CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Newest Project: FULL 3.5" intake, including Y pipe and front mount filters
Old Jan 8, 2013 | 05:21 AM
nidyanazo's Avatar
550HP+ ///AMG CL55 Kompressor, Ducati 916bp, Yamaha R1 WSBK replica
Exclamation Newest Project: FULL 3.5" intake, including Y pipe and front mount filters
DEPENDING ON OPTIONS, you CAN build this system for as little as $235!!!!
Current pricing for competing products?
1) Needswings system: $850.
2) Fabtech: $650 (and it's "ONLY" a 3" system.)
I went all out, and used the "ram air" frontal filtering cone filters, and full heat wrap.
The cost? A mere $300, and you get a true 3.5" system, all the way from the filters, to the throttle body..
*I'm not selling these, just showing YOU how to make them. *
This system flows more air, and gets less heat soak, is hundreds of dollars less expensive then any other similar competing product, draws air from a cooler location, and by virtue of passing more air through the system allows that air to heat up less, since the heat would have to transfer itself to more volume of air in the same amount of time. But the fabtech and needswings systems look cool in their own right.
Here we have the same shot as above, but additionally wrapped with the header wrap. (that stuff is annoying to apply)
Here's the plan:
FULL 3.5" tubing, and filters mounting right at the front. The filters will have heat shields to combat the rising engine heat, and also be the "cutout" cone filters, so the air coming in from the sides of the radiator will ram air effect right into the filter "nozzles"
I'll also be wrapping the pipes with a heat wrap good to 1000 degrees, and on top of the heat shields (or underneath it I should say) using adhesive backed heat "blanket".
Here's the shopping list..
The Competition:
#1) Needswings system. ONLY 3". $850.
http://www.needswings.com/NeedsWings...t-e55dcai.aspx
#2) FABTECH System. ONLY 3" piping, and $650!
Finally, if you dont want to go all out, and you DO wish to retain semi-stock looks, you can always just replace your front intake tubes while leaving the filters and OEM airbox.
Read this thread here for more info:
https://mbworld.org/forums/cl55-amg-...els-today.html
Old Jan 8, 2013 | 05:33 AM
nidyanazo's Avatar
Once I get it all fitted to my satisfaction, I may substitute in these air filters:
Wrap them with the heat shield and wrap material too.
Then, I'll attach them to the front using these scoops:
Old Jan 8, 2013 | 10:32 AM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Where did you get those scoops from? Or did you make them.
R.K.
Old Jan 8, 2013 | 05:24 PM
nidyanazo's Avatar
The scoops are just slash cut pipes.
Old Jan 10, 2013 | 02:54 AM
nidyanazo's Avatar
Old Jan 10, 2013 | 11:44 AM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Progress looks good so far!
Old Jan 11, 2013 | 09:12 PM
nidyanazo's Avatar
ALL it takes is 3 cuts with an angle grinder. Total time of 15 minutes to fabricate this:
Old Jan 11, 2013 | 10:04 PM
nidyanazo's Avatar
Old Jan 12, 2013 | 12:41 AM
awiner's Avatar
2003 CL55 AMG
Are you planning a before and after dyno to access the changes ?
Old Jan 12, 2013 | 12:49 AM
nidyanazo's Avatar
I doubt it. IT"s just for the looks and SOUND.
So if it makes any extra power, great. But I'm not worried about it.
I'll pick up one of those cheap obd2 readers and check and compare IAT's.. That's what's most important to me. After testing it out just now, boy am I impressed.
Old Jan 12, 2013 | 01:03 AM
OCKlasse's Avatar
MBworld Guru
Looks like you'll need a DIY for your valve cover gaskets
Old Jan 12, 2013 | 02:14 AM
nidyanazo's Avatar
Old Jan 12, 2013 | 12:56 PM
awiner's Avatar
2003 CL55 AMG
Looks like the purge tank covers are the culprit. Common issue on these engines. They use a silicon sealant as a gasket which breaks down over time.
Remove, clean sealant, clean area, reseal, re-install.
Old Jan 12, 2013 | 01:41 PM
nidyanazo's Avatar
Old Jan 12, 2013 | 04:22 PM
alx's Avatar
alx
Looks good. Not sure once underhood temps go up you will be making more power since you will be sucking hot air especially if the fan is on, but nice work. A am sure you get more intake noise at wot.
Now wrap those tubes to guard against heat soak.
Excellent post with parts source and etc.
Old Jan 12, 2013 | 04:49 PM
nidyanazo's Avatar
Thanks ALX.
I will be testing out the OEM and my different variations, and recording IAT's to determine the true effect and temperatures.
Again I just wanted to try to fab up something, and now that I see it works (will upload a video soon of it in "action")
I will be removing the filters, installing these tube style filters and wrapping EVERYTHING including the filter housings with the heat shield, and the header wrap:
http://www.spectreperformance.com/in...et-outlet.html
and connecting them up to the front air intake openings on the sides of the radiator.
Before spending another $200, I wanted to make sure this system would work, seal against the throttle body etc.. And it does..
Old Jan 12, 2013 | 07:07 PM
nidyanazo's Avatar
Old Jan 12, 2013 | 07:20 PM
nidyanazo's Avatar
Just ordered 2 of these filters!
Old Jan 13, 2013 | 10:43 AM
Blkvip's Avatar
12' E559
agree with awiner would love to see before and after dyno. but none less awesome work nice to see someone else is making diy stuff
Old Jan 13, 2013 | 03:45 PM
nidyanazo's Avatar
Thanks blkvip, it may add HP but the sound is the real gain.. It' really really nice to listen to this motor boosting at full throttle!
Old Jan 13, 2013 | 05:56 PM
nidyanazo's Avatar
Upon further inspection they are looking okay.. I'll most likely do them and the valve cover gaskets in the future anyways..
Some updates..
Untill I change the filters out and connect the fronts directly to the port in the side there...
Old Jan 13, 2013 | 06:06 PM
nidyanazo's Avatar
Started wrapping the tunes fully, but needed to order another piece of adhesive heat shield..
Old Jan 13, 2013 | 06:16 PM
nidyanazo's Avatar
Continuing my project, I made the devil horns to funnel in fresh air..
See this thread for more details:
https://mbworld.org/forums/cl55-amg-...-radiator.html
Old Jan 13, 2013 | 09:52 PM
awiner's Avatar
2003 CL55 AMG
Not the super charger covers, the small covers on top to the valve covers (different sizes on left and right) are oil purge tank covers. Those are the ones I was referring to.
Next time your at the dealer, pick up a new window washer tank cap. They are $2-$3.
Old Jan 15, 2013 | 07:01 PM
SLCL's Avatar
CL55, SL500, E350
These things break like once a year for some reason. I have been buying them for years! Tell them you need one for the W124, they are the same size but cost like 1/2 of the W215!
