hats and rotors are one piece ) ?
Old Dec 21, 2011 | 11:33 PM
ch33sehead's Avatar
215.379 (CL65 05-06)
A0034200983 front left
A0034201083 front right
A0034201183 rear left
A0034201283 rear right
215.376 (CL600 03-06)
A0024209583 front left
A0024209683 front right
A0024205383 rear left
A0024205483 rear right
215.374 (CL55 03-06)
A0034203183 front left (supercedes A0024209783)
A0034203283 front right (supercedes A0024209883)
A0024205583 rear left
A0024205683 rear right
cl65 uses 390mm x 36 rotors, cl55 uses 380mm x ?? rotors, cl600/500 uses 360mm?? or maybe it was 345mm
